Like Tree1Likes
Go Engine USA 2011 Thread
Old 01-21-2011 | 03:06 PM
  #256
MAGPIE-121's Avatar
Originally Posted by CHOAS
How does that MG66 run,is that a good truggy engine?
works for me in my overweight geriatric hobao thats a kg heavier than the rest, & they still can't catch it in a straight line
MAGPIE-121 is offline
Old 01-21-2011 | 04:27 PM
  #257
grizz1's Avatar
I ran two coral head 3rpt engines and loved them.Smooth power delivery and Plenty of it. I ran a lot fuel through them. Burned 24 gallons in the 2010 season The GX5 is nice in the truggy,a little bullish in the buggy.GX3 would work well in either I bet.Never ran a GX3 or GX7 though. How does that MG66 run,is that a good truggy engine?
ITS GO TIME
I have never run the MG in a truggy, but all the guys I know that have just love it. Eh Magpie
You should grab yourself a 7 Port, you would love it in the buggy. It's like a 3 Port on steroids that just keeps on winding out and out and out . Or maybe go the whole hog and drop the MG66 in the buggy
grizz1 is offline
Old 01-21-2011 | 05:09 PM
  #258
Flanno's Avatar
ITS GO TIME
Judge for yourself
http://www.youtube.com/watch?v=BucFOIkwSsc
Plenty of power and no fuel stop
Flanno is offline
Old 01-21-2011 | 05:14 PM
  #259
bigmatt's Avatar
ITS GO TIME
Like has been stated,Good. I have one of mine going to racer 22 aka rex welch. say's he can mod it to get more bottom out of it. which I feel is lacking.The mid and top are screaming!!!!!!!!!!!! You will in no way be dissapointed with an MG-66!! This is the first gx series engine I am running gx-3 port. And like you say they last for a very long time[if properly cared for]
bigmatt is offline
Old 01-21-2011 | 06:16 PM
  #260
nitroexpress's Avatar
Concerning your MG66. You are the first that I've heard saying the MG66 had a somewhat weak bottom end. But running my own MG66 in a truggy, I would tend to agree with you. I don't have a race tune on mine because it is not fully broken in, so I hope it wakes up soon.
nitroexpress is offline
Old 01-21-2011 | 06:50 PM
  #261
bigmatt's Avatar
I find that you need to keep it on the pipe so to speak. clutch setup is very important for this engine. when mine gets to mid it starts screaming and keeps going. If you can keep it at a certain pace it is fantastic. So I run a stiffer clutch spring for short run up jumps.
bigmatt is offline
Old 01-21-2011 | 06:59 PM
  #262
Flanno's Avatar
clutch is more important in a truggy than a buggy for the MG
ie; weight, & the bigger gearing and wheels than a buggy.
MBX6T I run 13/48 gearing as apposed to stock 13/46 too.
Flanno is offline
Old 01-21-2011 | 07:42 PM
  #263
MAGPIE-121's Avatar
try this with the MG in truggy & run a softer clutch, you will loose a bit of run time but hey if you what bottom end : http://www.massivemods.com.au/produc...roducts_id=314
Old 01-21-2011 | 07:50 PM
  #264
You mean the sold out MassiveModified Turbo Head Button?
I'm running a 4 shoe clutch with 1.0 springs. Don't think I want to soften the clutch. Maybe I'm being unfair comparing it to my old JPX.21 The Jammin was an animal, but it did have drawbacks. We'll see how it goes with a bit more fuel through it.
Old 01-21-2011 | 08:12 PM
  #265
bigmatt's Avatar
the mg is an ass kicker,your running my clutch set up,only I use the 3 shoe. Just keep breaking it in, loose the break in shim and hold on!!
bigmatt is offline
Old 01-21-2011 | 09:10 PM
  #266
grizz1's Avatar
Yep, you can't really compare anything until the motor is fully broken in. Especially if you still have the break in shim fitted. Loose that after 12 - 15 tanks.
When the majority of the pinch is gone, and you can turn the motor over by hand (in the buggy, by the flywheel from underneath when it is hot) straight after a run - remove one of the .1mm copper head shims (so you will be running .4mm of shims total). This will help to sharpen the bottom end a little, and give a tad more run time. It's cool to run up to 30% nitro like this. Run a medium plug (O'Donnell 97T or equivalent). The rest is up to clutch and gearing, but whatever happens it won't be slow that's for sure
grizz1 is offline
Old 01-21-2011 | 09:21 PM
  #267
MAGPIE-121's Avatar
MM does them to order from standard turbo head buttons
i didn't realize you are still breaking in the motor, just follow what grizz said above & hang on
Old 01-22-2011 | 01:22 PM
  #268
deadmancourt's Avatar
just dropped off my GX5R case to Lance @ RcRenew.com to put in TKO ceramics, front and rear ....cant wait to get her back....he was getting ready to take the lil ones out for a day of fun, so he said he will get it done tonight for me....or else he would have done it on the spot!.....great guy and great service guys....you should check him out
deadmancourt is offline
Old 01-22-2011 | 07:48 PM
  #269
juggaloracer198's Avatar
Thumbs up
+1
juggaloracer198 is offline
Old 01-22-2011 | 11:18 PM
  #270
Ruune's Avatar
I can vouch for Rex's work. I've got a GX-5R mill that he did for me last year in my MBX6-T. The thing is just plain wicked. He did some porting and crank work on it, and I added ceramics and changed to the long LSN.
Ruune is offline
