Arrow Racing GTR .21 Engine Thread
#811
These guys dont race at my home track..The RE-12 is similar to the 9901 and the 9901 sucked on my track..Our home track is 125x250' with a 230' WOT straight..I would trade the extra pit stop for a pipe that gives this engine balls..Grannies with walkers were passing me on the back straight
#813
#815
Take out the stock needles take the stock o rings off then take a small piece of teflon tape and wrap it around where the o ring goes then place the o ring back on its original place, bam your done, The Teflon tape makes the o ring fit snug like its supposed to. Hope this helps
I think I like that idea more than wrapping the threads. Anyone have experience with wrapping the threads? My concern is teflon tape seals and isn't designed to keep rotating - loosening, tightening, etc - that occurs with tuning an engine, and would become worthless after a while.
#816
Good suggestion.
#817
Guest
Posts: n/a
What I have been doing on my Arrow and OS/Bullitt carbs is put a drop of red Thunder Innovation loctite on the threads of all the needles. Then let it sit over night before starting. That solves the loose needles. I replaced the carb o-rings on my Bullitt and Arrow engines and they were both still way too loose once the engine was at temp, so thread lock is the way to go imo.
#819
#823
Yes. It will take Nova, Werks, OS, Alpha, etc. the only carb that I know for sure will not fit is Picco, but I have not tried them all. I have a nova carb on mine now and just got an OS carb for it cause I need that Nova carb back on my Nova. Put a little TLC into your nova or OS carb and it will last a lifetime if you don't ruin the insulator with the pinch bolt.
#824
Hi,
I am from Asia. We ran the Arrows here, with no whatsoever issue on the engine. The engine and carb all been very stable and easy to tune engine.
We had a team running the Arrows running in an endurance 8 hours race. Should have finish 1st place.....if the car didn't break down.....and clock the fastest lap too. Eventually finish 2nd overall..........
So far this is the first time I read that USA have so many issue with carb. All the needles are super. The engine hold tune in hot and wet weather. and I find it very strange that Arrows in USA have many issues on the carb.
#825
im stil breaking in my arrow. My needles feels also a little loose,but didnt have any issues yet.
Im using a RB 2087/192 combo.Anyone else have a experience with the combo?
In my novarossi 4btt it did feel a little more agressive al the way compered with the 9901.But still smooth...
