Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 04-19-2012 | 09:23 PM
  #691
Originally Posted by Mark Erce
has anyone tried a losi re10? i have a re11 and wanna know if the re10 will give me more bottom end?
i think it will if i remember these pipes if you want massivr bottom end i would go for the hong nor 2047 this pipe has the most bottom end i have ever come across and then the ae 2035 would be next.. Yes i like my hong nor pipes but that's only because they are reliable and do the job well and good value for money...
twitch_1 is offline
Old 04-19-2012 | 10:38 PM
  #692
Sein's Avatar
The re10 will definitly make the bottom end hit a lot harder then the re11. Try it but make sure you re tune your engine.
Sein is offline
Old 04-20-2012 | 08:24 AM
  #693
had the engine for 5 months now. since running great.
no trouble at all. no flame out.
carb hold tune. smooth in power. good fuel times.
pcage is offline
Old 04-20-2012 | 11:31 AM
  #694
Mark Erce's Avatar
Originally Posted by Rsickles
Arrow Racing is made by GO Engines in Taiwan at their Taichung factory.
Bullit Engines is made by OS Engines in Japan at their Nara plant.
XZ = Long stroke
VZ = Short stroke
Arrow is based on the short stroke VZ. The engine is a clone of the VZ-B V-Spec. It doesn't share anything with the VZ-B Speed, except for the fact it was designed with that style bottom end lubrication (the oiling hole was moved from the crank pin onto the rod to increase lifespan).
Bullit engines are based on the long stroke XZ engines. The 216 is essentially a XZ-B V-Spec while the 218 is essentially a XZ-B Speed.
Everything fits in a VZ-B.
The only thing that fits on a XZ-B is con rod, wrist pin clips, front and rear bearings, carb retainer, backplate screws, and the entire carb (just switch whole thing, I wouldn't mess with mixing Arrow carb parts with OS ones). That's it.
Crankcase, backplate, crank, piston, sleeve, head button, head gaskets, cooling head, and head bolts are all different.
what a great post! thank you for taking the time and explaining everything. i really appreciate it. i'll print this post and stick it in my binder. now i'll feel alot more confident answering questions when im at the track!
Mark Erce is offline
Old 04-21-2012 | 08:01 AM
  #695
Taffyjnr5's Avatar
Hi,
So the VZ-B Speed crank will fit the Arrow GTR........
Taffyjnr5 is offline
Old 04-21-2012 | 08:29 AM
  #696
Yes. I have fit one into my Arrow.
And works like magic.
However, it lacks in the long straight.
Arrow is better. Extremely fast down the long straight.
pcage is offline
Old 04-21-2012 | 05:56 PM
  #697
rfleck's Avatar
Broke the gallon mark and the Arrow came alive today. Plenty of low and and nice top end. Initially I was worried it would be a little weak on top but she was a bit faster after loosening up.
Running on a fast high bite indoor track, it will do 10 minutes. I think this is the smoothest motor I've ran.
Very pleased thus far
Oh using an re11 pipe and Byron's 30/9.
rfleck is offline
Old 04-21-2012 | 11:54 PM
  #698
Rsickles's Avatar
No problem! If there was a way to sticky it to the beginning of this thread... LOL. Most of the info is here, it's just spread out over pages and pages.
I just want to say one thing... the quality is up there on Arrow. I know saying GO freaks a lot of people out, since they lump it in with the no longer GO Tech engines. The truth is GO makes dozens of engines under different names. The JS stuff was great when I ran it. The new GO stuff is good too.
I agree. It's a tradeoff: Little less high for more low.
I've got the VZ Speed crank and it's got a lot of punch down low because of the timing. At higher RPM's I think it's hindered by not having a Speed sleeve.
Rsickles is offline
Old 04-21-2012 | 11:56 PM
  #699
James khoo's Avatar
Ya,mine loosen up really well.run with Orion 2058 pipe,runtime 10 min,temp at 115 degree,byron 30/11 on a big 30-35 sec track.gearing 11.97.
James khoo is offline
Old 04-22-2012 | 12:08 AM
  #700
I didn't know who manufacture arrow engine.
since but the others seems to follow arrows trend over the carb selection.
the arrow carb have good consistency.
I ran over 5 months and no hiccup.
try the speed crank, didn't like it.
since gone back what it is. I could forsake a little low end, compensated by smoothness.
but the high end, is a monster.
I like the arrow simply becos it is a simple 3 ports engine with blazing long straight speed.
pcage is offline
Old 04-22-2012 | 02:12 AM
  #701
sorry. I use ascendancy racing clutch with this engine.
it seems better than 3 pcs clutch.
pcage is offline
Old 04-22-2012 | 06:58 AM
  #702
Taffyjnr5's Avatar
Hi,
Whats a good pipe to run with the Arrow?
Old 04-22-2012 | 11:41 AM
  #703
Mark Erce's Avatar
the Losi Re11 seems to be working pretty good for me. great low end and blistering high end. runtimes are about 8-10 1/2 min. depending on tune, setup and track conditions.
Old 04-22-2012 | 04:08 PM
  #704
Jaz240's Avatar
Well I started break in today. I had to heat it to almost 300 degrees to get it to tun over but my carb got so hot I was vaporizing the fuel
Got the heat more concentrated on the sleeve and managed to fire it up at about 260 degrees. Ran 1 tank on the ground in slow figure 8's at same steady low RPM's just to get some fuel through it and seat the bearings. ran through the whole tank with no hiccups.
Let it cool down and re-filled for tank 2 and got about halfway through it when my throttle servo died..I must have heated that to 300 degrees also
installing new servo now and will continue break in tuesday. Hoping to get about 10 tanks through it by Saturday and then race it Saturday night. I went with the Nova 9901 pipe to start with
Jaz240 is offline
Old 04-22-2012 | 05:44 PM
  #705
Brian C's Avatar
Thanks James, whenever I'm feeling a little low I just find what you're posting and always have a chuckle. ' guess I heated that to 300 too!' that's classic.
Brian C is offline
