Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 07-04-2011 | 06:32 PM
  #271
jmaxey51's Avatar
Originally Posted by losi_racer
if anyone is interested in an arrow, 1/2 gallon on it, couldnt get it to run right, i believe it needs orings on the needles, they were loose but i put my nova back in and fell back in love with it and done with testing other engines, im sticking with nova.. pm me if wanted
is your carb seated all the way? mine wasnt and was a tuning headache. took the the pinch bolt out and seated the carb all the way in the neck. problem solved.
jmaxey51 is offline
Old 07-04-2011 | 06:42 PM
  #272
losi_racer's Avatar
yup, like i said i believe its the needles as they are loose, i know i prob could fix the issue very easy i just like the nova to much
losi_racer is offline
Old 07-10-2011 | 05:12 PM
  #273
xray2050's Avatar
xray2050 is offline
Old 07-12-2011 | 03:26 PM
  #274
STUBYSLAP31's Avatar
R/C Tech Elite Member
Has anyone ran the dynamite 2081 with this engine. Do you think that engine will be ok on that pipe?
STUBYSLAP31 is offline
Old 07-12-2011 | 09:19 PM
  #275
killerkustoms's Avatar
I have ran it with an 081, 2060, and 053 and the motor ran more efficiently with the 2060 and 053, didn't notice much from the 081 besides crappy mileage.
Just over the 2+ gallon mark and motor is still smooth, reliable and flameout free. Gonna switch from 6.5 to 7.0 restrictorand see if I can get more horsepower without sacrificing 10 minute runtime, keep ya'll posted.
killerkustoms is offline
Old 07-26-2011 | 04:58 PM
  #276
brandundecided's Avatar
What are stock needle settings for new break in motors. I just dropped some Arrow guts in an old speed I had.
brandundecided is offline
Old 07-26-2011 | 09:15 PM
  #277
On an Arrow carb, all needles flush.
Old 07-27-2011 | 09:11 PM
  #278
I broke in my new arrow tonight and man is that thing tight but after two tanks it sounds really good.Can't wait to take it to the track and see how she does.Lee
nascarracer is offline
Old 08-11-2011 | 12:21 PM
  #279
VPProUSA's Avatar
The new Arrow Racing GTR-21 version 2 engines are now available. They have a new redesigned crank case that is a little thicker & stronger. The new cases have a different Arrow logo on the side of the block.
We have had many pro drivers test the engine over the last few months and so far they all love it. They say it is smoother and gets better fuel mileage then the OS XZ-B V-spec. It is more like the older VZ-B Speed without the DLC crank & ceramic bearing.
VPProUSA is offline
Old 08-15-2011 | 01:45 AM
  #280
Approx what sort of settings are most people having once the engine has been run in?
Also, what about the mid needle? I have noticed most people are running at 2 o'clock but some have it at 10 o'clock...
Rgds
David
David1976 is offline
Old 08-16-2011 | 03:44 AM
  #281
Rgds
David
Anyone?
Old 08-16-2011 | 04:01 AM
  #282
Suspended
Rgds
David
mid-range flush.
Low end - 1/2 turn in from flush
top end 1 1/2 turns in from flush
30% sea level
should get you close
mikenix is offline
Old 08-16-2011 | 04:46 AM
  #283
Originally Posted by mikenix
mid-range flush.
30% sea level
Thank you. Looks like I am a bit rich on the bottom which I suspected. With the mid flush, where was the screw pointing- 2 'o clock, 3'o clock or 10 o'clock?
Old 08-17-2011 | 09:46 AM
  #284
VPProUSA's Avatar
Mine is at 2 'o clock
VPProUSA is offline
Old 08-17-2011 | 12:23 PM
  #285
Mark Erce's Avatar
mine is at the stock location still after almost 3 gallons. by turning the mid-needle to the 2' o clock position do u gain more low or top end power? or perhaps even both?
Mark Erce is offline
