Like Tree5Likes
"the engine tuning bible"
Old 10-09-2016 | 09:50 AM
  #496
Maximo's Avatar
Originally Posted by ironzgti35
Are there any tell tale signs of having too much or too little head clearance?
A engine with the head too tight will will usually display a strong tendency to hang its idle and no amount of tuning , linkage setup or idle gap adjustment can correct it..Unless you completely flood the needles the engine wants to keep revving when you let off the throttle ....They just become hard to tune when the head is too tight, they will not tolerate being leaned down any and will quickly start acting cranky if you try thinning the mixture...Also too much compression will increase fuel usage....
For optimal performance we want to run the squish as tight as possible however many things can affect this so IMO a little trial and error is necessary to find the sweet spot.. OS tend to go towards the over aggressive side while Nova leans towards the conservative side..there will be conditions where a OS will run better with a extra shim added and with Nova they usually run better with shims removed.
When you have too many shims the engines don't idle as strong, especially when hot, they will have a narrow tuning window on the LSN, they will lack top end power..
Once you find the sweet spot the engines will make the best power, idle stronger , have a broader tuning window, tolerate a richer mixture and not flame out as easy , will run strong even with no mechanical pinch ( OS trademark ) , stronger hot idle etc etc ....
IMO head shims play a pretty big role in how these engines behave and is something that is definitely worth playing with..IMO OS has head shims figured out and realized that the tighter clearance has more benefits then drawbacks...the engine runs crisper with more power has a broader tuning window and a much stronger hot idle at a slight sacrifice to runtime..
As these engines age they can sometimes tolerate less head shims...a freshly broken in engine may run best with a little extra shim but once its piston start to wear the engine may start running better with that extra shim removed... The best approach is to test how few head shims the engine will tolerate, as soon as you start noticing a hanging idle you know you went too far...back it up one step....Basically we want to run the least amount of shims the engine will allow...
Maximo is offline
Old 03-17-2017 | 02:57 PM
  #497
This is valuable information, thanks again for sharing
NitroJunky721 is offline
Old 03-27-2017 | 01:02 AM
  #498
Lasse Poulsen's Avatar
Hi Guys
Engine O.S Speed Spec 3. runs perfect. But when it ideals for 30 sec. Then you give it full throttle - The engine dies.. What the solution ? Thanks
Lasse Poulsen is offline
Old 05-17-2017 | 02:32 PM
  #499
Arctic RC's Avatar
Originally Posted by MassiveMods
It will take about 15 minutes of hard running to saturate a chassis at which case you start to get problems if the engine is not tuned correctly. You will find people who experience the " lower idle " have tuned their HSN first instead of last.
If you were to tune your Idle gap first , then your LSN then your HSN you will avoid this ( if its done properly )
M
How do you do when you tune idle, LAN and last HSN?
Arctic RC is offline
Old 05-17-2017 | 10:00 PM
  #500
SteveP's Avatar
It takes a little while to explain, but if you're starting an engine for the first time, be prepared to pinch and release the fuel line if you hear the engine idle down as though it's going to stall. It's a helpful tip to quickly reduce the amount of fuel going into the engine to keep an engine with an excessive rich low speed needle setting, from stalling so you don't have to keep restarting the engine.
You're going to want to observe two things as you're pinching the fuel line. How long it takes before the engine starts starving for fuel, and how much the idle speed increases before running out of fuel and losing RPM. You're going to want to release the fuel line before it stalls, but be ready to pinch it again and again until you can get the idle speed and mixture set properly.
If you pinch and hold the fuel line and the engine revs up and then starts to lose RPM over a period of 10-15 seconds or more (let go of the fuel line at this point), then your LSN is set too rich. So, the length of time it takes for the engine to rev up and then start to lose RPM from the loss of fuel, is an indicator of the mixture setting. Long time = too rich, very short amount of time = too lean. You're going to want the engine to start showing sings of being starved of fuel about 3-5 seconds after you pinched the fuel line. This should get you in the ballpark on the LSN setting that the engine will idle (more on that in a minute) so you can run it and fine tune it.
The amount of increase in the engine RPM is an indicator of an idle adjustment. If there's a very significant increase in RPM, it typically indicates the idle speed is too high. If there is little or no increase in RPM, the idle speed might be a touch too low.
Once you have the idle speed and idle mixture settings close enough to keep the engine running reliably, you can start running it to further refine your settings and to break-in the engine. Don't go full guns right off the bench. Work your way up to full speed after a few tanks.
SteveP is offline
Old 05-31-2017 | 07:01 PM
  #501
When I change the position of my car the engijne speed changes. Example- holding car wheels off the ground and then tip the front end down the engine elms change same when goes nose high... does this mean anything or is this normal
rjkotzur is offline
Old 05-31-2017 | 07:17 PM
  #502
mourinho's Avatar
normal. if you cant carry your car level or when picking it up to stop the engine etc, lift the front end not the back, lifting the front makes the mixture richer, if you lift the back it will be leaner and revs will rise
mourinho is offline
Old 11-14-2017 | 10:45 AM
  #503
just trying to make sure I understand what is going on and I am on the right track with where I need to go tuning wise
so after getting the engine up to temp and pulling off the track and setting car on the box the idle is high and the wheels will spin for about 10 seconds or so, then the idle will drop down to what I feel is a good idle speed and wheel spin stops. Rev engine to clean it out and the process repeats.
Based on what I understand my LSN is too rich and it is loading up which is why the idle speed drops and overall my idle speed is too high which is why there is wheel spin initially?. From what I understand I want it to be at the lower idle speed immediately after letting off the trigger?
thanks for the help
rjkotzur is offline
Old 01-01-2018 | 03:06 PM
  #504
dld's Avatar
dld
Originally Posted by SteveP
. . . The amount of increase in the engine RPM is an indicator of an idle adjustment. If there's a very significant increase in RPM, it typically indicates the idle speed is too high. If there is little or no increase in RPM, the idle speed might be a touch too low.
Once you have the idle speed and idle mixture settings close enough to keep the engine running reliably, you can start running it to further refine your settings . . .
First of all SteveP I want to thank you, as well as all the other Gurus of this lovely forum for making me understand how to tune my engines. I have been reading this forum posts for a long-long time and you guys shed light in quite a lot of different subjects, concerning RC nitro cars and their engines. Thanks, I really mean it
Now my question, a theoretical one :
Lets consider all other parameters being normal / OK.
Once the idle speed and LSN settings are set (5 to 6 seconds pinch test and a slight raise in RPM before it quits, warm engine NOT hot), I will put the buggy on the track and start leaning the HSN (long straight, WOT passes). Lets say after 3 or 4 or 6 hour lean adjustments of the HSN (one hour at the time of course), my power, RPM, smoke trail and engine head temp. is where I want it.
Now, theoretically speaking, shouldn't I have to richen the LSN at this stage to compensate? What I mean is, the fact that I lean the HSN should automatically lean the LSN as well, no?
And if that is the case, is it not a good idea to initially leave the LSN on the rich (but drivable) side (8-9 seconds pinch test, as it will be leaner after you are done with the HSN tuning) and revisit the LSN for a final tune AFTER the HSN is dialed in correctly?
I read through the Werks tuning procedure and the procedure in this thread several times. Sorry to repeat the same question again. I am just trying to undertand the relation between the LSN and HSN during the tuning process. Could somebody define this as a ratio (lets say for example if you lean the HSN 6 hours you should the richen the LSN 2 hours to be in balance). Or should I try and tune LSN and HSN completely separately?
I know it is not that easy, but is there any logic to what I am trying to say, or am I wasting yours, mine and everybody else's time . . .
Thanks for your answer.
dld is offline
Old 07-23-2018 | 12:43 PM
  #505
zonda's Avatar
Running a Nova P5 - probably on 3/4 of a gallon.
Is it possible to run the idle gap too small disguising a lean bottom end? I was getting a lean bog on the LSN when opening the throttle. Car would hesitate then take off. The idle wasn't racing high or pinging but richening the LSN took this bog away. I then had to raise the idle slightly.
running carbon shoes with 1.0 springs.
Rob
zonda is offline
Old 07-28-2018 | 10:23 AM
  #506
After Run Oil
There is conflicting information from various manufacturers on how to treat an engine after it was run. Everybody recommends using an after run oil, however TRAXXAS advises using WD-40:
https://traxxas.com/support/How-Perf...-run-Procedure
whereas Novarossi is firmly against it:
Frequently Asked Questions | Novarossi World - NOVAROSSI WORLD
WD-40 is widely known as a water displacement product, but nobody (except perhaps the manufacturer) knows its composition. I doubt it has any oils in its formula
After I've read the TRAXXAS article, I used WD-40 on my Kyosho engine (even though it's not a Traxxas…) Next time I ran it, it seized on the end of the crankshaft on the sealing surface behind the front bearing; not a big thing and it's already fixed, but I wonder... was it the WD-40 or was it not?!
Lacking a proper "after run oil", now I'm using a 3-in-1 product called motor oil M-20; at least it is oil, and also has a strong odour (why?).
What do you experts think, what is your experience?
kwhunter is offline
Old 08-14-2018 | 04:36 PM
  #507
TOO-TALL's Avatar
Hi,
Read this thread.... very helpful.
Im having 2 issues.
1--Truggy idles fine for 4-7 seconds then idle speeds up alittle...…..to lean LSN?
car has plenty of punch.and has a nice smoke trail.
2--After a wide open pull running down the street I let off the throttle and car dies...….some smoke out pipe.
on the box there is no issue
I replaced the gas tank,shimmed the clutch better,checked for a hung clutch shoe nothing.....Help
TOO-TALL is offline
Old 08-14-2018 | 05:33 PM
  #508
Grinder's Avatar
Originally Posted by kwhunter
After Run Oil
It is a good idea to use after run oil after each days running. Certainly if the engine will not be run for over a week. In certain parts of the country where it can be very humid, engines start to rust quickly without after run oil. No fuel is immune to attracting moisture when left inside the engine. A common problem I see causing bearing issues is rust inside engines. This can be avoided by using the right after run oil properly.
Don't put the oil in the glow plug hole, put it into the carburetor, and turn the engine over on the starter box for 3 seconds.
It is also very important to get any residual fuel out of the crankcase before you add the oil. To do this remove the fuel line, and start the engine until it doesn't want to fire any more. The engine will likely run for a few seconds as the residual fuel is being burned.
Regarding type of after run oil. Do not use WD-40. The WD, and any other petroleum based chemicals will make the silicone in some engines swell up, and detach. Our after run is completely silicone safe. Most labeled after run oils will be safe.
Grinder is offline
Old 04-11-2019 | 08:20 PM
  #509
You should just burn all of the fuel out of your engine and get some Marvel Mystery Airtool oil this good stuff and put a few drops in works great Michael
stoney452 is offline
Old 09-04-2019 | 03:53 AM
  #510
Thanks for the information!! your information helpful for us!!!
Pagaresav is offline
