"the engine tuning bible"
#31
Never used them engines before I don't get all wrapped in temps too many things can change that. Like running a M/T they tend to run very warm. I go by sound, smoke and reading the glow plug. The glow plug gives a better showing what is going on inside the engine. But smoke thing has changed alot since the most fuels are using syn oil now. That low oil content fuel which is better IMO all that extra oil tends to make them run warmer oil don't burn.
#32
So i have a question regarding the procedure for applying ARO in the original post... What type, if any, ARO should you use in an engine with a silicone filled crank such as the OS Speed? Would petrolium based ARO's react with the silicone filling?
I have wondered this for some time now, and as such, have not used ARO on my 2 Speeds for fear of ruining the crankshaft!
#33
imo , you are right about petroleum based oils .
just my opinion
#37
i have a NR 3 port. it is running on a near perfect tune. runs great.... except it want to lose fire. it may go 5 laps and die and the next time it will only go a half lap. it usually dies on an impact like a jump or a crash. it will also die coming out of a corner. after i get out of the fuel and then i get back in. usually sounds like i just ran out of fuel on a perfect tune. ?????????? the engine has 1.5 gallons on it. has good pinch.????????
please help.
please help.
#38
please help.
please help.
#41
please help.
please help.
I've had this problem with some of my car and a smaller flywheel has solved it!
#42
Houston,
I have a question for you. Some of the local racers here just returned from the Hank Perry Race in Spokane and they were informed from more than one Pro racer to not touch the flywheel to shut the engine off. They were told that method is hard on the rod. I'm not trying to start anything here, but that doesn't sound logical about the rod IMO. These guys were told to cover the exhaust pipe stinger to shut the engine off is a better method. I know that can cause a hydraulic lock in the cylinder and dissagree with this method. Am I wrong?
What is your opinion and reasons? Thank you for your time.
#43
Houston,
engines
#44
hi guys,
what could've caused the nitro in the tubing to 'back flow' when i crank it on the starterbox?
it's was fine 10mins ago but after it stalls and when i tried restarting, it just wouldnt start anymore and i notice the nitro would 'back flow' and my nitro line will be empty of nitro...
even if i tried covering the exhaust and managed to pump nitro into the carb, the nitro would 'back flow' again when i crank it on the box!
5Likes
