Picco .21bas Problems
I went out to run today and i burned out 2 glow plugs. It was just fine yesterday, then I put another plug in and it wouldnt start at all.
I tried to tune it but nothing, I havent checked it yet. But I wanted to get some input before I took it apart. Do I have a leak? any info would be great, Thanks in advance. |
Maybe too lean. Try richen it up a little bit.
I did that and it didnt help.
How old is the motor? I'd have to go too lean or sloppy rod. If your rod gets too much slop it can cause plugs to burnout. If any of them dropped the element it'll be time to pony up for a new motor.
little under 2 gallons
Check for excessive rod slop. Or too lean. I can't think of anything else...maybe someone else will chime in.
i got an ofna .26 picco outlaw first the hsn broke so i had to buy a new carb my lhs doesnt carry a darn thing for ofna, then i get home put the carb out luckly a snug fit i tried to start and relized no compression. non the less i have a worn piston and sleeve does any one have this for a decent price or a motor for a decent price heck might even trade my motor if ya got a diff one lol plzzz pm me
what kind of plugs are you running ?
ofna b4 hot plug
od sport purple and red |
Originally Posted by koopesv
(Post 8041633)
ofna b4 hot plug
Originally Posted by Maximo
(Post 8041722)
is that the plugs you started with ?
I know this seems like a stupid comment but sometimes it's the little things. Did you check your igniter was lighting the plugs well?
Could be many things or something simple, the rear bearing could be going out. Was the motor noisy like a grinding noise? If you take it out of the car and look at the piston through the exhaust port and see very small scratches it is from the rear bearing.
Rex |
Does your engine still have good compression and pinch?
- Check all screws and retight them - Inspect where the carb enters the engine for leak and retight the screw. - Replace fuel tubing, make sure there is no air leak in the tank/tubes What's your glow starter? and what kind of battery you use? Too much voltage will kill the plug |
Try a cooler glowplug.....
| All times are GMT -7. It is currently 03:18 AM. |
