NEW OS 21 XZ-B and Speed XZ-B
#2476
My practice engine is a BO1 with all new internals this is the one I took the carb from. My Club race engine is a BO1A. I saving the speed for big races. I have to admit I love the easy tuning of the O.S. brand an I thought NOVA's were easy to tune.
However i knew something was wrong with the speed when I started chasing tune. A fellow race has the same XZB speed he got his before me this summer. He had the exact same problems this summer so its not a weather thing.
I actually came by my speed because of the same problems the previous owner was having with it. I thought it was the tuner so I bought it with a half gallon on it seller went back to his beloved Ninja's.
I've always been jealous of the O.S. guys and how easy there engines tuned and sounded. I knew it had to be another issue other than tuneability. I've watched to many times O.S. guys come to the track and either don't touch a needle or make an hour adjustment and there off racing. Now I dont get into who has the fastest engine cause it only matters who can drive there car the fastest whipped many a ninja with a NOVA bf.
With all that said damn my car looked like a Rocket!!!!
#2477
My oldest XZ speed is just over a year old and I ran 2 of them through our winter series where temps start in the 30's and top out at 40's on some days. That's F not C and they ran fine no ghost flames. I was running the new J2 carb then. I use the J carb now only because it seems a little more tunable to me. But this last weekend I had to swap engines the bearings finally started to go after 7 gallons and I ran the new J2 carb and no issues. The issue with the ghost flames and the new carb I think is the bottom is too rich. You definatly have to make sure this xz engine and J2 carb is up to operating temp before you settle on a tune.
#2478
VLADCONNERY, There is not a problem with the new carbs. They just tune differently. I set the HSN on a break in bench and never touch it after that. Temp changes can all be corrected through the lsn. If it gets cold, I normally just have to richen the bottom. I never have to touch the idle either.
#2479
I tried to change bearings in a xz speed and there was no way to get the sleeve out. I used ice and then heat and a pair of channel locks some fuel lot of elbow grease and all I could get it to do is raise about 1/4 inch. I finally gave up and put in the backup speed. So I was thinking it was a fluke and then my buddy had the same issue. There are 7+ gallons on the engine and it has never been apart (there was be need to) anyone else experience this. I'm a little concerned that this seems to be more common than it should be. The engine was ready to be pinched and be used for practice but now it's a pile of parts. Anyone have an issue like this?
#2480
#2482
Sounds like there is carbon buildup around the exhaust port area on the liner.
Work it in and out that 1/4 inch and it should work free.
I have pulled many engines apart and never had a problem getting the liner out but after 7.5 gallons it will be difficult.
Don't use any metal tools of any kind. I just have the flywheel fitted and then I use a old tooth brush by placing the brush end into the top of the liner and push as many brush hairs as possible out through the exhaust port, turn the flywheel and up it comes. Tooth brush method is way better than cable tie and leaves no damage to any parts.
#2484
I was able to get the 2058 all dialed in this last weekend and it is a power monster on the xz speed. For those of you that want all the grunt this pipe is perfect. I'm going to stick with the OS pipes nothing wrong with the 2058 just my personal preference. So I can make someone a smoking deal on a 2 run weeks 2058 pipe and header.
#2485
#2486
This is fairly common on OS engines. You can get it out with a med sized zip-tie. What I do is put the piston at BDC, then insert the blunt end of the tie into the sleeve and then into the exhaust port (again through the sleeve, not throught the engine case/block) making sure that the zip-tie is not too far into the port (which would cause the tie to hit the engine case). Then turn the engine over using a pair of channel locks on the flywheel. You may need to repeat this a few times as the sleeve may only move a little bit at a time. It's very easy but difficult to explain. As already mentioned, do not use pliers or anything metal on the sleeve itself as it will undoubtedly ruin the sleeve. If this is too confusing, PM me and I'll give you my number and try to explain better.
#2487
#2489
