NEW OS 21 XZ-B and Speed XZ-B
#1502
The piston/sleeve will last the same time...the Speed crank will last much longer...... The Speed has more power from bottom to top.......The B5 is substantially stronger then the blue head XZB, but not quite as strong as the Speed.... The mod B5 outclasses the Speed in every performance aspect, but the Mod Speed compares very well with the mod B5
However, I can buy 2 Werks B5's (200euro) for the price of 1 speed (400euro). I'm running 20-30l trough a season so if I can get an other 20-25l out of it the next season with just a new rod, sleeve and piston that might be an option instead of every season a new B5/xz-b
#1503
XZ-B's are pretty cheap right now. Something to consider...
http://www.amainhobbies.com/product_...n-Buggy-Engine
Coupon code for March will save you $25
$250.00 - $749.99 $25.00 DPPMAR1125
#1505
With a speed, when I replace the sleeve, pistons and rod after a season, should i get another 20-25l from it? Or maybe a pinch and change the conrod. My LHS is a OS vendor and he has very low prices. Everything in Germany and Holland is cheaper than Belgium, except the OS engines from my LHS. And his CS is top notch.
This weekend with the Dutch open indoor race a lot off people came to me and asked me to tune there engines, they all didn't drive a Ninja JX or OS engine if you no what i mean
We also seen alot off flame outs in the 45 min A main, non off those engines were OS based
My Ninja JX was great all weekend with a 5th place as result in the A main so were the OS speeds off the rc-speedhouse crew.
Believe me there isnt a more reliable engine out there then a OS based engine.
I will let you no next week how to get alot off gallons out off a OS engine.
#1506
Jasper, come by me next weekend with the Ger/Hol/Bel race, then we will talk about engines.
#1510
Either one of those engines will be more powerful than the MR ninja. The XZ-B is more than enough power for a buggy. Do not hesitate to buy the standard one. Now if you want a ton of power, the speed will give you that. Like Neal said, the DLC coating on the speed crank will make it last a long time. You can successfully rebuild a speed and essentially double the life. With a new P/S/R and bearings you'll have a like new engine again.
#1512
Currently, it should go atleast a gallon and then I would order O.S. Complete Piston/Sleeve/Rod Assembly or the TKO front and rear bearings too. What do you reckon? Get the bearings too..
#1513
Carb
What is a eazy way to get a stuck carb out of a V-spec?It turns but I cant get it out.
#1514
do you have the pinch bolt partially in or have you removed it completely?
