RcRenew.com engine resizing and epoxy crank re-filling
#276
Keith, Received your Sirio. Engine was cleaned, inspected, crank was filled and is setting, And ceramic bearings were installed. Will ship it out monday morning after the epoxy sets.
Looks like more rain out here
Dang!!
Thanks again,
Lance
Rcrenew.com
Dang!!Thanks again,
Lance
Rcrenew.com
#277
Hey Guys, I got my plus 4's back from Lance a few weeks ago. It turns out both of them sucked dirt; witch destroyed the bearings and wore out the piston and sleeve. Luckily, Lance was able to resize the piston and sleeve. I also had Lance epoxy fill the crank shafts on both engines. He got the engines on a Thursday and they were ready to ship back by Monday. The resize was done in one day, but the cranks had to sit to let the epoxy cure before shipping. When I received the engines back, I took a look at the PSR he resized and they looked brand spanking new. I had to wait for my bearings to get here before I could do anything else, but once they did, I put everything back together and ran 4 tanks through each engine at an idle. Once that was done, I tore them down to clean them out and take a look. The compression on both engines is better then new. I couldn’t be happier with the service Lance provided. I would highly recommend RCRenew to anyone.
Thanks Lance!!
Thanks Lance!!
#280
Just to let everyone know how well the pinch service is, I got 4 more gallons out of my OS Speed on a medium pinch. It still has compression left, but I have to send it in for a rebuild for other reasons of my own doing now. Your top notch work and fast turn around = more
time at the track!
time at the track!
#281
time at the track!
time at the track!
3Likes
