TQ Engines
Old 01-03-2011 | 05:18 PM
  #451
jmaxey51's Avatar
which plug would be better the 97T or OS P4? i ran P4 with my GRP tuned and had great success.... the TQ plugs are hard to get for me.
jmaxey51 is offline
Old 01-03-2011 | 06:46 PM
  #452
RoyJ's Avatar
The TQ H4, H5, and H6 are all in stock at http://www.amainhobbies.com/advanced...words=tq+plugs
If you must use the Odonnell or OS, just try to stay with one brand or the other to keep from damaging your head button's plug seal. I would use the P4 or 99T for Summer racing, and the 97T for Winter.
RoyJ is offline
Old 01-03-2011 | 07:22 PM
  #453
jmaxey51's Avatar
ok thanks. ill just run the 97T and 99T.
jmaxey51 is offline
Old 01-21-2011 | 07:58 AM
  #454
RoyJ's Avatar
Default Updated Carb to Prevent Vapor-Locking
The engines now shipping from the warehouse I'm told will have the updated carburetor. The only difference is that now a composite material neck sleeve insulator has been fitted in place of the previous steel neck sleeve. The insulator sleeve is not available separately since they are press-fitted at the factory.
The composite material insulates the carb's temperature significantly, so the incoming nitro fuel keeps the carb-body cool. This will eliminate the chance of vapor-locking in the warm/Summer months. Using the correct glow-plug helps also.
RoyJ is offline
Old 02-28-2011 | 09:54 AM
  #455
briankstan's Avatar
I have a TQ-501T for sales, it's broken in, but barely used. comes with 2 H6 plugs, I'm open to offers
http://www.rctech.net/forum/r-c-item...ml#post8722985
briankstan is offline
Old 07-17-2011 | 09:56 AM
  #456
mxdawg's Avatar
Don`t know if i missed it or not but will the grp parts interchange with this model?
mxdawg is offline
Old 07-17-2011 | 10:04 AM
  #457
tony montana's Avatar
yes I do beleive they are. Im surprised you dont see many of these engines around. The original GRP was awesome
tony montana is offline
Old 07-17-2011 | 05:21 PM
  #458
mxdawg's Avatar
Talking
yea i have a few grp mills lying around was scared of running them due to parts shortage. guess i will start running them again and stock up on the speedlab parts.
mxdawg is offline
Old 05-07-2012 | 11:22 AM
  #459
Andrew_67's Avatar
I have a Marrio Rossi Tuned .21 GRP and i`m looking for a piston and sleeve, i heard the .21 TQ`s works, anyone know where i can still find these ??
Thank`s !
Andrew_67 is offline
Old 05-07-2012 | 06:07 PM
  #460
Thank`s !
tecnopower outlet
tracktearer is offline
Old 05-08-2012 | 12:36 AM
  #461
Andrew_67's Avatar
Originally Posted by tracktearer
tecnopower outlet
I don`t see engine names, which one is for the GRP ??
Old 05-08-2012 | 01:44 AM
  #462
Rsickles's Avatar
Thank`s !
You have a few options....
One... http://www.tecnopower-motor.com/OUTL...897000130.html
Two... See if Ascendancy has P/S/R combos for the Ascendancy G5. That is also the same. PM 'SoonerNate' or 'janderson78'.
Three... Just get your piston/sleeve resized and put a new rod on it. Ascendancy has rods.
Rsickles is offline
Old 05-08-2012 | 04:19 AM
  #463
part#0104001-01 (5T.21) or (5T.23) fits also. all grp, tq, ascendancy and tecnopower parts (b01,b02,t01,t02)are interchangeble.
