Like Tree4Likes
COMPETITION HEAT INC.
Old 09-19-2011 | 03:37 PM
  #1501
Muggydude's Avatar
what's the difference between the deuce and the regular one? (12V)
Muggydude is offline
Old 09-20-2011 | 05:56 AM
  #1502
CompetitionHeat's Avatar
The heating element, re-designed cover and New Deutsch connector.
CompetitionHeat is offline
Old 09-21-2011 | 05:06 AM
  #1503
Toiffel's Avatar
Quick question, I have the 12v Heater (not Deuce) lost the connecting wire that has the tamiya style plug one end and deans the other, can I swap the connector on the heater for deans and run a new wire connector with deans all around?
Toiffel is offline
Old 09-21-2011 | 06:24 AM
  #1504
I would only recommend replacing the connector with our new Deutsch, its a high quality connector that works perfect for the application.
Old 09-21-2011 | 06:30 AM
  #1505
kgombe's Avatar
the deans work fine... its a little tight to get on and off... other than that it will be fine.. i use it...
kgombe is offline
Old 09-21-2011 | 08:35 AM
  #1506
Yes, they are a pain to get on and off. We highly recommend a connector that has pins that are crimped vs. soldered.
Old 09-21-2011 | 10:25 AM
  #1507
MotoGod's Avatar
Eric does his homework. If he is recommending something, it's for a very good reason ;-)
MotoGod is offline
Old 09-21-2011 | 10:35 AM
  #1508
Toiffel's Avatar
So how do I get a replacement then ?
Toiffel is offline
Old 09-21-2011 | 01:14 PM
  #1509
You will need to ship us your Comp Heater.
You have PM, I provided detailed info.
Old 09-22-2011 | 08:04 PM
  #1510
bcarter007's Avatar
got mine back 2day from being serviced and u guys rock.....u were fast and communicated with me a++++.....guys dont hesitate to send your heater in for the new connector and or to just have it checked out is well worth the $19 bucks!!!!!!!! thanks again Comp. Heat
bcarter007 is offline
Old 09-23-2011 | 09:49 AM
  #1511
MotoGod's Avatar
Eric....got the heaters in today. All I can say is WOW! This new connector BLOWS the old one out of the water my man. After using the v1 product since inception, this one is WAY easier and looks WAY tougher than the last version. Awesome job as usual.....
I may actually send the old one in for at least the new connector after feeling how this one operates. Very happy.....
MotoGod is offline
Old 09-23-2011 | 03:38 PM
  #1512
Your Welcome... The new connectors are pretty sweet and worth every penny.
Old 09-23-2011 | 03:40 PM
  #1513
Thanks Scott... Enjoy your new Deuce, it's just about perfect timing as the weather starts to cool down.
Old 09-23-2011 | 04:09 PM
  #1514
guss2009's Avatar
Can someone post a pic of the new connector? I would like to see if i have the new one or the older one. I have the Competition deuce if that helps.
guss2009 is offline
Old 09-23-2011 | 04:55 PM
  #1515
MAGPIE-121's Avatar
If u have the deuce u have the new connector
MAGPIE-121 is offline
