NOVAROSSI Engine thread....
#6106
I found for fuel economy the 9901 pipe is the go
I get 11 mins driving smooth
Pushing hard i only get 8.5 mins I'm trying to get a medium were I can push and get 10
#6108
Try the 6 venturi with the werks 2058 pipe and header. I tested it against the 9901 and the 2096 with the 41021 header. the werks got about 1 extra minute of runtime and there was no comparison on the top end. It screams with 2058. It honestly sounds like a different motor. Try it, You won't be disappointed.
#6109
what is the bonitos fuel economy like in a buggy?
and how does the keepoff 21-4 compair to the P5? is it as fast?
#6111
Hey guys got a quick one for you
If your motor lean bogs from idle arfter 10 min on track you richen the top witch I've always done but then I lose my 11 min run time
So if I richen the bottom instead will this stall it when I give it a mouth full of gas
I've got a good speed now but only doing 8.5 fuel stops in buggy in a full legal set up buggy
#6112
#6113
#6114
#6116
#6117
Not really a issue like that I wouldn't not think
As I richen it up 2 hrs on top it goes away but my economy goes down too only if I push hard though
#6119
I usually run my engines slightly lean on bottom and slightly rich on the top end.
It should never lean bog though.
