Ofna Force .21 JL
Old 05-12-2010 | 11:01 AM
  #826
Ananda Robinson's Avatar
Originally Posted by off road god
Just saying thanks....
I checked out Easyriders new thread....2 pages so far....drama and sct racing so far(both subjects are mute to me!) Nothing about the JL.
Ananda, I saw where you had posted pics of your 2.0....you've built a fine looking racer.
Thanks Off road every community has its *troll* im trying to get back into RC after being gone for a long time, this community has offered lots of help along with local racers and tech from Neal at clockworks. "Its good to be back" ~Tony start
Ananda Robinson is offline
Old 05-12-2010 | 12:05 PM
  #827
off road god's Avatar
Originally Posted by scoopdaloop
Anyone have a dyno of a stock JL and also anyone have a dyno of a modded JL? I'm the type that resides upon factual information... I'm happy to send my incoming JL to have modifications but I need to see some sort of results. I know it will be faster but that means nothing to me on a race track.. I'm more concerned about a broader power-band and mileage(which mods don't help in most cases).
If anyone has dynos post them!
With your incoming JL you will receive a tech sheet with that info.
If you are interested in a mod on it,then just get in touch with Neal at Clockworks or any modder of your choice and discuss the pro's and con's of a mod motor. I'm sure if they're reputable they can ease your mind on what to expect.
off road god is offline
Old 05-12-2010 | 08:33 PM
  #828
kgombe's Avatar
some feed back...
i have tested many pipes on my engine but its on a very wide open track... so here is my feed back
the bullit 1005... good power but it seems to top out and have a lacking for something
werks 2013... this thing is killer on this engine... great bottom and top and not to mention it s sounds great.. run times suffered a bit..
jp3... almost the same as the werks 2013 but better mileage...
then i decided to try the 9901 with the short mugen style header from nova... and this thing had the most top end ever.. soft bottom and the best runtime for the track i was on... now i have to say it suits my driving style and the track i was on did not require to much power down low...
this is in a D8t
i would also like to mention that i pulled away from everyone on the back straight and from straight.. no matter what they were running...
by the way ... its the Clockwork JL
kgombe is offline
Old 05-14-2010 | 06:22 AM
  #829
Maximo's Avatar
Originally Posted by kgombe
some feed back...
this is in a D8t
Good to hear !
And yes the Clocked JL .21 pulls like a banshee !
Maximo is offline
Old 05-14-2010 | 07:08 AM
  #830
I noticed the same thing.
Old 05-14-2010 | 11:01 PM
  #831
Any body using losi buggy how do you get your motor to mount perfect. having problems with mine it sits to far forword and my carb linkage does not go on right.
scm22 is offline
Old 05-15-2010 | 03:36 AM
  #832
The carb will have to be at an angle. Make sure the linkage sets level.
Old 05-15-2010 | 05:46 PM
  #833
Integra's Avatar
All motor's require small adjustment's here or there to go from 1 car to the next.....As off road god said Make sure the linkage is level and not binding up the carb....loosen the carb pinch bolt and also the actual carb ball to acheive the proper angle/pull...and again Make SURE its smooth and everything works properly Prior to trying to firing up the motor.
Integra is offline
Old 05-17-2010 | 06:36 AM
  #834
Just being off less than 1 mm had my carb sticking.....after many valium and a magnfying glass I found the problem....had much less hair after that too!
Old 05-17-2010 | 09:27 AM
  #835
scoopdaloop's Avatar
Default Ha
Sticking due to what? The angle of the carb?
Has anyone switched the carb for a better one? If so, which?
scoopdaloop is offline
Old 05-17-2010 | 10:34 AM
  #836
Why do you think that you need a better carb?
I have ran almost a gallon and a half of fuel
through my Clockwork JL and have never had to touch
the idle screw. The Hi and Low speed screws
have only required very minor tweeks since the
first time the engine hit the starterbox wheel.
I own alot of nitro engines and the JL one of
the easiest to tune that I have ever owned.
I don't know and never asked Neal if he ever
pre-set the carb screws on this engine. I know
I told him I didn't need the carb modified for
venturi changes, so I don't think he did anything
to the carb. I do know that I told him that i'm very
happy with the JL and as with all my Clockwork
engines, It freakin screams.
rageworks is offline
Old 05-17-2010 | 11:44 AM
  #837
balistic's Avatar
I got a JL after fighting with two used engines I bought and for me (new to nitro) when I didn't have "help" tuning it I got it to run great. I just ordered a clockworks motor and found out talking with them that I may have my idle gap too big. If that works I will have tuned it right, the first time i can say that.
I can't wait to get the clocked motor!
balistic is offline
Old 05-17-2010 | 01:22 PM
  #838
When I first saw how small the idle gap was set
on my JL, right out of the box, I thought I was
going to be twisting screws right from the start.
But to my suprise, I have never touched the idle
gap screw. It fired up as soon a it hit the starterbox
wheel and has idled just right ever since.
I always like to run a little colder glowplug that most
do. The Picco med. turbo plug and the Dynamite #7
med. turbo plug run great in my Clockwork JL.
Old 05-17-2010 | 03:52 PM
  #839
Angle of carb and linkage....swap for a better one? Seen em' swapped so they could use restrictors. JL carb works great.
Old 05-17-2010 | 06:04 PM
  #840
Can anyone that has ran this engine PM me please, I have a few question. For 170 dollars, this engine looks killer.
DuckStang is offline
