Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
The New Werks B5 .21 Racing Engine >
Like Tree63Likes
Old 06-28-2019 | 09:42 PM
  #9361
Originally Posted by Werks
Thank you for using our product! In regards to yoru questions about the new HHSN (horizontal high speed needle) carb that we are shipping with our engines it's real benefit as mentioned is that we have found it to provide a more stable idle and also allows more precise fuel metering so adjustments are going to be more noticeable. The previous generation of carbs worked just fine (as based on your comments you have also noticed ;-) it's just that the never version just sees to do things better if that makes sense. It's not going to be night and day different but give it a try on your new engine and let me know what your thoughts are! Also I should add that the intention with it was not to make a so called "max power" or "fuel mileage" carb, it was simply to make a better performing carb.
no prob liking the powerband of B5pro2 tunes good runs good powerband is awesome in Buggy want to try it in truggy. I like bottom end and it’s got a nice bottom end not to aggressive where it’s undrivable in buggy like some engines. I love it in Buggy cause I just tap trigger and clear jumps wjth not much run up definitely saves fuel to cause not squeezing htrigger hard. I’ve tuned my friends b3pro2 and it tuned easy, thanks for reponse though I’m gonna definitely pop the new carb in the b5pro2 eventually and compare them and do some fuel mileage testing and do more of a comparison with same engine tuning. Thanks again
jersey is offline
Old 09-30-2019 | 11:58 AM
  #9362
I'm running a littl ebhind on this but I wanted to take a second to congratulate our Brazilian importer, Thomas Gisler on the results of our engines at the recent Brazilian Nationals!
Truggy Class:
1st place went to driver Marco Amaral running our B7KE engine!
4th place went to driver Rodrigo Nakad running our B5 Pro II engine!
in Buggy Class:
3rd place went to driver Rodrigo Nakad running our B7KE engine!
8the place went to driver Thomas Gisler running our B7KE engine!
As usual these were 100% box stock engines, they were not gone trough, inspected or have special parts used in them. They are exactly the same engines that are supplied to all of our customers!
jersey likes this.
Werks is offline
Old 07-25-2020 | 09:42 PM
  #9363
Im wondering who are still using B5"s and how they are holding up!!
inlinesick is offline
Old 07-27-2020 | 11:48 AM
  #9364
They are doing well, here's an example from the weekend before last. Adam Cogreve won Sportsman Buggy taking home 1st with his B5-Pro II powered Mugen at the 800+ entry 2020 Psyhico Nitro Blast! Jacob Savage also took home 3rd in Sportsman Buggy running one of our B3-Pro II's giving Werks Engines 2 out of the 3 top spots for the class! Werks team driver Evan Vail also made the A main in a very stacked Pro Truggy class with his B5-Pro II powered Associated truggy!
Werks is offline
Old 07-27-2020 | 02:01 PM
  #9365
B5 pro II is curently the best truggy motor?
Old 07-27-2020 | 03:52 PM
  #9366
Yes the B5-Pro II is our best all around truggy engine!
petersen114 and inlinesick like this.
Werks is offline
Old 08-04-2020 | 08:34 AM
  #9367
frewster's Avatar
Has the regular B5 been discontinued? It says it has been on Amain. Will the Pro II engines be the only ones available now?
frewster is offline
Old 08-04-2020 | 11:27 AM
  #9368
Yes we phased out the standard B5 & B6 engines a little while ago as the amount of different engine versions that we making was getting too large. Also in general engine pricing of our competition has been increased quite dramatically the last few years and we decided that with our Pro-II model we offer the best performance and feature set in comparison to what others are offering at a very atractive price point! To give you an idea of how our engine compares to the competition here is some pricing from A-main's site:
Werks B5-Pro II $284.99
FX K501 $379.99
OS B2103 $479.99
ProTek Samurai R03 $399.99
Tekno Bloc 2 lbm $469.99
Reds 721s $359.99
So as you can see we come in very agressive price wise when compared to the other engines currently on the market with similar feature sets!
Werks is offline
Old 08-04-2020 | 04:37 PM
  #9369
frewster's Avatar
FX K501 $379.99
OS B2103 $479.99
Reds 721s $359.99
Thank you for the quick update! Is the 2058 pipe still being made? My buddy has been having trouble finding it in stock.
frewster is offline
Old 08-05-2020 | 12:05 PM
  #9370
Yes, the 2013 and 2058 pipe sets are still in production and we sent a bunch of the 2058's to A-main a few weeks ago but they might have sold out since. Unfortunately we (and a lot of the other Italian engine manufacturers) are dealing with fall out from the pandemic right now as Italy was affected quite badly by the pandemic. The government put everything in lockdown there back in February shutting down all of the businesses/factories and they just opened up right around the start of June. Unfortunately on top of that everything in Italy is normally shut down for their summer holiday from August to September. The lead time on making engines etc is quite long so you are lucky if you are able to get more than 1 shipment out of Italy in that 2 month window before everything is closed for the holidays! So being candid availability of any popular items that are made in Italy (from any of the manufacturers) is going to be pretty limited the next few months until Italy opens up again and the manufacturers have time to catch up on production.
petersen114, frewster and jersey like this.
Werks is offline
Old 08-12-2020 | 06:55 AM
  #9371
Im struggling find parts to rebuild my B5!! Where could i find some?? Conn rod, piston and sleeve!!
Old 08-12-2020 | 10:00 AM
  #9372
Default Question/advice
Hey Ron,
So i have one of your B5 engines, not the newer Pro II version. The engine is sitting around the 4-5 gallon mark, and still has a lot of compression. However, about a year ago, I was a dummy and didn’t have the piston at TDC when I was taking off the back plate, and took a chunk out of the skirt of the piston. What I would like to know, is if I get a new piston for it to repair the engine, would I also absolutely have to get a sleeve as well, or can you get away with just replacing the piston. I understand that each piston and sleeve builds it’s own wear characteristics and then they essentially “match”. I ask this, because for the wallets sake, it would obviously be cheaper to just change the piston. But if that would cause issues with not changing the sleeve with the new piston, and I should just get both, then I might as well just look at getting an entirely new engine, as the price difference isn’t that much. What are your thoughts or advice on this? Thanks Ron.
xlrsd is offline
Old 08-12-2020 | 11:23 AM
  #9373
Originally Posted by xlrsd
Hey Ron,
I had similar situation, your going to need a new piston and sleeve more then likely as it’s not likely the piston will lap into a worn sleeve. However u can try. I just know it’s been near impossible for me because the situation I had was with a .19 speed and the piston used isn’t a very easy find as I have yet to track one down but all the asking around I’ve done I’ve always been told I will need a new piston if the sleeve is new, if it’s used you can’t do anything as the original piston has already seated and lapped itself in and they settle in u unique so the next piston won’t seal because it can’t fill in or lap in. However like I said I never found a piston to try cause the .19 isn’t popular.
Matt Piva is offline
Old 08-12-2020 | 02:42 PM
  #9374
Werks piston comes in a kit with sleeve anyway! You get all or nothing! I had my sleeve repinch, but the conn rod is loose on the crank! P/N wrxtl21070011 for the rod, and piston sleeve is p/n wrxtl21043241. Mine too is the older one!
Old 08-13-2020 | 12:38 PM
  #9375
Sorry to hear about what happened! A lot of people actually make the same mistake when they first start workingon engines unfortunately. As others have mentioned pistons and sleeves are always sold as a matched set, so you can not buy a loose piston or a loose sleeve (from any manufacturer that I know of). Hope that helps a bit!
Werks is offline
