EB Mods JS Engine
Old 05-11-2010 | 12:40 PM
  #751
jpalessi's Avatar
Originally Posted by TheFcuddy
I pulled the trigger on the full mod, an 086 pipe and some P5 plugs. Checking out shipping prices to Philly on the fuel as we speak.
shipping to Philly will be no more then $20 a case if you order from EBMods, or Lucky 7 RC. We're happy you decided to get a JS.
jpalessi is offline
Old 05-11-2010 | 12:42 PM
  #752
TheFcuddy's Avatar
I am leaning towards 25% just because some of the other engines that I have. I don't want to have 20% in one, 25% in another and 30% in something else. Will the JS full mod disagree with 25%? 25 is a good middle ground for everything I have. Let me know what you guys think.
TheFcuddy is offline
Old 05-11-2010 | 01:06 PM
  #753
jpalessi's Avatar
The JS comes shimmed for 25% - 30% nitro.
you should let Alan and Mike from Hobby Hut know you want to buy EBMods fuel. They can order it for you too.
jpalessi is offline
Old 05-11-2010 | 02:18 PM
  #754
wallot's Avatar
had to get a full mod again as it was the last engine available at amain (made a big order to smuggle back home )
will get a race prep next time i will be in the US (June) so I can compare
wallot is offline
Old 05-11-2010 | 02:35 PM
  #755
Default 25 % will work just fine
25% nitro will work out just fine. Due to Danish legislation, 25% is all we're allowed to race here. As mentioned already, the engine is set up to use 25-30% so you don't have to touch anything. The lower nitro content might make it necessary to use a hotter plug (thank you JPalessi).
moosemachine is offline
Old 05-11-2010 | 05:09 PM
  #756
nitro crazy's Avatar
just wanted to make sure i'm right. tune this engine from the high speed needle first then the bottom, tuning the bottom so the idle stays steady and doesn't drop, while not touching the idle screw right??? what temps should i be looking for?
nitro crazy is offline
Old 05-11-2010 | 06:33 PM
  #757
hambone's Avatar
Right. Throw the temp gun away.
hambone is offline
Old 05-12-2010 | 06:19 AM
  #758
jbright33's Avatar
dont throw it away just burry it deep inside your tool box....
jbright33 is offline
Old 05-12-2010 | 04:22 PM
  #759
just bolted a full mod in today, what is needed as far as break-in, i won't be running eb fuel all i have is 2 cases of byron's 30%.. is it good to go, or do a few easy tanks... thanks.....
Old 05-12-2010 | 04:37 PM
  #760
jpalessi's Avatar
being that your changing fuel you should idle a tank before race tuning.
jpalessi is offline
Old 05-12-2010 | 05:33 PM
  #761
thanks jpalessi, what would be a good starting point for carb restrictors, got a truggy with a 086 pipe. looking for just a bit over 10 minutes run time on a tank.. thanks...
Old 05-12-2010 | 06:05 PM
  #762
jbright33's Avatar
i run a 7mm in my d8t with rp i feel it makes great power with it and im getting 13min on tank
Old 05-12-2010 | 06:11 PM
  #763
thanks jbright, i'll probably go in the middle 7.5 and see where i turn out, can't wait to get her going.....
Old 05-12-2010 | 06:30 PM
  #764
jpalessi's Avatar
no prob! I've been running the 8mm w/ a 2041 and have been getting over 10mins everywhere. I would try them all and see what fits your driving/car the best.
jpalessi is offline
Old 05-13-2010 | 09:15 AM
  #765
Hm?????????????????????????
Franchise is offline
