New Ascendancy Racing Effortless Racing Clutch
#361
#362
Oh and make sure you are shimming your clutch bell correctly I can tell from the picture that you are not. The face of the crown should always be black. So you bell is rubbing and that will reduce the life of the shoes greatly as they will get too hot.
#363
He could've had it shimmed right if he's been running it 3-4 gallons w/out issues. The face of the crown probably lifted up when the base of the plate broke apart since that's what the nut holds down. Just my thought!!
#364
Ran into a few guys from UK at the track and they were using "JVD" clutch, it look exactly like the ascedense clutch just wondering if ascedense is marketing this clutch as 'jvd' in europe or is it a completely different company?
#365
JVD is the original and is designed by a dutch company. Ascendancy is a rebadged JVD with a black finish (original JVD is red).
I had the crown of a JVD clutch break aswell but JVD send me a new one free of charge. Could have been an early make aswell...the crown i have now has been flawless.
#366
This is not correct. The way it is made even if the bottom broke it would continue to work perfect as the springs hold the retainer in place.
It is the exact as the JVD as that is the MFG.
#367
Thanks for the quick reply!
#368
I'm not trying to start an argument here. I run the Ascendancy clutch on my Alpha motor and absolutely love it.
I cross threaded the nut on mine today. Was in a hurry and didn't make sure the nut started on straight before tightening it down.
#369
Then why is the plate designed to be held down with the nut? If the springs hold the top plate down securely then it would make it even quicker to change shoes or springs because you don't have to remove the nut.
#370
#371
mbx6
ok. i'm trying to fit the clutch in my alpha engine on my mbx6. It seems that crankshaft is too short and the bell is too tight. i used the parts that came with the clutch and tried using the shims that came the kit and still same results.
can anyone advise on what they did to fit the alpha s852 on the mbx6?
#372
I am running it in both the 6 and 6t. For the 6 no washers behind the shaft collet. 1tko thrust washer bearing then clutch then bell then bearing then shims and I use a dynamite end washer it adds a little more to then end of the shaft. I will try and post some photos tonight. I am also using the adendency clutch bell.
#373
thanks... it seems that the collet that came with the clutch have a sizable gap between the bearing and the flywheel. the stock flywheel had little gap between the bearing. I am wondering if this is one of the problems...
#374
I run the JVD which is just the european version on an OS speed with an mbx6.
Front bearing, Ascendancy Collet, Flywheel, Engine nut, 0.2 or 0.4 shim*, bearing, Answer RC Clutch bell, bearing, 0.2shim, large ish washer, 2.5mm Caphead.
The standard mbx6 CB does not fit.
* I'll check later this week the qty of shims and the size of the washer i use.
#375
Do make it in 38mm?
