Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Rayaracing sleeve resizing and tooling >
Like Tree15Likes
Old 09-03-2010 | 05:49 PM
  #376
Russ G.'s Avatar
Ray just as the other 2 times you resized my sleeve it looks great. When I sent the motor to you it had carbon on top of the piston and no pinch left. It also shut down at idle when hot. Well less then a week later for 20 bucks I get a motor that had a nice pinch and looks like a piece of jewelry. Cleaned up, polished and lubed. And the best part it now idles through tanks of fuel easily. You might have the best 20 bucks spent in RC.
Russ G. is offline
Old 09-07-2010 | 05:55 AM
  #377
From: 4373 Creek Road Chaffee,NY 14030 USA (716)783-5198
Russ,
I looked back thru my records to find your Plus 4 was last serviced April 15th 2010, showing 4+1/2 months running on a 2+1/2 tenth resizing. You must have been running this same engine since last year. NICE
RayAracing
RayA is offline
Old 09-08-2010 | 12:38 AM
  #378
Default every so often I do get one that cannot be fixed
Mark, Arvin, and Kevin serviced and return shipped.
Poorly resized piston+sleeve sets with Out Of Round conditions it is best to fix it before running, that would have otherwise worn piston unevenly, resulting a un-salvageable piston + sleeve set, or at the very least will not run well or for long. I have found the best repair method-process is to "first" OPEN sleeve bore while reforming cylinder to again a uniform (Perfectly Round) diameter. At this point of repair the piston is very loose in sleeve with NO physical resistance, loose enough to push piston thru top of sleeve. Resizing can be then performed accurately and with a correct tapered fit. I use the same process removing the pinch damage first, with OverPinch repairs.
Just request on my order form "REPAIR" as you would a standard resizing.
Any questions guys just call....
RayAracing
RayA is offline
Old 09-08-2010 | 10:31 AM
  #379
Timmo's Avatar
If my piston has scratch marks on it,can it be repaired and resized.
Thanks.
Timmo is offline
Old 09-08-2010 | 10:05 PM
  #380
Default Honestly
Thanks.
Please also look at sleeve liner surface finish condition. Post some well detailed pictures if you can. Very important to know just how deep these scratches are. Little damage can be worked out. Deep scratches cannot. What engine model? If its a ABN piston+sleeve set I can tell you now TOSS IT. Feel free to ship the set to me and I will consult with you fallowing initial inspection.
Call me tomorrow if you wish delt with more personal
RayAracing
RayA is offline
Old 09-09-2010 | 12:26 AM
  #381
boxhead's Avatar
Hope to be sending some business your way soon.
I have 2 sets of MG66 that require repinch, I have put the question to other club members and will see if anyone else wants to add to combine for better postage deals.
These will be coming from Alice Springs, Australia.
When sending, do you need a note advising what model engine the sleeves are from?
boxhead is offline
Old 09-09-2010 | 04:47 AM
  #382
Boxhead,
Your return shipping from Orchard Park New York here is described below. I can fit many sets as you like in the little box I use.
Just note on my order form engine models sending and mark each piston+sleeve set 1,2,3 and so on.
And also please pay extra attention (talk to your guys) as to the "Prefered Tightness" you sellect. Light-Medium is the most prefered with my repeat ccustomers. Your the boss. I can tighten and loosen these babies any which way you like
Feel free to email me with any further questions and concerns
Priority Mail® International Small Flat Rate Box*
Maximum Value for Contents: $400.00
USPS Supplied Small Box: 8 5/8" x 5 3/8" x 1 5/8".
Maximum weight 4 pounds. 6 - 10 business days $14
RayA is offline
Old 09-09-2010 | 03:10 PM
  #383
Timmo's Avatar
RayAracing
okay,I will take some pics and post it here so you can decide if they are worth sending in.I have several piston/sleeve that I want you fix.The engines are the old GRP/Ninja MR28MO1's..
Timmo is offline
Old 09-13-2010 | 02:41 PM
  #384
Default Monday at the farm
Any questions guys please feel free to call. Close to the phone and laptop thru tomorrow evenning.
RayAracing
RayA is offline
Old 09-15-2010 | 07:58 AM
  #385
Hi Ray, What is the recommended break-in procedure for a medium pinch. Thanks.
JoeC is offline
Old 09-15-2010 | 10:03 AM
  #386
Default Posted by Monty a few pages back
Theres re-breakin method on my website but here is what Monty recomended a few pages back and he has re-broke in quit a few sets
houston
Trader Rating: 63 (100%+)
Originally Posted by Greenlee37
when these come back from a service, do they need to be broke in the same as a new motor? had a buddy call me tonight asking this question, and I wasnt exactly sure so thought Id check here...
Preheat before starting to a temp of at least 180 , I use competition heat engine warmer and it works awesome .
Perform 3 x 5 min idle sessions (heat cycles) on the starter box at 190-210 with head covered
Let cool between each cycle with piston at bdc
Then run 3 x 10 min sessions of running the car on the ground without head wrapped , body on the car just slightly rich of race tune at 190-210 . Be careful as not to over rev the engine , after this go racetune it on the track .
Be sure you richen up your needles a bit before starting engine back up . If you are running novarossi and you get lost on your needle settings I can give you a good starting point , just get a hold of me
Any questions call me....still knee deep here in packages
RayA is offline
Old 09-15-2010 | 04:21 PM
  #387
Default Worked my 40 hours already this week
Michael,Niels,Jarmaine,Brian,John,Martijn,Sam,Bud, Jason.Monty,Ken,Timothy,and John arrived Saturday-Monday ,serviced and shipped Yesturday. Marty,Taylor, Brandon, and John here today serviced and return shipped Today. Turnaround time better the second group of guys but everybody got accuracy You youal should see good performance results.
Time to work on my Buggy ......ROOOOOOUGH
Thanks guys!!!!
RayAracing
RayA is offline
Old 09-15-2010 | 05:56 PM
  #388
thank ,been using you since i saw that article in the mag, great service.
maybe one day i'll get the nerve to buy your machine to have my own personal one. but your service is so convient.
jmoneym is offline
Old 09-16-2010 | 05:07 AM
  #389
Default ExtremeRCcars magazine December 2005 issue
ExtremeRCcars magazine December 2005 issue was the story on RayAracing. Puts you as a repeat customer close to 5 years. Very nice.....Thank You!
RayAracing
RayA is offline
Old 09-16-2010 | 09:11 AM
  #390
Default Off Tomorrow, Sat and Sun
Work thru early evenning
Packages from Mark, Jason, Bradley, and John just arrived and on the bench now.
Here today to answear any question online or by phone
RayAracing
RayA is offline
