Like Tree1Likes
Sirio engines thread
Old 05-19-2004 | 03:55 AM
  #301
suntok2's Avatar
Default Re: Pipes for a Evo2 5port
Originally posted by gentleman81
any suggestions for a pipe to go with a evo2 5port, smaller parkinglot track, can be slick at times 70-90 straightaway and a very quick twisting (everchanging) infield. MTX 3 is the car.
Use the sirio inline pipe for your mtx3 if your track is very small but if you have long track use rdlogic turbo2 in line pipe.
suntok2 is offline
Old 05-19-2004 | 05:22 AM
  #302
afm's Avatar
afm
Originally posted by InitialD
afm, do you know if the engine used at the Pre-Worlds in Brazil feature AAC or ABC sleeves? The one you posted is ABC.
From my sources, the engine used was an Evo2 3 ports ABC, using 16% Nitro fuel at 7% oil (70% synthetic and 30% Castor).
The one I posted, is to help "Gentleman81" who is looking for a 5 port engine on the $200 (tops) bracket.
AFM
afm is offline
Old 05-19-2004 | 05:31 AM
  #303
afm's Avatar
afm
Go with the Novamega TPO4, Part Number 2183.
It is been used succesfully by Uriah Murnan on his moded Sirios.
AFM
afm is offline
Old 05-19-2004 | 02:55 PM
  #304
xluis's Avatar
For Sirio EVO 2 trp pro E, is a 3 port motor. What is best, the tp03 or the tp04, mega pipes? I have a Sirio inline pipe and work very well, but i hear this pipes work well, too and are more heavys.
xluis is offline
Old 05-19-2004 | 03:01 PM
  #305
afm's Avatar
afm
Luis
Las dos Megas van bien, solo que depende del circuito, La TPO4 es mas tirada hacia los bajos, la TPO3 es mas completa dando una curva de potencia mas plana si resaltar tanto los bajos o las altas. Depende mucho de la pista y las relaciones que usas.
AFM
afm is offline
Old 05-19-2004 | 03:06 PM
  #306
xluis's Avatar
Ok, muchas gracias.
He pedido un tp03, para probarlo, este fin de semana.
La semana siguiente voy a correr el Nacional, es un circuito medio, los desarrollos que uso en el 710 son 17-22, 61-57/56.
xluis is offline
Old 05-19-2004 | 03:13 PM
  #307
afm's Avatar
afm
Ok, muchas gracias.
.............. es un circuito medio, los desarrollos que uso en el 710 son 17-22, 61-57/56.
Cual es la relacion interna de los diferenciales del 710???
A que le llamas circuito medio?? Cuanto tiene de recorrido y que tan larga es la recta principal??
AFM
afm is offline
Old 05-19-2004 | 04:28 PM
  #308
gentleman81's Avatar
AFM
not quite $200 tops but around that $250 at the most for a stock motor, alot of modified motors i have seen run a little touchy?
gentleman81 is offline
Old 05-19-2004 | 04:45 PM
  #309
afm's Avatar
afm
Have you seen Murnan Modified Sirios? they go for $250.00
http://murnanmodified.360k.com/
Barry baker runs them quite succesfully, and Uriah really knows this engines inside out. Why don't you speak with him, he'll give the best advice for your money.
AFM
afm is offline
Old 05-19-2004 | 04:47 PM
  #310
i will check them out!
Old 05-19-2004 | 06:40 PM
  #311
Default Re: Re: Pipes for a Evo2 5port
AFM
where can i get a novamega pipe?
Old 05-19-2004 | 07:37 PM
  #312
afm's Avatar
afm
Default Re: Re: Re: Pipes for a Evo2 5port
Any Serpent dealer must have it or can get it.
Try www.atomichobbies.com
AFM
afm is offline
Old 05-19-2004 | 07:41 PM
  #313
wow they have all the pipes listed good site thanks
Old 05-20-2004 | 06:36 AM
  #314
alana07's Avatar
AFM
side track a bit here, anyone tried a TP04 pipe with a nova engine before? how's the performance? thanks.
alana07 is offline
Old 05-20-2004 | 07:05 AM
  #315
xluis's Avatar
AFM
El ratio interno es 1.875.
El ratio final equivale a: 17-61=6.72
22-57=4.85 22-56=4.77
El circuito tiene unos 200-230 m. de cuerda. La recta no estoy seguro, pero esta sobre 60-70 metros.
xluis is offline
