Like Tree1Likes
Sirio engines thread
Old 08-25-2008 | 01:51 AM
  #2371
Wanabrc's Avatar
How does a CL7R compare to the old Collari WCR.21 limited edition motor?
Wanabrc is offline
Old 08-25-2008 | 03:21 AM
  #2372
Grassy's Avatar
Originally Posted by Scott Fisher
George I don't know if all the CL7R's are ABC, but I know they come as ABC, not AAC. The STI version is the AAC.
100% right
S21CL7R - ABC
S21CL7RSTI - AAC
Grassy is offline
Old 08-25-2008 | 11:12 AM
  #2373
Originally Posted by Michael P
all the cl7r's are AAC i believe
Michael: I know that you are incorrect. I have been offered some CL7R's that are ABC. I just didn't know if they all were ABC or if they were both ways. It seems that the non STI's are ABC and the STI versions are all AAC. See the other post right above me.
Scott Fisher is offline
Old 08-25-2008 | 03:11 PM
  #2374
Michael P's Avatar
Originally Posted by Grassy
100% right
S21CL7R - ABC
S21CL7RSTI - AAC
I have both the CL7R and the CL7R sti and they are both AAC. I know the CL7B's are ABC.
SIRIO'S motor line up for on road 21s are CL7R (AAC), Cl7R STI (AAC), RR STI (ABC), S21 WCR (AAC), S21 P (ABC), S21 RR (ABC), S21 RE (ABC), S21R (ABC).
Michael P is offline
Old 08-25-2008 | 07:54 PM
  #2375
GMartinez's Avatar
+1 Mike is right the off-road line are ABC the on road are AAC
GMartinez is offline
Old 08-25-2008 | 07:57 PM
  #2376
GMartinez's Avatar
Scott the 1st line that came to Kyosho were AAC & just like Mike I got 1 of each from the 1st delivery reg version & STI
Old 08-25-2008 | 10:56 PM
  #2377
George/Michael
PM sent
Old 08-27-2008 | 11:34 AM
  #2378
duneland's Avatar
I am in need of a rear bearing for a Collari .21 engine.
I believe the one I have is the same one mentioned above, and has a Sirio counterpart. It was sold with a wooden box and has the alum sleave with heat sink fins, that bolts to the crankcase. The rear bearing is an oddball size;
14.2 X 25.3 X 6mm with a 6.3mm wide inner race (extension on one side).
Anyone know of a source?
duneland is offline
Old 08-28-2008 | 05:02 PM
  #2379
Michael P's Avatar
Here you go i think this is what you are looking for.
http://www.amainhobbies.com/product_...ducts_id/20515
Old 08-28-2008 | 06:15 PM
  #2380
duneland's Avatar
Thanks. Not too crazy about it being ceramic though..
duneland is offline
Old 08-28-2008 | 06:19 PM
  #2381
Michael P's Avatar
http://www.amainhobbies.com/product_...ducts_id/12410 this is non ceramic
Old 09-02-2008 | 11:43 PM
  #2382
Grassy's Avatar
Ceramics are really good, less wear as well as a smoother with better tolerances under racing conditions ive been using them in my sirios this year and the only bearing problems ive had are with a front one in an evo4 which was a steel bearing replaced both and havnt had a problem yet "knock on wood"
Cheers
Chris
Grassy is offline
Old 09-03-2008 | 08:20 AM
  #2383
duneland's Avatar
I have never had a ceramic bearing hold up in ANY application, for more than one race day! Have heard many similar reports in engine applications. I won't chance it.
duneland is offline
Old 09-04-2008 | 12:36 AM
  #2384
blown sv's Avatar
i agree with grassy , we both drive sirio powered cars in aus and ive run ceramic bearings (genuine) in all my sirios and they have lasted 2/3 times longer
blown sv is offline
Old 09-04-2008 | 04:07 AM
  #2385
grub's Avatar
i run ceramics in my sirio and have never change a bearing
while my cheaper mate's dont run ceramics and had to change
2 set off bearings mainly the frount this season
grub is offline
