Like Tree6Likes
Team Orion Engines
Old 02-15-2011 | 09:40 AM
  #571
kdol8's Avatar
What pipe is everyone running on the ABI 3 Port? I currently run the 2013 and it has a little to much bottom looking for something a little softer any suggestions.
kdol8 is offline
Old 02-15-2011 | 12:07 PM
  #572
2058
transplantlife is offline
Old 02-15-2011 | 06:17 PM
  #573
pitpop's Avatar
what he said ^^^^^^^^^^
pitpop is offline
Old 02-15-2011 | 10:16 PM
  #574
team316's Avatar
Questions?? Orion Alpha ABI 3 Port
I have my new engine and I am setting up the clutch bell. How much back and forth play should the clutch bell have? The Mugen 6T kit has a bunch of shims but dosn't say how many or how much play there should be. Should there be a shim or two between the inside clutch bell bearing and the clutch retaining nut? In my simple brain the bearing should ride against a shim instead of the edge of the clutch retaining nut.
I am also looking for some more detailed instructions on properly sealing up the carb.
The only complaint I have after buying the NEW Team Orion ABI 3 port engine and a NEW Team Orion 2013 tuned pipe is not one sticker came with either item for my truck body.
Thanks in advance.
team316 is offline
Old 02-16-2011 | 08:52 AM
  #575
pitpop's Avatar
Thanks in advance.
Just the tiniest click of play should exist on the clutch bell. Basically the smallest amount of play you can get, while still having any play at all, does that make sense? You are correct, the bearing should run on a shim on both sides, not against the nut. No stickers? Where do you race? Hopefully you can get some stickers at the track. There should be a sticker sheet in the engine box, no?
Take your time sealing the carb. Thick grease on all the o-rings, and a small zip tie around the dust boot. If you move the bango fitting, you should use sealant on the washers before you tighten it back up.
pitpop is offline
Old 02-16-2011 | 11:44 AM
  #576
pitpop~ what engines are you guys running in truggy. i was looking at the .24 and the 7 port but dunno.
Thanks,
Andrew
Old 02-17-2011 | 10:03 AM
  #577
pitpop's Avatar
Thanks,
Andrew
Honestly, I would run the 7 port. Just as much power and much better on fuel than the 24. The 7 port is race bred and the 24 is really just out there for the guys that want a big number on the head.
pitpop is offline
Old 02-17-2011 | 05:28 PM
  #578
trickedout's Avatar
any news updates on when the discovery combo will be in stock??
trickedout is offline
Old 02-17-2011 | 08:28 PM
  #579
team316's Avatar
Thanks Pitpop. Your help has been indispensable! I did move and seal up the washers. Should I pull the different needles and grease the o-rings on them too or no?
BTW, I tore the boxes apart looking for stickers and nope, no stickers.
All in all, Orion has a great looking product and you represent them well! Very pleased with my purchase and I haven't even fired it up yet! I cant wait to tear up the local track!
team316 is offline
Old 02-18-2011 | 10:49 AM
  #580
kdol8's Avatar
My LHS called me and said they are available
kdol8 is offline
Old 02-18-2011 | 01:49 PM
  #581
pitpop's Avatar
Thanks for the nice comments yes, you can carefully take out the needles and grease the outer o-ring
pitpop is offline
Old 02-18-2011 | 03:33 PM
  #582
what do you seal the fuel inlet washers with?
debo179 is offline
Old 02-18-2011 | 09:22 PM
  #583
pitpop's Avatar
I use permatex form-a-gasket, being VERY careful not to get any on the bango fitting itself when putting the washers on. If you get any goop in the holes on the bango, it's not good. Some guys use black silicone adhesive, which is also made by permatex. Either of those work. I like the form-a-gasket because it doesn't harden. If you want to clean it off it's pretty easy.
pitpop is offline
Old 02-19-2011 | 04:06 PM
  #584
Mugen racer123's Avatar
i just broke in a new MTE today, I ran it on the track for about 4 tanks and 5 brakein tanks. I got the temps at 230 at the most. Was just wondering if i still need to pre heat it before i run it or no?
Mugen racer123 is offline
Old 02-19-2011 | 04:49 PM
  #585
trickedout's Avatar
Pre-heating is never a bad thing as it will help get your tune quicker and less strain on the rod..Me personally i like to pre heat my motors at least for the first gallon, although i dont think its always needed...If you cant turn the flywheel over by hand then i strongly suggest you preheat it until you can...
