Like Tree6Likes
Team Orion Engines
Old 12-27-2010 | 09:48 PM
  #406
fleggasaurus's Avatar
Thankyou for the reply pitpop.
I will be looking for an orion alpha 5 port piston and sleeve set on my next parts purchase.
I was taking the back plate off to perform after run maintenance but unfortunately I had forgotten to make sure the piston was near tdc and unfortunately when I forcefully pulled off the back plate, I tore the longer edge of the piston off because the bottom of it had been in the groove of the back plate. The piston top surface has not been damaged but is missing its "Skirt" if you can understand that???
Thanks again.
Brendan
fleggasaurus is offline
Old 12-28-2010 | 02:24 PM
  #407
GM
Originally Posted by pitpop
That's a great idea. We've been planning on doing that for awhile, but never seem to find the time. I'll work on it, but can't promise how quick I can get it done. I use Mugen super grease on Cody's stuff, but I know that is near impossible to get any more as they discontinued it. I'm looking for a substitute that is easier to find.
I think this is the grease you're talking about it
http://www.amainhobbies.com/product_...r-Joint-Grease
GM is offline
Old 12-30-2010 | 06:04 PM
  #408
setanborneo's Avatar
hi pitpop,i am from indonesia
what type best plug for the orion truhe edition engine use?
because only the os plug in Indonesia are sold on the market
thanks
setanborneo is offline
Old 12-30-2010 | 08:37 PM
  #409
pitpop's Avatar
That's not the same stuff. The Super grease is in a tube and it's black. Pretty much like half way dried JB weld...
pitpop is offline
Old 12-30-2010 | 08:39 PM
  #410
pitpop's Avatar
thanks
the best plug for team orion engine is team orion plug, #5 & 6... if you must use the OS plug, then the P4 is preferred... the p3 is not strong, if the engine even runs lean for one run, you need to change it
pitpop is offline
Old 12-31-2010 | 02:55 AM
  #411
thanks pitpop
Old 12-31-2010 | 06:53 AM
  #412
ScottyM's Avatar
Hey PitPop, have you and Cody had much of a chance to run some of the cheaper "budget" engines yet?? I know Cody and you both have been really busy since winning the Worlds, but I remembered you saying that you had plans to do some testing on the lower priced motors..
ScottyM is offline
Old 01-02-2011 | 02:51 PM
  #413
criss2115's Avatar
last year I ran AE RC8T w/OS25xz, wasn't all that happy with the durability of the os and previous os engines I had in the past. I am looking at the Orion mills for 2011. I was thinking the .21abi 7 port or the .24abi 5+2 port motors. These both are quite expensive mills. Please give me feedback on ave. run times and comments on which to use and why. Please help me make up my mind. I generally race every weekend April to Nov.
Thanks in advance.
criss2115 is offline
Old 01-03-2011 | 12:16 PM
  #414
pitpop's Avatar
Thanks in advance.
The 5 port engines are plenty for buggy. We ran 7 port in Colorado because we were at 7000'. Normally the 7 port is a little much for a buggy. For truggy the 7 port is the way to go. Durability wise, you can't get much better than a Team Orion engine. If it's cared for properly and doesn't suck dirt, it will run a LONG time. The quality is second to none, especially with the new piston material and crank case on the WC edition engines. If set-up properly and with the proper fuel and such, the 5 port will run 10 minutes without too much trouble. Longer on high bite smaller tracks.
pitpop is offline
Old 01-03-2011 | 12:18 PM
  #415
pitpop's Avatar
Not yet, but we have one ready to break in and run.
pitpop is offline
Old 01-03-2011 | 02:44 PM
  #416
criss2115's Avatar
Thanks pop
Old 01-03-2011 | 03:14 PM
  #417
halfman's Avatar
What is the normal life span on these engines?
halfman is offline
Old 01-03-2011 | 04:33 PM
  #418
I picked up one of the Alpha .21 5 port ABI engines today. Gunna wait till my Orion MTE quits on me before i really start running it though. Apparently it has ceramic bearings and all that jazz. Overall its typical looking orion quality and if it runs like my crf's do (not expecting the power, but the reliability, longevity, and easy tuning) it should be a winner at right around $200.
Attached Thumbnails Team Orion Engines-img_0350.jpg   Team Orion Engines-img_0351.jpg
RePeTe is offline
Old 01-03-2011 | 04:57 PM
  #419
j_blaze14's Avatar
a buddy of mine bought a 3 port abi used with 6 gallons and it looks and feels like it has 2.
j_blaze14 is offline
Old 01-03-2011 | 05:52 PM
  #420
ScottyM's Avatar
Thanks Paul, I look forward to hearing the results..
BTW I hope it is soon, cause I am about 3-4 weeks from ordering a motor, and am down to Orion or Werks..
ScottyM is offline
