Team Orion Engines
#1793
What temperature range does the orion engines run at I have done around 12 tanks now through the engine in the 9th tank I started leaning it out and jumping it and temps around 210-215f I kept it at the same setting till the 12th tank It does not scream when in the straight section it seems like it wants to be leaned out and still can not clear the triple jump. It is slightly rich from race tune I think. Should I race tune it and till what temp can I get it up to which is safe? 260F ?? 250F ?
#1794
What engine would you suggest? A lot of racers at my local track use orion engines and they love them , not even a single broken heatsink head, not even a case and holds the tune perfectly and has plenty of power. I had an alpha plus engine and it cracked after 6 gallons.
#1795
Also heard good things about the FX engine.
#1798
#1799
Yesterday i got my RS edition, nice looking engine, the cooling head is bigger than previous versions, silicone filled crankshaft.
Started to break it in on the hudy beanch, it took me some more time than i expected, the piston comes very tight, i had to time for run 7 tanks.
Today i will run 1 more on the bench and then put it into the car.
6Likes
