RB Concept Engine Thread..
#781
I found the piston that let go in my beloved C6BBT7. The engine was bought used with ceramic bearings on Ebay for $150, engine ran great for over a season. I don't run me engines lean, it just let go on a small straight without warning. Im not complaining It was one of my best engines, I miss her.
I think the rod is still good!!
#784
RB did loose their US rep recently and are getting the situation fixed. If you want an RB try this guy, he always can get me any RB stuff I need.
http://www.acehardwarehobbies.com/
I've been using RB for years & every time I try something else, I'm disapointed & go back to RB. If your track is small the S5 is my favorite. For big tracks both the WS7III & the C6 are great. I like the C6 with a 2045 pipe the best on big tracks. If your on a budget & have a medium to large track I recomend the regular S7. For me If you told me I could only buy 1 motor & had to run it on every track I would pick the regular S7. These motors last a long time if you take care of them & keep them tunned properly. They are easy to tune (especially the S motors). Please, if you get an RB, run a good pipe on it. Pipes make all the difference on performance. For me, I like the 2045 pipe for racing with the C6. Great power & fantastic fuel economy. For track bashing & practice I like the 2020 pipe but it has worse fuel economy.
I'm not an employee or affiliated with RB Concepts in any way.
#785
Rb 2045/192 should do the trick
Also
RB has had a new USA rep for over a year and they are in full swing.
Also
#787
The WS9 is always going to struggle a little bit in truggy. This engine was designed as a buggy racing engine in a way that the bottom end would be very smooth and controllable in a buggy, not to mention it was designed for Euro tracks where high corner speed is a lot more common and 180 degree turns right in front of jumps are rare. The way it delivers power leads most people to think it has no bottom end. There are several ways you can make the engine feel a little more snappy. To start.. what is the gearing on the truck?? A nitro motor is no different than an electric motor, if you don't gear it proper it's going to seem to lack power and probably run hot. If you are at 48 on the spur try going up to 50. Also you want to make sure your clutch is more on the heavy side, with a WS9 you want that thing to spool up as much as possible prior to engaging the clutch. As for pipe/header you should be using the 198 header no matter what and the 2020 pipe will wake up that engine even more. The 2045 may also work well for you if you have the gearing and the clutch in the sweet spot.
More than anything the gearing is going to help you, I run the WS9 only in buggy but I race at high altitude where we loose about 20% of the overall power of these engines. In a Losi buggy that comes stock with 13/48 gearing I run 13/50. This gives me the great bottom end needed for big jumps with short run ups as well as plenty of top end on 180 foot straights. I have tried 12/48 gearing and that was a little too dramatic as it was full song less than half way down the straight.
[QUOTE=JonnyW;6689589]
What pipe does your friend use to get the most BOTTOM END out of his "WS-9"? I also have mine in a truggy, but it seems that the "punch" isn't there.
I have a lot more punch more bottom-end & more control speed out of a low end 3-port engine, don't get me wrong, the WS-9 is a bad ass engine... and I love "RB" motors. Just a little stumped
on tuning of this bottom-end.
It's not a fuel tune issue... I believe it's about finding the right pipe!
I've tried the, RB-2045, JP-2 & the AE-2035.
Any help would be awesome, Thanks, T.[/QUOTE
Maximo-aaronjoy are right you need to a different motor. I have a beast of a C6LG2 with MX ceramics that has all the bottom end you could ever need. I run a XB808 and it is just too much!!! The rear end was all over the place no matter how I tried to lay off the throttle. I need to sell or swap it for a buggy motor.
on tuning of this bottom-end.It's not a fuel tune issue... I believe it's about finding the right pipe!
#788
I just got into the hobby! not racing yet but getting close. we built a track we are practicing on. I have a buggy and a truggy both with the older version of the S7! they both scream. both engine were bought used and i have gone thru 3 gal. of blue thunder 20%. without a problem. Iam running jp1 and jp2, and werks clutches. any Ideas would be appreciated or other engines I should try! reliable as the s7
#789
#790
#793
I found the piston that let go in my beloved C6BBT7. The engine was bought used with ceramic bearings on Ebay for $150, engine ran great for over a season. I don't run my engines lean, it just let go on a small straight without warning. Im not complaining It was one of my best engines, I miss her.
Regards,
Ashton
#794
Try to get in contact with them before you send it in. My buddy sent in two 523 revo engines because of cracked cases. They took care of him with two rebuilt engines with new cases.
Try calling them, you should be able to get a hold of them since there are two guys working there now.
#795
Anyone know what the correct shimming would be. I am at .75 right now. I am wondering because I ran this weekend real hot even though I was blowing good smoke. I know RB run hotter than most but the high 200s were scaring me. But if I fattened it up it ran like a tird. The LSN seemed right. The air temps were low 40s. I ran Oddonnels 30% w/97t- 2045/198. Pulled the motor down-looked good. The usual browning from O fuel - just light carbon to exhaust port- plug looked good.
2Likes
