Like Tree2Likes
RB Concept Engine Thread..
Old 11-14-2009 | 05:14 AM
  #691
hambone's Avatar
Originally Posted by aaron joy
Sounds like whoever you got the engine from changed the shims along with the crankcase timing. LOL
I'm not positive but I think it would be like any other RB C6. Two shims both the same color. One .1 and one .2, shimmed for %25 nitro.
Thanks Aaron. Got it back together. Tore all the grass outta my backyard. It's a bottom end wheel standing monster.
hambone is offline
Old 11-14-2009 | 07:22 AM
  #692
aaron joy's Avatar
Originally Posted by fpart
Hey Aaaaron or anyone! Does anyone have experience with the Shark9. After blowing up my Trinity Extech (I can't complain about it since it gave me over a year of running), I just ordered one. How are they??
Hello Tom,
I actually have a Shark9 that I am breaking in for Ofir. It looks to be a very nice engine.
aaron joy is offline
Old 11-15-2009 | 04:17 AM
  #693
Default Headbutton cutout?
Originally Posted by hambone
How many head shims for the C6 USA edition? I bought one used and had it pinched. Not sure if one got lost in the shuffle as mine only has 2, a thicker alum shim and a thinner copper shim. It has the head button with the cutout on the exhaust side. Talk to me Aaron!
could someone post a pic of the C6 us head button with the relief/cutout on the exhaust side? Thanks
JonnyW is offline
Old 11-15-2009 | 12:13 PM
  #694
can anyone tell me a cross reference for a ws7III rod? i am having a hard time finding one.
bigred0988 is offline
Old 11-15-2009 | 02:54 PM
  #695
JPMSRacing's Avatar
R/C Tech Elite Member
From: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
If anyone is interested, $165 plus freight, this engine has a new TKO front bearing and new conrod, the engine had almost a couple gallons ran through it and then the new bearing and conrod was installed. After the bearing and conrod installed ran once in a borrowed truggy to make sure it ran good and put away for a spare. The clutch is not included.
Attached Thumbnails RB Concept Engine Thread..-dsc04402.jpg   RB Concept Engine Thread..-dsc04405.jpg   RB Concept Engine Thread..-dsc04408.jpg
JPMSRacing is offline
Old 11-15-2009 | 06:06 PM
  #696
aaron joy's Avatar
Hello Bigred,
The rods are all the same for the "S" and "C" series.
It is a beautiful thing!!
Old 11-15-2009 | 06:17 PM
  #697
I may be wrong but I remeber seeing on RB's parts list that just about all thier motors but the C6(squarer stroke?) use the same part # con rod. As far as another brands fitting I have no clue. I wish someone could find a replacement rod for GRP.
JonnyW is offline
Old 11-15-2009 | 06:51 PM
  #698
aznitronut's Avatar
The RB conrods .21 are all the same, including the C6, the new 9 series are the same conrod also, the killer 9 is not the same conrod.
aznitronut is offline
Old 11-15-2009 | 07:11 PM
  #699
ok thanks alot for the info guys.
Old 11-16-2009 | 10:57 PM
  #700
Can I get some opinions on putting a killer 9 engine in my mbx6t w/ an rb 2045 192 exhaust set up. Seems to have a good price for what it is.
Inertia is offline
Old 11-17-2009 | 06:49 AM
  #701
aaron joy's Avatar
It will be awesome! My Killer 9 in my 8ight T 2.0 with 2045/192 pulls just as hard as my C6 BBT7 with a little more top end. I get about 10 mins on a tank and after 2 gallons I still have a ton of pinch. I encourage my fellow racers to try my truck on race days during practice just so they can feel the smooth power of this engine. It will be my next back up engine for sure!
I run it with 25% Byrons Pro and OD97T, temps are so cool I don't even check anymore. Engine holds a very consistent tune as well.
Old 11-17-2009 | 09:59 AM
  #702
plus2ss's Avatar
Default Hobby 9 carb settings
Hi ive got a RB H9 with a couple gallons on it. I recently switched fuel and now it seems my needles are off, like almost a full turn. I just need base needle settings to get me back to factory setting. Thanks.
plus2ss is offline
Old 11-17-2009 | 10:45 AM
  #703
aaron joy's Avatar
Base settings are 3.5 turns out on the high-end and 5 turns on the low end needle. Don't forget to reset your idle screw before you start tuning.
What fuel did you switch to and from?
Old 11-17-2009 | 01:13 PM
  #704
plus2ss's Avatar
The first 2 gallons were sidewinder, im now using nitrotane and im deffinetly switching back to sidewinder or odonnell once im done with this gallon. It took a full turn on both needles just to get it the ballpark.
plus2ss is offline
Old 11-17-2009 | 01:51 PM
  #705
blktransam's Avatar
metal pinch after 2 gallons?.....or COMPRESSION?
blktransam is offline
