Like Tree2Likes
RB Concept Engine Thread..
Old 04-15-2015 | 06:02 AM
  #3601
Yes. It still has lots if mechanical pinch.
Jamie James is offline
Old 04-15-2015 | 06:39 AM
  #3602
The most important thing is to keep the engine above 200. I would lean on both needles until you have a clean bottom end then what you need on top. You can put a descent tune on it so it is raceable without hurting the engine
Chris Reilly is offline
Old 04-15-2015 | 06:42 AM
  #3603
aznitronut's Avatar
With temp guns, I have used exerted temp guns, since they came out, with the guns most people are using now, they will be most accurate on temps up to around 250, compared to other brand temp guns start showing larger temp ranges when the temperature is getting hotter, other brands may show 290, and the exergen temps will show 270.
aznitronut is offline
Old 04-15-2015 | 12:18 PM
  #3604
I will be putting more fuel through it today after work. Just going to run it in a parking lot and tweek it a bit.
Old 04-15-2015 | 12:32 PM
  #3605
Remember though, when you tune on a parking lot, temps will generally go up when you run it on a track with those same settings... (and even more up if you run it for ex. on grass...)
Herrsavage is offline
Old 04-15-2015 | 12:35 PM
  #3606
For me it is Exergen or nothing. I do own a Raytek, but I don't trust it. I always borrow a friends exergen to verify my temps. If the battery is new my raytek is pretty good. If my friend is there I don't even get mine out. He has a older one and a newer one.
Old 04-15-2015 | 03:08 PM
  #3607
I'll be running it tonight just to put more fuel through it more than anything. It needs it. I'm at the 1/2 gallon mark if I'm lucky.
Old 04-23-2015 | 03:09 PM
  #3608
allaboutwho02's Avatar
Ive got a Murnan mod RB M5x with a 2097 and med header in a truggy. This thing has loads of bottom end. Is there a better pipe to smooth it out?
allaboutwho02 is offline
Old 06-21-2015 | 06:28 PM
  #3609
jhold87's Avatar
Default BX-R
I have a older style bxr that has a scratch on the piston and sleeve but it still runs. I really like the engine but with rb closing I'm sure parts are about to get slim. Do any of you guys know if there is a p/s/r from a novarossi that will interchange? Thanks in advance.
jhold87 is offline
Old 06-21-2015 | 09:03 PM
  #3610
aznitronut's Avatar
Did you try Amain yet?
Old 06-22-2015 | 08:25 AM
  #3611
jhold87's Avatar
Default bx-r
Yeah but they didnt have p\s\r combo listed maybe ill just run it until its worn out and get it pinched and keep it as a backup.
jhold87 is offline
Old 06-22-2015 | 08:31 AM
  #3612
aznitronut's Avatar
If your in doubt of anything with your engine, contact Rcrenew.com, Lance can do wonders with engines, he is a good guy, and really knows his stuff on engines, he won't talk you into something you don't need, and fast with his work and returning your items, check him out on line.
Rcrenew.com
Old 06-22-2015 | 01:01 PM
  #3613
This P/S/R will fit your engine. http://www.amain.com/rc-cars/rb-prod...147-33/p266655
kyosho28 is offline
Old 06-22-2015 | 03:46 PM
  #3614
aznitronut's Avatar
I just saw I miss-spelled Exergen, or spell check did, lol
here is a good one for you, do you know who designed and help develop the Exergen temp gun? It was a man that was, called, Ron Peris, I'm sure you know who is, if you been into RC for quite awhile. The main guy from Exergen was telling me about this not to long ago, I got the temp guns like most everybody uses now when that first came out in about 2002, and since, even bought another a few years ago, there the best.
Old 06-22-2015 | 09:52 PM
  #3615
jhold87's Avatar
Default BX-R
Originally Posted by kyosho28
Thanks bud not sure how I missed that I was on amain for 30 minutes last night looking at rb parts.
jhold87 is offline
