Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Rw modding and engine rebuilding >
Like Tree28Likes
Old 03-15-2009 | 09:02 PM
  #31
22Racer's Avatar
Kendall ran my newest 5 port Go last weekend. He said it out pulled everything, even at a small indoor track.
It has a lightened and polished crank and some timing changes for more rpm.
$240.00 for a new one
Rex
22Racer is offline
Old 03-16-2009 | 09:38 PM
  #32
22Racer's Avatar
09 prices and services
piston and sleeve pinch $15.00
Motor rebuild $35.00 return shipping included to Us. on both
Basic mod $40.00 crank and sleeve blending and timing adjustments
full mod $50.00 includes crank lightening and epoxy ramp
Discount when rebuiding and modding, I will mod a used motor but the crank and rod can not be worn much.
Rw 5 port $240.00 epoxy ramp crank, mod, and timing adjustment per customer needs. Any shims added for timing can be removed to make it back stock again!
Rw 3 port sport $145.00 This sucker kicks butt, and it's a sleeper!
I will pre set needles on all motors for break in if wanted. I will tell you how to shim it after break in. I will also rebuild motors I sell at a discount.
Rex
22Racer is offline
Old 03-31-2009 | 06:58 PM
  #33
22Racer's Avatar
I am also breaking in motors now.
Prices
$20.00 extra on anyew motor I modded
$30.00 with any new Go motor bought from me
$40.00 for any other motor sent to me.
Heat cycle method on a Hudy break in bench.
I will be on Vacation in late April so there will be some delays then.
Rex
22Racer is offline
Old 05-22-2009 | 04:52 PM
  #34
looper's Avatar
to the top, when sending in the engine for pinching do i need to do anything in the way of prep to it or should i just send it as it sits?
Go 3 port sport question, when removing shims for 20% which one should i remove?
looper is offline
Old 05-22-2009 | 05:14 PM
  #35
Integra's Avatar
hey Rex i might send in the Frankenstein JPX to get a pinch....Just giving you a heads up.
Integra is offline
Old 05-22-2009 | 07:20 PM
  #36
22Racer's Avatar
When sending the whole engine just send it dirty. I dissasemble and clean it first. I do get a little annoyed with people that leave clutches on, it takes more time to take that off than to dissasemble the motor. I have been pretty swamped , I came home from last weekends race with over 10 motors to rebuild. Plus I have a couple new Go 5 ports to mod.
On the 3 port sport for 20% I would remove both brass just use the aluminum.
Nick, I'll be watching for Uncle Fester dropping the motor off.
Rex
22Racer is offline
Old 05-23-2009 | 08:39 AM
  #37
Integra's Avatar
Integra is offline
Old 05-31-2009 | 06:21 PM
  #38
22Racer's Avatar
I am starting to get caught up from the 12 motors I had to rebuild. I am now charging $15.00 to retime a stock 5 port when bought new, nice thing is you can change it back. It will smooth out a stock 5 port on the bottom and give it more top end, pretty much makes it an awesome buggy motor.
Rex
22Racer is offline
Old 06-12-2009 | 12:29 PM
  #39
22Racer's Avatar
I will be on vacation June 21 -27 any motors I get will be done the week after that.
I see some people have mailed piston and sleeves in the priority envelopes and boxes. The cheapest way is to send it in a padded envelope, probably under $2.00 from anywhere in the Us. Then I have a padded envelope to send it back in then!
Rex
22Racer is offline
Old 07-11-2009 | 08:41 PM
  #40
Wow, good prices, I may just send my LRP 28 in for a rebuild after this gallon of fuel. Still has a little pinch left, and gobs of compression so better get it worked on soon. 6 gallons of driving does a lot to an engine. Especally when you factor in 1 gallon's worth of time in free- revving due to diff issues . May I "ask" (out of curiosity) in a nutshell what you do in the rebuild, i guess you just go through, find out what is worn, fix it up, re-pinch and ship out
Calvino is offline
Old 07-11-2009 | 10:18 PM
  #41
22Racer's Avatar
I tear it down, mic the crank and I use a bore guage to check the conrod. I use a high pressure hot water cleaner to wash the motor and then check the bearings for smoothness and feel if they are loose. I clean the top of the piston and usually polish it up and use a stone and get the top of the sleeve flat. After I talk with the owner about what I feel needs to be replaced if anything I pinch if needed and do what needs to be done and ship it out.
Rex
22Racer is offline
Old 07-11-2009 | 10:21 PM
  #42
22Racer's Avatar
I will also be attending the Roar Nats next week, I will be there for support for any Go engine users and feel free to come say hi and talk motors. I will be pitting indoors near the Kyosho team, my sone Kendall will be at this pit area.
Rex
22Racer is offline
Old 07-12-2009 | 12:03 PM
  #43
Rex
Thanks, i may send in my LRP soon, seems to be maybe running a little low on pinch, still has tons of compression and runs super strong
Calvino is offline
Old 07-12-2009 | 03:27 PM
  #44
Integra's Avatar
Rex
Good luck to Kendall in Buggy and Truggy......I WISH i could be there....but the chip's didn't fall in the right place this year....maybe next....See ya round 7 in Foley.
Integra is offline
Old 07-14-2009 | 11:14 PM
  #45
looper's Avatar
Are you able to source parts for a sts engine? it is a d21e 6 gallons on it. mechanical pinch weak but compression great, thing is its still on the stock bearings and conrod.
looper is offline
