O.S Engines thread
#2776
Looks great! Pair it with a 2050 with L shaped header (Mark Pavidis) and it will be ballistic. I've also tried this combo with 2041 and had great results.
Have fun racing!
Have fun racing!
#2777
Badass engine. Still ultra competitive.
#2779
#2781
#2782
Hey every I brought a
OS Engines Max-21 XR-B Version 3 Nitro Buggy Engine and the Fuel Inlet nipple broke off on it so I checked the manual it say re placement one is a no16 but I can't found it anywhere only thing I can found is the no15 will it fit or what can I uesd as a replacement
#2783
#2784
So that will fit good then
#2785
that part you're looking for is plastic right?
that part listed should fit or just get this which includes the high speed needle
https://www.towerhobbies.com/product.../OSMG7120.html
#2786
I know I’m seeing this late but not sure if you’ve had chance to compare the 2 engines. I never ran AD2 but I ran 2104 in truck I used 85header with 2090 pipe and it was slinging truck around great. I felt it was lacking a little punch with the 2100 as I was testing on a tighter track. Large flowing track would be better with 2100 imo
#2787
#2788
i thought so too since all the good I was hearing on the 2100. There was this one double right after an almost 90* turn and unless I hit it in this perfect spot with the 2100 it was not consistent in making it clean. With the 2090 it gave it more kick that it didn’t matter so much how I hit the jump. Once tracks here in the Northeast are good to run on (soon I hope) I’ll be doing some more testing and comparing.
#2789
OS 2100 is more linear with power band compared to the 2090. It is better suited for smooth flowing layout. OS 2090 is what you need for torque paired with a heavy spring clutch setup.
#2790
I’m about to rebuild my AD2 engine. Looking for a new piston, sleeve and rod. What is the partnumber for
these parts?
these parts?
