REEDY .21 Nitro Engine
#826
#827
Well I started breakin mine in today. Had to richen it 5 full turns to get a liquid discharge out of the pipe. Also richen the bottom a half of turn. She purred for 2 complete tanks at 205-210. What are other guys needles set at for breakin. Also my kit didn't come with extra shims but I have to say. I really like those venturis and the manifold springs. I also went ahead and sealed the carb and back plate with racers edge sealer. This was just for a piece of mind. Plus I hate seeing motors with sealant all over them.
#828
Hey guys I just broke my Reedy in 3 weeks ago and this last weekend heard a strange noise out of the engine. So I tore it down and discovered that the rear bearing went bad. Anyone know if AE will do good on their engine? This engine doesn,t even have a gallon on it yet.
Chuck
Chuck
#829
#830
Chuck
Chuck
#831
I found out flush settings don't work. Need to use turns. For instance, my hsn flush is 6 turns out. For breakin my hsn is 4.25 from bottom and lsn is 4 out. I had to keep the head wrapped and the temp are around 230. I'm only on tank 4 but it still idles perfectly.
#832
NeoBuggy posted a saying "Maifield in particular suffered engine problems and having qualified poorly." This was with the older engine, in his truggy he was sporting the new engine along with Saxton and Brent.
#833
Ok I have ran 8 tanks rich with temps starting at 220-230-240-250. After the 8th tank I was about to try and race tune bit thought I would check the pinch. After idle and 8 tanks run thru it the pinch is still there. Is this the case for everyone else. Also I like the fact that I didn't have to use any shims on the clutch bell
#834
#835
