REEDY .21 Nitro Engine
Old 11-05-2009 | 08:47 AM
  #616
Scottmisfits's Avatar
Originally Posted by allan42r
not talking about pro mod,speed,ninja,mod whatever. if you think the reedy has the top end pull of a stock 3 port vzb 21 v spec, your ruler is bent. os v spec max rpms 48000. reedy? i've never seen you run a reedy with topend and or a temp below 300. the os motor pulls of the corner and keeps pulling down the straight. the reedy signs off half way down. the os 28 motor while it has lots of lowend like the reedy it does not have the topend rpms and stops pulling half way down the straight.not saying the reedy is down on ponies, it uses a smooth lowend that works very well in offroad.
I'd love to know where you're getting your number of 48,000rpm. I don't know of any engine that revs out that much.
I have used Speeds, Ninja's, and stock V Spec's. I am now using the Reedy. Using the same gearing, the Reedy is better out of the corners but does suffer a little on the top. Gear up a tooth on the clutch bell and it's a lot better. Still has that smooth bottom end power that doesn't seem to end but transitions nice to a high speed mill. Still doesn't have quite what a V Spec in stock form has, but it's darn close.
Scottmisfits is offline
Old 11-05-2009 | 08:59 AM
  #617
JoeyTheRocket's Avatar
your ruler is bent.
My ruler is bent!
JoeyTheRocket is offline
Old 11-05-2009 | 09:30 AM
  #618
Brandon thanks ! I have been doing this for years. I do realize that I don't know it all. There are things we can all learn. When you have the AE team and support behind you it makes it easier to get the most out of a product . They know these things better than I ever will. That is why I asked. Thanks and keep up the great job. I do appreciate you being on here to help.
The only thing I would add is make sure the engine is at BDC when coolng. I preheat my engine with a device a friend makes for the life of the engine. As long as there is power. It heats the engine to over 200 and I don't have to hold it. Engines keep there pinch much longer that way. It's the cold starts that are hard on these engines.
Chris Reilly is offline
Old 11-05-2009 | 05:51 PM
  #619
mattwoodcraft's Avatar
Originally Posted by JoeyTheRocket
I have both motors so I feel I can answer your question for ya. The Reedy has more top end and is much, much smoother over the v-spec. The V-spec is a faster motor too also very snappy and very easy to tune. If your a good tuner I would choose the Reedy.
thanks mate i keen to get one to try for sure i have use the vspecs as for tuning no probs thanks mate what sought of run times would i expect to be getting after run in ?
mattwoodcraft is offline
Old 11-05-2009 | 06:19 PM
  #620
Bigedmond's Avatar
I am getting 9 minutes, and i have a heavy trigger finder. I also use the 7mm restrictor.
Bigedmond is offline
Old 11-05-2009 | 08:08 PM
  #621
mgtmadness2007's Avatar
I am wanting to get a couple of these engine's and am wondering if the pipe and header combo from the GRP .28 tuned would be a good choice. I have no place to race so my best option is hopefully making it to motorama 2010.
mgtmadness2007 is offline
Old 11-05-2009 | 08:47 PM
  #622
Bigedmond's Avatar
They work fine. I was running a 2053 GRP pipe for a while, since that was all i had.
Old 11-06-2009 | 02:39 AM
  #623
pipes i already own are the 2035 pipe AE and a 2072 pipe i was going to try these pipes i know about the 2035 piupe be good but i will be keen to try the other
Old 11-08-2009 | 12:38 PM
  #624
Bigedmond's Avatar
well, last night on a small track, i did 11 minutes in truggy in a second place in the first round of the Desert Thunder Series raced. I also TQ'ed
Old 11-10-2009 | 02:37 PM
  #625
viperbill1963's Avatar
Default pipe selection
what pipe is recommended with this motor i just bought one and is looking to start a break-in i usually race on a tight and simall track to a fast medium track i have jp-1 jp-4 ofna 086 os 2060
viperbill1963 is offline
Old 11-10-2009 | 04:04 PM
  #626
i was told teh 2035 AE pipe was the go for these motors
Old 11-10-2009 | 04:17 PM
  #627
I pesonally use the factory team pipe which is a low to midrange pipe on my rc8t whith the 8mm carb restrictor. i run a 14 tooth bell and the 50&the 52 tooth spur. I race at white house hobbies the track is like 145x75? JCP which is 175 x75/ and reo raceway indoor track its like 100x45? the factory team pipe does fine on all three tracks I get 9to 11minute run times. the reedy has greate bottom end but if the straight away is over 145 feet my team mate runs the dynamite o86 top end pipe. we run the same truck and engine. gear to gear threw the middle of the track I am faster but on the long staight"s he is faster. so to answer your question on a small track use your bottom to mid pipe and on the big tracks use your mid to high pipe. the reedy can be a great engine if geard right and clutched right, in my truggy i use 1.1 clutch springs to give me better bottom end snap. in my rc8 buggy i use 1,0 springs to soften the bottom. the engine did take some getting use to,the sound of the reedy at the end of the straightaway is a little soft compared to other enginse but the speed is there.
ArronRC is offline
Old 11-10-2009 | 07:17 PM
  #628
I thought Brandon Melton said he runs the TT2039 for more top end. He may have to correct me though.
Old 11-10-2009 | 08:08 PM
  #629
fast11970's Avatar
Just breaking one in ..But right now it is getting Insane run time 12+ with an OS 2060..6 Tanks on it, not race tuned, I will let you know what it does when it has to sweat...
fast11970 is offline
Old 11-10-2009 | 08:12 PM
  #630
fast11970's Avatar
I have the 9mm in right now BTW, an its Really Fat, Seems slow on the top end,
One thing I noticed is the bottem end needle was a lil to lean for my break in style, just speakin,,cause I can.
