REEDY .21 Nitro Engine
Old 09-16-2009 | 04:30 AM
  #526
Brandon Melton's Avatar
Originally Posted by BSchorr
Mounted my Reedy 121VR in my brand new Kyosho MP9.. I see in the packaging, there is an extra head shim... There is already 2 on the motor... What have you guys been running? Ill be runnin Trinity 30%
The engine comes with a .2, .3, and .4mm shim. The .2 and .3 are already installed. The engine is ready out of the box for 30%. What I like to do is remove the .2 and add the .4 just for break in, to reduce the compression to help idle and also take load off the rod during break in. After about a 1/2 gallon of fuel, I take the .4 back out and go back to "stock" shimming which is .5 mm.
Brandon Melton is offline
Old 09-16-2009 | 10:46 AM
  #527
BSchorr's Avatar
R/C Tech Elite Member
Are the shims labeled someow with their size? I will try that out!
BSchorr is offline
Old 09-16-2009 | 11:03 AM
  #528
JoeyTheRocket's Avatar
Nope, you have to measure them. That's the only way.
JoeyTheRocket is offline
Old 09-16-2009 | 02:50 PM
  #529
Don't take this the wrong way, but get a set of $15 digital calibers from harbor freight, every racer should have set. Measure shocks, shims, head shims, among a million other things when setting up a car.
As for the shims, you can tell by looking at them if they are thinner or not, thinnest .2, largest .4mm. Use two largest together for break in, thin use two smallest together for 30% fuel race tune.
Old 09-16-2009 | 04:42 PM
  #530
BSchorr's Avatar
Im a well rounded racer.. lol I have a couple calipers..
BSchorr is offline
Old 09-16-2009 | 06:24 PM
  #531
lol, 10-4. Maybe I just assumed that when you asked if they were "labeled" you didn't have anything to measure them with . All good. Enjoy the engine.
Old 09-17-2009 | 09:14 AM
  #532
BSchorr's Avatar
What plugs is everyone deciding to run since the bastard dont come with one? I see alot of people running the Odonnel 97T... How does an OS P3 compare?
BSchorr is offline
Old 09-17-2009 | 09:34 AM
  #533
Bad idle with the P3. The only plugs everyone is using is the 97T and P4. I don't think the Reedy plugs are out yet. That's the reason the motor didn't come with one.
Old 09-21-2009 | 10:31 AM
  #534
Bigedmond's Avatar
Its official. This motor with a 16t bell in the RC8B, screams. Also, with a 14t bell in truggy is dialed.
Bigedmond is offline
Old 09-24-2009 | 09:35 AM
  #535
Have tried both JP3 and 2035 the JP sounds better and was easier on fuel then the 2035 but I would say the 2035 was more driveable powerband. Now I just have to figure out how to tune the quack out of it from low to mid funniest thing I've heard from a pipe in awhile.
Insane Nitro is offline
Old 09-26-2009 | 12:18 AM
  #536
Jason Pelletier's Avatar
My carb boot developed a pin hole somehow.... I glued a small piece of tire bead to the out side... Thought after the fact maybe should did the inside.. looks gangsta.
Where can i find a replacement ASAP !!! i got a race on sunday and i can't roll out with this in my head.
Jason Pelletier is offline
Old 09-28-2009 | 07:57 PM
  #537
datracing's Avatar
I see alot of people running the AE 2035 tune pipe. What manifold is everyone running?
datracing is offline
Old 09-28-2009 | 08:46 PM
  #538
fast11970's Avatar
P6? Its a new plug, Its what I have in it..I will let you know how it goes.
fast11970 is offline
Old 09-29-2009 | 04:48 AM
  #539
AE header also, here is a link, they have three different version, polished, black, or hardcoated.
http://www.carolinasrc.com/Webstore/...idproduct=6650
Old 09-29-2009 | 06:40 AM
  #540
datracing's Avatar
Thanks Brandon for the info and link..
I just purchased couple weeks ago Novarossi 41020 Long and 41021 Short manifolds. Has anyone used these with this engine?
