REEDY .21 Nitro Engine
Old 08-10-2009 | 06:42 PM
  #346
Originally Posted by RB FIVE
maybe the reseal job is causing the leak, maybe try it over.
I was thinking that may be the case as well.
I saw on A-mains reviews that Kurt Wenger says to seal around the outside of the carb and not inbetween the case/gasket/carb. So I may have to try that and see where it gets me.
I also have a small feeling it's just my lack of tuning experiance, causing me to have a hard time finding the proper starting point for this carb. As I'm reading a few other threads now with guys having all kinds of trouble with lean bogs or tuning issues.
porter is offline
Old 08-10-2009 | 07:14 PM
  #347
slaytanic's Avatar
Originally Posted by megasaxon
tower's price is 249.99
Tower has a $30 off 249 coupon on the front page of the site. So Towers price right now is 219.99.
slaytanic is offline
Old 08-10-2009 | 08:24 PM
  #348
Bigedmond's Avatar
I had a problem going from a GRP to the Reedy as it tunes differently. My GRP's never ran more then 190, but the Reedy likes to run above 250. My pit man gave me a oh crap look when he first saw the temp. Then he gave me the confused looked when i said 265 was fine, and the motor was running great. I get tons of smoke too.
I think the only thing i am having problems with is the warmup. It is taking me seriously 4 minutes of warmup before i can put it on the track. If i go before that, it will flame out. its odd, but i can handle it.
Bigedmond is offline
Old 08-10-2009 | 08:52 PM
  #349
SkarTisu's Avatar
Porter - Are you absolutely certain you don't have an air leak in the fuel lines, fuel filter, or fuel tank?
Edmond - Mine runs very rich during warm up too, but it doesn't take 4 minutes to get warm enough to make power. Maybe your LSN is too rich.
SkarTisu is offline
Old 08-10-2009 | 09:09 PM
  #350
wfo's Avatar
wfo
From: SO. CAL. Thunder alley, revelation raceway The Dirt -Perris RIP OCRC
239.98 after tax and shipping... 20 off
wfo is offline
Old 08-10-2009 | 09:23 PM
  #351
Jason Pelletier's Avatar
I wish i have run my engine a bit more. I could prolly give better feedback.
Jason Pelletier is offline
Old 08-10-2009 | 09:25 PM
  #352
porkchop's Avatar
i have found that if your having problem put a p4 in it
set the top and bottom and 2 and 1/2 out
and then your only a hour or two off!
porkchop is offline
Old 08-11-2009 | 06:08 AM
  #353
Put new lines on when engine was installed. Could be a fuel tank issue, but my back up engine ran ran just fine after I decided to pull the reedy, using the same tank and lines.
porter is offline
Old 08-11-2009 | 06:26 AM
  #354
Powerhouse RC makes engine warmer that runs off 110v and will warm the motor up to about 200f in about 10-15 mins. Clamp it on and come back when your up to race.
clebo3 is offline
Old 08-12-2009 | 05:34 AM
  #355
lethalleigh29's Avatar
has the airleak problem been resolved i have heard that alot of people are having trouble with the sealing of the new style carby just curious as i really want one and at the price you cant go wrong.
lethalleigh29 is offline
Old 08-12-2009 | 12:29 PM
  #356
SkarTisu's Avatar
Yup. Use a little Green Slime on both sides of the gasket between the carb and engine block, and use Loctite on the carb fixing screws.
SkarTisu is offline
Old 08-12-2009 | 12:38 PM
  #357
slaytanic's Avatar
Looks like a better design then what we have now. Hope it takes off.
Old 08-12-2009 | 01:04 PM
  #358
SkarTisu's Avatar
I'm a fan of it. No more worries about the insulation material shattering when you remove the carb from the engine block!
SkarTisu is offline
Old 08-12-2009 | 02:19 PM
  #359
Green Slime??? No gasket sealer or any other sealer?
Will have to try that out, and see where it gets me. I'm a huge fan of the design as well, just having some issues with my first go around. Hopefully I can get things worked out within the next few days.
porter is offline
Old 08-12-2009 | 02:27 PM
  #360
Haven't had a leak, so far so good. I use locktight in the screws but be easy dont strip your case.
