Trinity EXTECH .21
Old 01-10-2009 | 07:26 PM
  #1171
your bottom end needle may be too rich and your idle might be too high, I've had that happen before. Try leaning the low end needle until it stays at a high idle, then, turn the idle screw down until its at a low idle.
B_Wheeler is offline
Old 01-10-2009 | 07:29 PM
  #1172
Originally Posted by NitroOB4You
Frank, call em back sometime and ask to speak to Don. He is the one, from other forums I have read, that has been taking care of people. The "King" even suggests talking to Don. Can't get a better reference than that
thanks i email them and a ben martinez i think emailed me back and he he sending me a third new tank. i put my other new tank in and it ran fine for two tanks. so i hope this new tank is good so i can have a backup. forget the arms, shock shafts, glow plugs etc, you need a box of fuel tanks associated number one priority lol..... i still love my cars for now.
franklucas is offline
Old 01-10-2009 | 07:38 PM
  #1173
Just got it back from Chad and mine was shimmed wrong also but that was fixed. I use a P4 plug w/30% Byrons. When I try leaning the LSN to where it needs to be it constantly chatters, never going to a smooth idle. Really, with my other high end Italian mill I don't have to seal anything, does the ExTech need to be sealed everywhere? The carb seems well sealed with 2 O-rings. I dunno, maybe if all else fails.
KyJoe340 is offline
Old 01-10-2009 | 07:42 PM
  #1174
when you say chatters do you mean, it idles high?
Old 01-10-2009 | 07:45 PM
  #1175
Yes, but it's more than a high idle. It's very inconsistant, something you would associate with a lean condition.
KyJoe340 is offline
Old 01-10-2009 | 08:34 PM
  #1176
I can attest to kyjoe chattering condition. I would think a motor of this caliber would not need to be sealed but clearly somthing is wrong. It is spitting a ton of raw fuel out of the pipe yet it idles erratic and chatters on the bottom end.
nairb is offline
Old 01-10-2009 | 08:42 PM
  #1177
chickenfarmer's Avatar
mabey your LSN is rich and your HSN is very lean.
chickenfarmer is offline
Old 01-11-2009 | 05:07 AM
  #1178
kyjoe - the needle settings are for our fuel.. set hsn and lsn flush then turn them out 1 full turn. you cant run the needles the same with byrons as you can with our fuel.. Byrons has more oil..
anytime you run a fuel with more oil, you have to run the needles richer.
I also ran fuel through your engine at the factory without any issues. You could have bad fuel also..
Chad Phillips is offline
Old 01-11-2009 | 06:44 AM
  #1179
Team Chambers's Avatar
[QUOTE=Chad Phillips;5277675]kyjoe -
QUOTE]
Chad am I missing something here...More OIl??? Wouldn't you have to lean her out a bit not richen it???
Team Chambers is offline
Old 01-11-2009 | 06:50 AM
  #1180
100% agree with that process! I had low speed problems for the longest time runnig it to rich on the LS and turning the idle up. This was on other motors not my extech.
For what it's worth my pre run .24 fired right up, first turn. no problems at all then I leaned it out top and bottom a few hours and she rips like no other motor I have had.
Old 01-11-2009 | 07:11 AM
  #1181
cdbias's Avatar
Is there any wetness around the carb area? You may have a small leak or a tear in your carb boot. I had the exact same issue with my first mill and found a tiny slice in my carb boot. Threw a new boot on and all of the idling issues went away.
It was my first weekend with the "Big Boy" (2056 pipe) and all I can say is wow! I had been running the 2013 and I absolutely loved that thing but with the new pipe it makes the power band more linear and it upped my run time about 3 minutes. I had practice runs of 12:03 and 12:31. You could have laid the motor on your face afterwards it was so cool. Don't be scared of the ugly.
Thats on a "full mod" using the X-Tech #5 plug.
cdbias is offline
Old 01-11-2009 | 01:07 PM
  #1182
a little off subject just wanted to ask what size bearings to order from tko for x-tech engine ...time to replace on first gen x-tech ..thanks
C-Web is offline
Old 01-11-2009 | 01:50 PM
  #1183
+1 couldnt find it in the search bar and now am searching .....what is the size of the front and rear bearing ...and also is the bearings the same on the
.21 and the .24 .....
zixxer is offline
Old 01-11-2009 | 02:12 PM
  #1184
i know the .21 and.24 bearings are same it was in this thread somebody asked and chad posted but coudnt find a size for em
C-Web is offline
Old 01-11-2009 | 06:09 PM
  #1185
I ran a tank through today and it ran good and idled normally with the needles about 1/2 turn out from flush. The only problem I had was fuel leaking out from around the carb boot again. I removed the boot and found a flat spot in the carb housing where the boot seats and this is exactly where the fuel is coming out. You can see the flat spot just past the end of my finger. I don't think this is normal and I believe it's causing my problem. Sorry Chad, I'll be bugging you again tomorrow or you can PM and tell me what you think.
KyJoe340 is offline
