Trinity EXTECH .21
Old 08-11-2010 | 09:45 AM
  #2101
bigjayjay1's Avatar
Originally Posted by smedly
Anyone have the silicone insert in the crankshaft fall out of their ExTech .21?
Mine did. I found chunks of it between the sleeve and case. Caused me some tuning problems to say the least.
I cleaned out the motor and removed the chunks of silicone. What will this do to the performance/runtime of this motor, lacking the insert?
Runs great now that I figured out what was going on. It rips now, idles without stalling, and then doesn't load up/stall when I grab a handfull.
Anybody?
OMG that one for the three main problems with these motors others are cooling head and carb. The ramp isn't a issue run it as is save your money don't fix it you wont see a difference.
Also if anyone needs a brand new cooling head Extech NIB let me know will sell cheap.
bigjayjay1 is offline
Old 08-11-2010 | 10:13 AM
  #2102
chevydc44's Avatar
Originally Posted by Marcus Falconie
http://www.amainhobbies.com/product_...ine-Turbo-Plug
same motor the rod will fit when they get them. Someone also said the Werks B5 and Sirio Evo 4 rod will work also. I have a Extech II .21 rod I changed after break-in it is almost new.
So the piston and sleeve will also fit in the extech's
chevydc44 is offline
Old 08-11-2010 | 10:22 AM
  #2103
ScottyM's Avatar
Yes.. Bur keep in mind that the Bore and stroke are slightly different between the 2 engines.
ScottyM is offline
Old 08-11-2010 | 10:32 AM
  #2104
D8's Avatar
D8
so... what happens if you use a slightly shorter conrod in your engine?
D8 is offline
Old 08-11-2010 | 02:24 PM
  #2105
v6shooter's Avatar
I think the sirio ,orion , werks ,use the length rod right now i'm using a sirio evo 4 sti p/s ,rod,case and a werks b5 crankshaft and engine runs good. Will see if any better or worse when i race this weekend.
v6shooter is offline
Old 08-11-2010 | 03:18 PM
  #2106
D8's Avatar
D8
Thanks for te info mate!...., i guess that i will get the kanai3 engine rod from my friend..
D8 is offline
Old 08-11-2010 | 08:36 PM
  #2107
ScottyM's Avatar
The Rods are the same length from Sirio & Trinity.. But, rod length Does not determine your Stroke.. The Crank determines your Stroke..
The answer to your question, how ever, is it will change port timing.. Which could be good or bad, depending on which way it changes, and depending on your driving style.. I'm not a tuner, so I don't know which way will do what. One, thing I do know for sure if you only change the crank to a shorter stroked crank, you will loose some compression, same would be true if using a shorter rod.
ScottyM is offline
Old 08-12-2010 | 12:50 AM
  #2108
v6shooter's Avatar
sirio cl7 sti and the evo4 sti use the same rod [ same part number]it all about the crankshaft stoke. I gained the compression by removing a shim and i will watch it close. Not for beginers. 16.62 evo vs werks b5 16.50 crankshaft
Old 08-12-2010 | 12:53 AM
  #2109
v6shooter's Avatar
Has same bore and stoke so it should fit.
Old 08-12-2010 | 10:28 AM
  #2110
chevydc44's Avatar
And the rod is the same size if so im gonna order a re-generation kit but not sure which one to order cuz there are 2 different one's on team epic/team trinity website
Old 08-12-2010 | 10:50 AM
  #2111
ScottyM's Avatar
Port timing will be your only achilles, and depending on which way it moves it, it might actually fit your style of driving better..
I have a STi Evo 4 that needed new crank, I have a werks B7 I was considering swapping into, it, but decided against it, becuase none of the modders or manufacturers would give me any idea how well it would work.. one said it coudl either increase bottom end or loose bottom end.. Considering I wanted more, it was a gamble I decided against.. I ended up with a nice used RB S5, and am glad I got it..
ScottyM is offline
Old 08-12-2010 | 12:13 PM
  #2112
v6shooter's Avatar
Trial and error, my crank is wearing at the pin on my evo4 so that why am trying the b5 crank because its close .You cant find part on a sirio 4 sti anymore and the b5 crank has hardly no wear so what the hell.BTW the evo4is the best engine I have ran.I wished they still made parts for that engine,very smooth and powerful at the same time.
Old 08-12-2010 | 12:20 PM
  #2113
D8's Avatar
D8
+1 my evo4 sti engine is bad as hell.. but my eb full mod extech runs awesome as well.
D8 is offline
Old 08-14-2010 | 03:00 PM
  #2114
Rcrenew's Avatar
Anybody?
We re-fill the cranks on a lot of Sirio trinity engines, They are notoriuos for the epoxy coming out. We charge $15 you can run it without, like another member stated ,but it will run better with the epoxy in. With the epoxy out it enlarges crankcase volume, so you will lose responsiveness and a bit of runtime.
Lance,
Rcrenew.com
Rcrenew is offline
Old 08-15-2010 | 10:26 AM
  #2115
ScottyM's Avatar
One of my Evo4's is doing this as well, which is why I was considering using the Werks crank as well.. BUt you will have to run a Werks Rod.. And, I am not sure if the wrist pin is sized different from sirio to werks or not.. So just beaware that you might waste the $75 for a rod for nothing..
ScottyM is offline
