Like Tree2Likes
GRP... Engine... Thread...
Old 04-28-2009 | 08:50 AM
  #1411
Frank L's Avatar
Originally Posted by Toiffel
OK Gentlemen, I have a question that not only applies to GRP engines, but to all of them.
What does it mean, when after a high speed pass you apply brakes, and the engine revs high for a couple of seconds and then idlle drops down drastically to the point that it will die?
I was reading an article by the late Ron Paris, and maybe I misunderstood, but there is states, that when coming off a high speed pass, you should listen to the engine and it should have a slight high rpm before settling and if not to continue to lean the LSN......
Any help much appreciated....
Try raisng the idle or leaning the lsn. When you 1st start it does it idle?
Frank L is offline
Old 04-28-2009 | 09:02 AM
  #1412
yoshgixxer's Avatar
lean the low speed ..you may have to also lower your idle after you lean the low speed...plug may be crapping out also if it wont hold a idle and the engine still has good compression
yoshgixxer is offline
Old 04-28-2009 | 09:06 AM
  #1413
Toiffel's Avatar
Let's narrow it down:
1)Brand new plug
2)Engine has very good compression
3)No air leaks
Toiffel is offline
Old 04-28-2009 | 09:44 AM
  #1414
1)Brand new plug
3)No air leaks
Tune.
Alan D. is offline
Old 04-28-2009 | 10:19 AM
  #1415
Toiffel's Avatar
Originally Posted by Alan D.
Tune.
Wow can you read minds too?
Toiffel is offline
Old 04-28-2009 | 03:50 PM
  #1416
If you make something really obvious
Alan D. is offline
Old 04-28-2009 | 08:51 PM
  #1417
benamin's Avatar
Richen up the the HSN just a little, 1/2 to one hour. your runnin too lean hsn
benamin is offline
Old 04-28-2009 | 09:21 PM
  #1418
phantom racing's Avatar
i saw this on neobuggy today,
- GRP stop engine production, focus on tyres?
Got Gossip ?
[email protected]arely 4 days after writing, "I am still runnning GRP engines at this time. we will see what the future brings but as for now still GRP." in our Live Q & A, Mike Truhe has switched to Orion engines for the remainder of the 2009 season. After Adam Drake's departure to Novarossi, it seemed only a matter of time before Truhe would find a new engine supplier. The Losi driver will debut at the Euro warm up in Austria next week.
always sad to see and eng manufacture having a tough time.
phantom racing is offline
Old 04-28-2009 | 09:26 PM
  #1419
Frank L's Avatar
I have 3 new GRP's for this season for my truggy, 2 .21's and a .28 I will run them till they fall apart, they treat me well.
Frank L is offline
Old 04-28-2009 | 10:17 PM
  #1420
tristyn's Avatar
Bummer, The GRP's have been great engines for me. I am currently running the .21 &.28. I just installed new TKO ceramics in both engines last week. Maybe A guy should buy an extra p/s & rod before everything is gone.
tristyn is offline
Old 04-29-2009 | 06:31 PM
  #1421
Default fuel?
I'm just getting into 1/8 scale racing and just purchase a GRP engine. I was wondering is there a different in the nitro brands? Or should just be the same brand from my local hobby store?
alexaj46 is offline
Old 04-29-2009 | 07:09 PM
  #1422
Frank L's Avatar
Either that or do the Drake and switch to nova.
Frank L is offline
Old 04-29-2009 | 07:22 PM
  #1423
TeamD's Avatar
A-Main only has one GRP Piston/Sleeve 5 Port-ABC (.21)[LOSR2044] left.
I bought one this afternoon.
TeamD is offline
Old 04-29-2009 | 08:46 PM
  #1424
are grp people realesing a new grp????
muassociated is offline
Old 04-29-2009 | 09:32 PM
  #1425
Trevor Williams's Avatar
R/C Tech Elite Member
no
Trevor Williams is offline
