Like Tree2Likes
GRP... Engine... Thread...
Old 03-27-2009 | 02:43 PM
  #1261
odoylrulz's Avatar
For the GRP 2053 FLS pipe do you need one or two o-rings?
odoylrulz is offline
Old 03-27-2009 | 03:05 PM
  #1262
2
zixxer is offline
Old 03-27-2009 | 04:06 PM
  #1263
odoylrulz's Avatar
Old 03-28-2009 | 06:04 PM
  #1264
steve307b's Avatar
Hey guys I just got my GRP tuned .21 and it came with a couple different carb inserts. Wich one should I use? Not too familiar with these things. Thanks
steve307b is offline
Old 03-28-2009 | 06:06 PM
  #1265
6mm buggy 7mm truggy inmho
zixxer is offline
Old 03-28-2009 | 06:16 PM
  #1266
steve307b's Avatar
Ok thanks
Old 03-28-2009 | 06:26 PM
  #1267
Generally the smaller restrictors give better fuel economy at a loss of preformance. The larger restrictors offer improved preformance and less economy. It's probably better to start with the 7mm restrictor and see how the engine runs and change from there if you think you need to improve one charicteristic or another
John Schafer is offline
Old 03-28-2009 | 06:30 PM
  #1268
i mean i was event thinking the un thinkable ...running the 6mm on the truggy ...i didnt notice any difference...or well not noticable running the 6 or the 7 ...i idid notice better fuel economy ...with the 6 ...and fuel economy wins races ...but ...really i get great milage on the 7 in my x2 ....but buggy i would say the 6 or lower for runtime ..and the performance loss is negligible
zixxer is offline
Old 03-28-2009 | 07:22 PM
  #1269
patrick lsp's Avatar
Default ninja head on grp?
has anyone ever ran a different head on the tuned grp. from what little i know about the grp, they are very similar to the old b01 ninja. i have heard this from several different people. were the b01's turbo plug motors?
patrick lsp is offline
Old 03-28-2009 | 07:47 PM
  #1270
steve307b's Avatar
Thanks John...cant wait to run this thing
Old 04-01-2009 | 07:41 PM
  #1271
ovalosi's Avatar
Default plugs?
Do all of you guys run grp plugs? Also what temp plugs work best in a tuned .21 .I live in TN and have been running hots, but I was told I shoudn't be. Any suggestions are appreciated.
ovalosi is offline
Old 04-01-2009 | 07:59 PM
  #1272
steve307b's Avatar
I had a question on the GRP collet that came with my tuned .21. I installed the collet and then put on my losi flywheel. The flywheel did'nt seem to seat properly or go all the way back so I went ahead and put on the losi collet and it seems to work fine. I guess my question is do you have to have a certain collet for each brand of ctutch system? Because the grp one definately didnt seem right with my 2.0 flywheel.
Old 04-01-2009 | 08:16 PM
  #1273
Briguy's Avatar
Most of the time you have to use the collet that is designed for the flywheel , the car`s collet .
Briguy is offline
Old 04-01-2009 | 08:24 PM
  #1274
im breaking in my tuned .21 and noticed that the high speed needle is almost past flush on the way out to get enough smoke for it to run right is this normal cause i read it should be .045 in from flush and the low speed needle seems right from the .o45 out from flush any tips would be appreciated thanks.
teamreidy is offline
Old 04-01-2009 | 08:28 PM
  #1275
Briguy's Avatar
Needle settings are going to be different from what you read and everyone lives in different climates . Temperature and humidity play a big role for tune settings . Just adjust to where it works best in your area .
Briguy is offline
