Like Tree2Likes
GRP... Engine... Thread...
Old 02-11-2009 | 09:41 AM
  #916
Originally Posted by Jonro
At the end of the day if i need to replace all that and with the amount of fuel through it(around 20ltrs)it would probably be cheaper to just salvage the ceramic bearings and carb and buy a GO engine or something.
Scrap the bearings as well, metal shavings will have damaged the bearings as well.
Chris-s is offline
Old 02-11-2009 | 01:31 PM
  #917
Miller_Time's Avatar
Originally Posted by tom yfz
Jonro, Hate to tell you this, but the tune was off on that engine.
The piston has been cooked, and detination from being lean,and more than likely the lean condition has hammered the rod bushing out and changed the compression and timing, which in turn burnt the glow plug out.
I would not salvage anything out of that engine other than the carb and head!
Adam Drakes tune on this engine is:
.045 in from flush Hsn
.045 out from flush Lsn
.030 in from flush, idle screw
6mm restrictor
GRP 5 plug ( I run a GRP 4 plug)
2035 GRP pipe
The engine will run between 150 to 190 degrees(nitrotane,30%)
Good Luck
Are those measurements in inches from flush or something else?
Miller_Time is offline
Old 02-11-2009 | 03:09 PM
  #918
tom yfz's Avatar
Miller Time, yes those measurements are in inches, NOT mm.
The only one that is protruding is the lsn, it sticks out from the throttle ball mount.
The other two are measured, from flush to recessed (below the surface)
It should just need minor tuning from those settings
(air density,temperature,clutch springs etc.)
Good luck
Tom
tom yfz is offline
Old 02-11-2009 | 04:55 PM
  #919
Matt M.'s Avatar
Administrator
Good luck
Tom
it also a 2053 pipe
Matt M. is offline
Old 02-11-2009 | 05:33 PM
  #920
tom yfz's Avatar
Mr Losi is correct.
tom yfz is offline
Old 02-11-2009 | 05:38 PM
  #921
Originally Posted by jpz_67
Thanks for all the replies everyone I am still trying to decide, not ready to pull trigger just yet. Wouldnt you know as soon as I take interest in something the price goes up. The promo kits were on sale for 369.99 before discount at amain and now there back up to 445.00!!
Save Up to $65 in February!
To save up to $65 on your next order, enter the following discount code into your shopping cart before checking out.
If your Order is Between:You Saveiscount Code:
$75.00 - $149.99 $5.00RCFEB95
$150.00 - $249.99$12.50RCFEB912
$250.00 - $699.99$25.00RCFEB925
$700.00 + $50.00 RCFEB950
http://www.carolinasrc.com/Webstore/...idproduct=8834
http://www.carolinasrc.com/Webstore/...idproduct=8766
Not that it helps to much but whatever helps a little....
ABURTON is offline
Old 02-13-2009 | 12:47 AM
  #922
6mm restrictor
2035 GRP pipe
Good Luck
The piston looks allot darker and worse in that photo than IRL, plus the plug had no coil in it right after the engine died. The engine was running rich with a temp of around 190.
I put over 20 ltrs of fuel through this engine without a hiccup, unless someone sneaked into my house during the night and totally messed with me needles thats the only way it could have run lean, which it wasn't.
Jonro is offline
Old 02-13-2009 | 12:52 AM
  #923
190 is at the upper end of heat for those GRP motors.
Heck tonight Truhe's motor was running at 170 and it was flying.
Alan D. is offline
Old 02-13-2009 | 01:08 AM
  #924
losi_racer's Avatar
Originally Posted by Alan D.
190 is not hot for those GRP motors.
mine runs at 160 at it runs great
losi_racer is offline
Old 02-15-2009 | 05:13 PM
  #925
Franchize04's Avatar
I got a half gallon through my GRP tuned and its really coming alive. We had a test and tune day at the track and I was getting 11 minutes @ 160 degrees. I know it will get 12 minutes once it gets broken in good and race tuned.
Franchize04 is offline
Old 02-16-2009 | 05:21 AM
  #926
Has anyone heard about the new pricing plans or distribution? I plan to get one but definitely want to wait for their price drop.
Old 02-16-2009 | 07:20 AM
  #927
Frank L's Avatar
I have had 3 of these engines and they all seem to run around the 200 mark 190 to 220 with pleanty of smoke out of the pipe. Tuning to temp can be dangerous. Tune to smoke and performance and use temp as a check just to make sure you are in the right direction.
Frank L is offline
Old 02-16-2009 | 07:51 AM
  #928
What about breaking one in, should you still try to get to around 230F? I guess you would need to do some pre-heating and wrap up the head if so?
Old 02-16-2009 | 02:49 PM
  #929
How can you tell if your piston is black what does it mean is is too rich,but the engine has run 5 gallons + with compression
Quietman is offline
Old 02-16-2009 | 04:47 PM
  #930
Adam Drake's Avatar
http://www.losi.com/Articles/Article...ArticleID=1897
Adam Drake is offline
