Like Tree2Likes
GRP... Engine... Thread...
Old 06-05-2010 | 03:52 PM
  #2026
J.Sears's Avatar
Hey guys I dont mean to sound like a dumb ass but I can not get my motor tuned right. I have a MR21 B01T with the magnisum head. Ok so I take it out today and run it for the first time scense break in which still isnt completly broken in all the way yet still has alittle metal pinch left in it. well what it's doing is before I put it on the track i warm it up for 2 or 3 minutes and get the idel perfect on it well so I thought the first heat race i run it for 6 minutes and notice about half way through the race it has a real high idel like so fast it wants to push me through the turns. Why is it doing this? I just cant seem to get the hang of tuning for some reason it seems like the longer i do it the worse I get. I have read every thing i can find about tunning and it doesnt seem to help me any. Can someone please help me or point me in the right direction to get help and help me when to know when to richen or lean the bottom end and top end.
J.Sears is offline
Old 06-06-2010 | 11:10 AM
  #2027
J.Sears's Avatar
I will figure it out thanks though.
J.Sears is offline
Old 06-06-2010 | 05:20 PM
  #2028
mugenize1's Avatar
I had the same problem with my GRP .28 tune-line, your MR21 B01T is the same as the GRP .21 tune-line take it to stock at 0.045 inch tops needle from flush going in the same for the bottom but from flush 0.045 out and for the idle it's 0.030 inch this is your best starting point. My .28 was doing it and it was to lean in the bottem very puchy and idled Hi Start with stock settings and you should find the sweet spot just hit the top needle still it run just under 190% and you should be good. Hope this helps
mugenize1 is offline
Old 06-06-2010 | 07:52 PM
  #2029
J.Sears's Avatar
You have pm mugenize.
J.Sears is offline
Old 06-07-2010 | 07:38 AM
  #2030
mugenize1's Avatar
I returned your mail you have PM
Old 09-02-2010 | 12:34 AM
  #2031
can anyone help me find a carb bushing for a grp .28 or a grp ninja .28 its the little black thermo insulator that allows the carb to be used with the mill, just like this one http://www.amainhobbies.com/index.ph...inja-MR28-M01A
cham is offline
Old 09-02-2010 | 07:39 AM
  #2032
Integra's Avatar
Look into contacting TQ racing.
Integra is offline
Old 09-02-2010 | 07:43 AM
  #2033
thanx!
cham is offline
Old 09-02-2010 | 07:55 AM
  #2034
I have found a whole carb but I cant find the bushing alone, I have the carb, but just need the bushing
cham is offline
Old 09-02-2010 | 07:59 AM
  #2035
Tony Newland's Avatar
The bushing is not available alone.
Tony Newland is offline
Old 09-02-2010 | 08:02 AM
  #2036
Dr. Evil's Avatar
Talking Block
Hi. does anyone know where I can get a GRP/Mugen Ninja MR B01 Block.
I think the front bearing spun , now no bearings will stay in . They just fall
out.
Otherwise, I guess I'll just make it a paper weight .
I have a Magnesium head for this engine as well.
Dr. Evil is offline
Old 09-02-2010 | 08:45 AM
  #2037
plus2ss's Avatar
Here you go, http://www.amainhobbies.com/product_...kcase-21-Buggy
plus2ss is offline
Old 09-02-2010 | 10:19 AM
  #2038
newuserlosi8t's Avatar
Originally Posted by TStorm
Or you could sell it to me cheap!!
i got a mario rossi tuned line 21 grp with 3 gallons with break in runs killer i will sell cheap tons of compression and runs like a bat out of hell modded also
pm me if anyone intrested
newuserlosi8t is offline
Old 01-15-2011 | 06:59 PM
  #2039
Default setting to factory grp.28
sry for this topic. i dont understand when they say flush .45hsn and lsn on the grp can u help how many turns that would be from bottom to out? i purchased this motor last month and im on my 9th tank and i lost where thefactory setting was and the motor stalls . i sealed the backing plate and carb. and also is their a tool to used for the meaurments on .045 turn from flush?
florencio is offline
Old 01-15-2011 | 09:29 PM
  #2040
he is saying with the screw head flush with the body that it go's in use a set of calipers to measure it, and trun it in or out so it is .045 thousandths from flush. hope this help
axle is offline
