Like Tree2Likes
GRP... Engine... Thread...
Old 04-27-2008 | 04:25 PM
  #166
MadRussian's Avatar
I LOVE my GRP(Ninja) 21, ran about a gallon through it practicing today, did a bit of performance tuning...and WHOA, this thing puts out some SERIOUS power.
I need to reglue all my tires, the GRP power has torn them off of teh rims
MadRussian is offline
Old 04-27-2008 | 04:37 PM
  #167
Well, I whipped out the digital calipers and a bunch of plugs....
O.S. Turbo, GRP Turbo (C6), Mugen Turbo, and O'Donnell Turbo
Now rather than post my actual numbers, I'll post my findings. Reason being, calibration of digital calipers will vary so numbers may vary. The key is to use the same digital calipers for all the measurements, apples to apples comparison...
I measured total length from where the plugs sits on the button head to the end of the cone.
Length of the cone itself, from the shoulder to the tip or end.
Diameter at the end of the plug (filament end)
Diameter at the shoulder (Where the threads end, and just before cone starts)
Length of plug from where it sits to where the threads end....
In summary; I found the Mugen and GRP to be basically identical (no real surprise).
The O'Donnell was very close to the GRP that I'd have no fear of running it in my GRP. The differences I found were in the .001 range which I can attribute to my error....
The biggest difference was between the O.S. Turbo and the GRP C6...
The two big differences were in the (outside) diameter of the tip/end where the filament is. The O.S. measured .197, the GRP .202. The next biggest difference was in the diameter of the "shoulder". The O.S. measured .256 and the GRP .271
So, the O.S. is smaller by some. Other than that observation, I don't know what that really means....
I'd sure like to hear what others mic'ed out...
bushyar15 is offline
Old 04-27-2008 | 04:58 PM
  #168
ezveedub's Avatar
My suggestion is, it you ran an OS plug in the head button, use OS plugs for that button. If you want to use a GRP/Ninja plug, get a button for that glowplug. I have seen them leak, not just this brand, but all others when you switch up glowplug brands. I have heard people tried the OS plug and went back to the GRP glowplugs and said they didn't feel as good as the OS, but this could be because the taper is now not sealing properly.
I have been hearing the GRP is closer to the Picco taper than any other plug, but I would still say stick to GRP plugs unless you are certain you have no leakage issues with another brand.
ezveedub is offline
Old 04-27-2008 | 05:47 PM
  #169
Originally Posted by bushyar15
No offense, but pictures and basing it off of pictures can be inaccurate becuase of angle, distance, etc...
I would like to see the numbers on a set of calipers, actual measurements...
Come on man,... you can see the freakin difference... geesh! My point here is Novarossi plugs wont work no matter what the caliper say's! LOOK! The angle and distance is the same as they are laying right next to each other...! The taper does not match, the pictures are not lying....!
The reason to actually figure this out is:
10 GRP plugs @ $11.50 x 10 = $115.00
10 Odonnel plugs $6.99 x 10 = $69.90
What plug would you rather run if they both fit and perform well?
CarCrazy is offline
Old 04-27-2008 | 05:52 PM
  #170
Oh... I see you said no offense... sorry! Anyways, good job on measuring. No need for me to take close ups now. Cool.
Ninja, GRP, or Odo plugs got it!..
Thanks.
CarCrazy is offline
Old 04-27-2008 | 06:31 PM
  #171
MadRussian's Avatar
My understanding is there are 3 options
Ninja plugs
GRP plugs
O'Donnell 97 plugs< exact same taper, I run these
Old 04-27-2008 | 06:38 PM
  #172
Matt Howard's Avatar
got to race my GRP mill this weekend and it's a winner. Plenty of power throughout the powerband and it was delivered really linear. I'm happy with it I was running a P3 plug as well
Matt Howard is offline
Old 04-27-2008 | 08:23 PM
  #173
I asked Mike Truhe if I could run an O.S P3 with no problem in the GRP engine this is what he told me.justindyer: yeah that will fit just fine
JustinD is offline
Old 04-27-2008 | 08:29 PM
  #174
ezveedub's Avatar
One thing, does the stock GRP plug suck? I'm trying to figure out why everyone runs a P3 plug instead of what it comes with.
ezveedub is offline
Old 04-27-2008 | 08:47 PM
  #175
The one it comes with is a cold plug I think a GRP 6 mine died after breakin.
JustinD is offline
Old 04-27-2008 | 08:54 PM
  #176
I ran the P3 with very good results. P3's are cheaper and easier to find. Plus they idle for 1/2 with P3s.
infanterene is offline
Old 04-27-2008 | 09:05 PM
  #177
Geo Y-Rock's Avatar
Yes, the grp6 is a medium plug. the grp5 is the hotter of their selection. I emailed Mr. Drake and he told me to run the 5. I'm a tool and die mold maker. I have the precision tools to get some hard facts about the plug dimensions. I will measure a grp and an os. I work second shift so, I will post my findings in the early hours Tuesday morning when I get home from my Monday. The difference of the end diameter from .197 to 200 isn't as important as the angle. If the angle is different, that's when damage will occur. I will get the bottom of this.
Geo Y-Rock is offline
Old 04-27-2008 | 09:14 PM
  #178
Truhe told me to run the 4.But told me the OS would work fine no problems.
JustinD is offline
Old 04-27-2008 | 09:35 PM
  #179
FrankBlack's Avatar
Ive been running boss & ninja # 6 plugs with 25% with great results and i can get them alot cheaper here in Australia than the grp plugs. #6 plug seems to be ideal for Australian daytime conditions.
FrankBlack is offline
Old 04-28-2008 | 04:43 AM
  #180
The problem is if you are looking for the "hot" plug (GRP), just about every place is out of it. I can't find it anywhere in stock. So I believe people are looking for alternatives until those are available OR a less expensive alternative...
