Like Tree6Likes
RB Concept Engine Thread
Old 03-31-2009 | 04:43 PM
  #316
TommyBlazin's Avatar
rody left?? also anyone know anything on that new 9 port onroad?,,should be sweet
TommyBlazin is offline
Old 04-01-2009 | 08:03 PM
  #317
anyone know were i can still find a rb tm923???
ARCBOYZ is offline
Old 04-02-2009 | 10:36 AM
  #318
wingracer's Avatar
Originally Posted by TommyBlazin
rody left??
Yep, since the new year.
wingracer is offline
Old 04-02-2009 | 12:21 PM
  #319
kickass's Avatar
Originally Posted by bd581
It seems we have found the problem.
The low speed needle was pre set far too lean. 1 1/2 turns to far.
Took it back to what the instructions say, and, its not perfect yet, but its getting very close now.
Either way.
Why is there absolutely no information on this engine, not even by RB themselves?
BD there are lots of us that run these engines with no probs, if you need a hand just approach us at the track and we can assist. Be patient with it they are very tight at new. a good tune and full power wont come till they loosen up
cheers
Alex.K
kickass is offline
Old 04-04-2009 | 10:52 AM
  #320
FF25510's Avatar
Default RB T9 vs RB R3
hi, can i use R3 cooling head on T9, will it run hotter (because they are different in size) thanks!
FF25510 is offline
Old 04-04-2009 | 01:43 PM
  #321
Nitro-Racer*'s Avatar
i think so because they claim that the new design of the cooling head reduces the temp. of the engine
Nitro-Racer* is offline
Old 04-04-2009 | 02:16 PM
  #322
FF25510's Avatar
thanks, just because it's too big(to me ) and i though it can interchangeable
FF25510 is offline
Old 04-06-2009 | 12:39 AM
  #323
bd581's Avatar
cheers
Alex.K
Unfortunately i don't get to sydney racing.
Power was never an issue, nor was tightness. Even after a very slow 2ltr of fuel, it would start easy, but it just wouldn't run very long.
Since finding the problem, its been running well. The fault was with RB, no fault of ours. We took for granted that the needle settings were right from factory (like every engine we have had anything to deal with)
bd581 is offline
Old 04-06-2009 | 12:49 PM
  #324
Ultraspeed84's Avatar
does anyon eknow why RB used a AAC sleeve in the alpha motor instead of a ABC? ive heard alot of bad stuff about AAC
Ultraspeed84 is offline
Old 04-06-2009 | 05:06 PM
  #325
Default AAC
The AAC engines are fast . I have a zenon and love it. I never start it without heating it first. I have put about 3 gallons on mine and still can't turn it over without heating it first. With these engines you cannot ever run them lean or you will ruin them.
latemodel13 is offline
Old 04-07-2009 | 05:25 PM
  #326
how do you heat at track? they have power there, also do you have to heat in summer when its like 90 plus outside? ive been wanting to try one out, but the heating deal has me stuck,unless i can find a way to provide portable heat..lol..these guys are light as well, surely you have to adjust suspension to accomandate
Old 04-08-2009 | 08:03 AM
  #327
when I run one, I use a small torch to get it to about 150 to 160 degree's
before I start it, I alway's pre heat it, let fully warm up before tuning
michael 1 is offline
Old 04-08-2009 | 08:46 AM
  #328
can't turn it over without heating it first..
+1
motojon is offline
Old 04-10-2009 | 10:54 AM
  #329
Default Heat
Yes I race at a great track that has power outlets. They had the 1/8th worlds there in 2003. I heat mine with a 1600 watt hair dryer. It gets it to 170 degrees.
Old 04-25-2009 | 09:10 AM
  #330
joebiii's Avatar
Default r3
Hi,
Anyone tried using the "maxpower turbo tuned pipe 2602" on the RB R3 ? Is there a big difference in using it versu the 2604? coz right now its the only avlbl pipe I have.
thanks.
joebiii is offline
