Like Tree2Likes
Go-Tech Engines Thread
Old 01-29-2015 | 05:37 PM
  #14971
Excuse my ignorance but I don't know if it's the short or long needle. I can say it's a .21 Turbo Burn Room Coral Head Buggy Engine with a 13mm crank 3p+2. I'm running a Dynamite 5005 with a 7.0 Venturi.
LosiMadMan is offline
Old 01-29-2015 | 05:44 PM
  #14972
It holds steady at 240 to 250 degrees and rips. I usually run a med-hot turbo plug. The clutch is the losi carbon and aluminum shoes with black spring I believe. Since I have no track to race at I'm sure I'll go for the long lasting shoes after I finish this clutch off. The 5005 pipe is a great pipe, I'm not sure if it's still for sale or not I haven't checked. I'm sure there is an equivalent pipe though.
Old 01-30-2015 | 01:15 AM
  #14973
http://www.rw-mods.com/
see if you find what you may want .
DaRaceMasta is offline
Old 01-30-2015 | 03:35 AM
  #14974
cczjordan's Avatar
Basically all pipe can use but to get best performance better use recommended 2072
cczjordan is offline
Old 01-30-2015 | 07:08 AM
  #14975
Thanks I'll look there when I want a new engine.
Old 02-02-2015 | 03:07 PM
  #14976
18to88's Avatar
OS 2060 ....
18to88 is offline
Old 02-02-2015 | 04:23 PM
  #14977
curacing2's Avatar
Originally Posted by 18to88
OS 2060 ....
Lol, you could buy a new motor for the price of that pipe, GO motor and 2072 pipe, perfect combo.
curacing2 is offline
Old 02-02-2015 | 06:48 PM
  #14978
22Racer's Avatar
Richard at Bellgate says the new .28 gasoline engines will be shipping to the Usa this week! Cant wait to get some in and try them
Rex
22Racer is offline
Old 02-02-2015 | 07:18 PM
  #14979
curacing2's Avatar
It does look interesting Rex from the pic on the GO website.
What oil can you use to mix with the gasoline?..I remember the one a company was bringing out last year required their own expensive oil.
Old 02-02-2015 | 11:41 PM
  #14980
Use any high quality castor oil of your choice. The recommended fuel to oil ratio is 20:1.
Bellgate is offline
Old 02-03-2015 | 12:42 AM
  #14981
grizz1's Avatar
Hi Richard,
Are you importing the petrol engines for rtr applications ?
With the current rules in most countries a .28 engine won't be permitted to race in buggy class - just wondering how guys are going to work around this if they intend to race the motors ?
I'm guessing eventually rules may be changed to .21 nitro / .28 petrol, but in the meantime it's a bit of a funny situation.
grizz1 is offline
Old 02-03-2015 | 03:20 AM
  #14982
max_chen's Avatar
Originally Posted by 22Racer
Go used to sell the 0801 which worked very well on Go engines. Go doesnt sell it anymore but it is still available, I think it is one of the top 5 or so pipes of any brand.
Rex
max_chen is offline
Old 02-03-2015 | 05:58 PM
  #14983
cczjordan's Avatar
I think the dynamite pipe give good power/economy for older gx series
Old 02-03-2015 | 08:02 PM
  #14984
grizz1's Avatar
+1
The Dynamite 086 top end pipe was a strong pipe on the earlier 5 Port and 3 Port engines that had plenty of bottom end, and the Dynamite 053 mid range pipe was a brilliant match for the 7R engine - strong and smooth right through the power band.
I ran all those combinations back in the day, and they worked great.
I'd forgotten about the 0801 pipe that came out before the 2072. It was pretty good as Rex mentioned.
As far as the GO range of pipes, if you want an all round performer - one pipe you could run on all three engines (3p, 5p, 7p) - I'd still recommend the 2072 as my first choice.
Other than GO pipes, we are seeing great results on the later model GXII-5RHO and GXII-Plus engines running the Werks 2058 pipe and header.
This pipe works on just about anything - GO, Alpha, JS, Nova, RB, OS Speeds - performance and economy just seem to go hand in hand with this pipe. Possibly the most versatile pipe and header set up out there right now.
I must also mention the Werks 2058 pipe and header on the GO .25 6 Port truggy motor - awesome !!
The 2058 really brings this motor to life, giving massive bottom end power combined with a screaming top end that you would normally only associate with a .21 engine.
The unique 6 Port design combined with the 2058 creates a real beast
grizz1 is offline
Old 02-08-2015 | 12:06 AM
  #14985
Hi Shane,
Yes, the gas (petrol) engine is targeted at the RTR market.
Bellgate is offline
