Like Tree2Likes
Go-Tech Engines Thread
Old 08-10-2010 | 07:36 AM
  #11416
Suspended
Originally Posted by rcdude236
for the gx5r what do you recommend for a pipe. The 0801 or the 2072? Im just looking for something that will make it smooth and keep run times good.
086 works great with a round header
inferno13 is offline
Old 08-10-2010 | 07:55 AM
  #11417
Originally Posted by motomatt
For buggy I presume?
2072
yes buggy. Alright. I just figure the 2072 is better then the 086 because its made for the go's by go. You sell them? How much?
rcdude236 is offline
Old 08-10-2010 | 08:03 AM
  #11418
motomatt's Avatar
PM sent
motomatt is offline
Old 08-11-2010 | 03:11 AM
  #11419
grizz1's Avatar
Either will work nicely. I find I get better run times out of the 086 personally, and the 5 Ports do like that pipe (so do the 3 Ports & MG's).
Hey rcdude, I can't believe you had no bottom end with the 7 Port ?????????
I had run a 7 in my buggy for some time before I changed to the MG66, and it could be a handfull if the track wasn't up to it. Plenty of punch for a buggy with the 2072 pipe IMO, and the top end - well
I agree with Flanno totally - first choice for buggy is the MG66. Can't be beaten in this range of motors - smooth, powerful with top end that has to be experianced to be be realised, no kidding. Close behind is the GX-7R - sweet power band for a buggy with ballistic top end as well.
Unless you run real grippy tracks, the 5 Port is a bit of a handfull in the buggy, unless geared and clutched to quiten that stump pulling bottom end. Good in the winter months if your tracks get muddy. It has the extra bottom end to help carry the added weight build up during prolonged races in the soft conditions.
The 3 port is a sweet buggy motor on smaller tighter tracks. Lovely smooth power band, but just lacking a little in the top end on bigger tracks with long straights (unless you fit the MG66 modded crank and an 086 pipe - then it's quite nasty )
grizz1 is offline
Old 08-11-2010 | 04:04 AM
  #11420
MAGPIE-121's Avatar
hehehe +1
MAGPIE-121 is offline
Old 08-11-2010 | 06:30 AM
  #11421
how many minutes do u manage to get on your gx5r and gx7r ?
thks
Bear_ is offline
Old 08-11-2010 | 08:22 AM
  #11422
thks
Truggy, GX5r, 086 = 11.5 minutes on large open track
Buggy, GX7r, 2072 = 9.5 minutes on the same track
I DO NOT have a smooth throttle finger either
matrixmike28 is offline
Old 08-11-2010 | 03:45 PM
  #11423
grizz1's Avatar
He he - me neither
With the 086 on the MG in my buggy I can do 20 min on one stop (this is a smaller track with no hard out straights, running 7mm restrictor).
On my home track which is a fast flowing layout with several full throttle sections I can get around 9 mins with the same set up on a good day.
grizz1 is offline
Old 08-11-2010 | 05:31 PM
  #11424
deadmancourt's Avatar
what carb restrictor do you guys run in truggy with the GX-5R?
deadmancourt is offline
Old 08-11-2010 | 10:59 PM
  #11425
ya i hated that 7 port but i did really like run times at like 12 minutes. i got the 5 potr because i have a lot of medium grip tracks wiht jumps out of corners that are killer to hit.
Old 08-11-2010 | 11:09 PM
  #11426
grizz1's Avatar
Sweet !! If you have good grip and are faced with jumps just out of the corners like you describe then the 5 Port will kick butt with it's extra bottom end for sure. That's the nice thing with the GO GX range - there is a motor for every occasion
grizz1 is offline
Old 08-11-2010 | 11:10 PM
  #11427
jwm2's Avatar
I have no idea what problems you guys are having with your 7 port engines, but mine screams. It has so much low end torque its hard to get traction and the high end is ridicoulus. I have a 3 port, 5 port (pos engine) and a 7 port and run the 7 port in my 8 2.0 buggy and the 3 port in my 8-t 2.0 truggy. Both engines are fantasic with the exception of the 5 port i had repinched, but i think that was due to carb issues and i have a new one on the way to resolve that.
jwm2 is offline
Old 08-12-2010 | 01:09 AM
  #11428
808gx7r's Avatar
do you have a heavy clutch. i run two med and one hard spring and i have a heap of torq.
if i change my suspension setup i can make it wheelie all over the place
808gx7r is offline
Old 08-12-2010 | 01:47 AM
  #11429
grizz1's Avatar
jwm2 - have you tried the 7 in your truggy and the 3 in your buggy ???
That is the combo I would run (not having seen the tracks you run of course).
We have a few guys running the GX 7R in their truggies and they haul butt Run 3 x alloy shoes with all 1.1 springs, or the JVD (Ascendency) 4 shoe clutch with the gold 1.0 springs - NICE
grizz1 is offline
Old 08-12-2010 | 02:56 AM
  #11430
808gx7r's Avatar
i tryed the 3 alloys with 1.1mms as you told me... just way to much torq.
it loves just one 1.1 spring. still with a heap of grunt... almost too much but just how i like it. sideways from standing start
808gx7r is offline
