Like Tree2Likes
Go-Tech Engines Thread
Old 08-02-2010 | 09:53 PM
  #11326
MAGPIE-121's Avatar
Originally Posted by deadmancourt
im looking for 2 nice go motors for under $150!....any1 got any backups they dont need
try this page : http://www.rctech.net/forum/r-c-item...-9-motors.html
# 1 & #7 are the go, 1 just run in & 7 is brand new $250 for both
MAGPIE-121 is offline
Old 08-02-2010 | 10:15 PM
  #11327
deadmancourt's Avatar
yeah i pm'd him!....i was just checking if any1 has 2 used for a good price!
deadmancourt is offline
Old 08-05-2010 | 10:04 AM
  #11328
i am getting a barely used gx-5r, i was wondering what plug you guys reccomend running?.....i run truggy in hot ass so-cal where its always over 80 degrees
Old 08-05-2010 | 10:19 AM
  #11329
jwm2's Avatar
O'Donnell 77T (turbo plug) or 97T
jwm2 is offline
Old 08-05-2010 | 12:50 PM
  #11330
Flanno's Avatar
Australian Truggy Nationals Qually round 1, 13th of 71 so far.
I use T97 Medium
Flanno is offline
Old 08-05-2010 | 01:57 PM
  #11331
MAGPIE-121's Avatar
way to go flanno
O'Donnell 97T +1
Old 08-05-2010 | 02:27 PM
  #11332
well i just bought a used motor and was wondering,with the flywheel off,does the crank have back and forth play?....i took the back plate off and the con rod has no play on the pin but the crank can be pushed in and out just a lil bit?...is this normal or no?
Old 08-05-2010 | 02:32 PM
  #11333
the od 77t is a great plug!
Old 08-05-2010 | 03:13 PM
  #11334
so is the 97t!
Old 08-05-2010 | 03:23 PM
  #11335
like the 77t the best
Old 08-05-2010 | 03:47 PM
  #11336
how many shims should there be and what size?...i want to run 20% is that not good also?...i run losi's nitrotane 20% race blend
Old 08-05-2010 | 04:12 PM
  #11337
MassiveMods's Avatar
Originally Posted by vyt666
guess i'll try to change my plug to an os p3,currently im using a nova medium plug c6tf. about air filter,i always use clean air filters on my engine.last week the engine rips on our local track without flame outs,no idle drops,no lean bogs,tuning errors whatsoever,maybe nova plugs do not lasts like the os plugs.
the C6TF is a cold plug , the nova plugs with the letter F in them is cold. Freddo in italian is Cold . F Cheers MM
www.massivemods.com.au
MassiveMods is offline
Old 08-05-2010 | 04:23 PM
  #11338
MAGPIE-121's Avatar
deadmancourt heat the motor up with a heat gun before u fire it up & all will be good. the motor isn't run in yet by the sounds of it & the crank play is normal without the flywheel !
have a good look at the head button with a small flat blade screwdriver & see if you have the shimes there as 1 is the same color as the head button & the copper ones might be under it !
hope this helps
Old 08-05-2010 | 04:42 PM
  #11339
jwm2's Avatar
Do the venturi carbs on ebay work on the older 5 port engines? I just had my 5 port repinched and it doesn't want to hold a tune, the idle is all over the place and it likes to flame out on me. I am hoping a new carb will get it back to where it needs to be.
jwm2 is offline
Old 08-05-2010 | 04:48 PM
  #11340
hope this helps
thank you!....i put it all back together and sat it out in the sun for 30mins cause i dont own a heat gun and it runs great!....i didnt really even drive it but just fired it made sure it idles and blipped it acouple times and all is good....sounds great!....about the shims,right before i put it back together i tried what you said and found 1 thick shim,the same color as the button head,but no other shims!...should there be any more shims! i only run 20%...i have a few old shims some thin,some thick,but none as thick as the 1 thats on this motor!
