Like Tree2Likes
Go-Tech Engines Thread
Old 06-30-2010 | 12:20 PM
  #10981
grizz1's Avatar
Originally Posted by kevinjh
Changed my clutch to answer rc alum long life low wear with 1.1 springs,
Have kept retuning the engine from flush as the tune isn't right, mostly due to changing restricters, air temps and using different tracks,
have had the engine with good top end with no bottom and visa versa but always with the plug issue, I have used 11 plugs in 2 1/2 gallon now.
One of the main reasons for retuning though is kind people help tune it, first they up the idle then tune it by leaning the top end about 2 turns in, I know this isn,t right but hate to bash kind offers, engine runs reasonably well but blows plugs, cuts and just isn't the powerful engine i keep being told it is supposed to be so set back to flush and try again when they leave.
Would really like to be able to crack this tuning melarchy as I get bad quals all the time and loose 2 many laps in finals, I know i am faster than what results im getting but obviously loose 2 much time with cuts, was 2/3 of a lap ahead last sun but ended up 5th after 3 cuts, drives me mad.
Have tried to use Griz paragraph but sometimes the LSN needs to go in 2 1/2 to 3 turns to get the engine to cut out between 5 - 7 secs. when on the track and hot it bogs?
OUCH !! 2 turns in on the top, no wonder it is blowing plugs. You will have to start being rude to the kind people that are trying to kill your motor.
They are committing all the cardinal sins - wide idle gap, rich bottom, super lean top.
Definitly set idle gap at .7mm and follow the instructions on my site (PM'd you).
grizz1 is offline
Old 06-30-2010 | 12:27 PM
  #10982
Gizmatron's Avatar
I had the helpful tuners when I was a noob....they are trying to tune your long needle carb like a short needle carb...politely tell them to go jump in a lake.. then follow tuning above..I would take the time to just blow out the carb and needle seats and reseal everything..can't hurt and at least eliminates that from the equation..gimme a sec and i'll post the link to grizz1's guide
go here http://www.go-racing.co.nz/ and click tech tips...
Gizmatron is offline
Old 07-02-2010 | 04:50 AM
  #10983
Do you set the idle gap with or without a restrictor in the carb??
Tigergutt is offline
Old 07-02-2010 | 05:09 AM
  #10984
MAGPIE-121's Avatar
it's easier without
MAGPIE-121 is offline
Old 07-02-2010 | 05:14 AM
  #10985
Originally Posted by MAGPIE-121
it's easier without
Old 07-02-2010 | 01:39 PM
  #10986
Have stripped the engine down to have a look at the carb etc, the seal on the carb has split and the front bearing has play in it, the needles were not the cleanest either, think any one of these problems may be giving me tuning problems, there is slight wear on the conrod as well, I will be replacing the conrod, bearings and seals prior to rebuilding the engine to ensure I start tuning in a good position. Question - do you think the play in the front bearing has caused me problems with my clutch bearings? I use the answer rc bearings and they last about 25 mins running before collapsing?
kevinjh is offline
Old 07-02-2010 | 01:41 PM
  #10987
Ruune's Avatar
Have stripped the engine down to have a look at the carb etc, the seal on the carb has split and the front bearing has play in it, the needles were not the cleanest either, think any one of these problems may be giving me tuning problems, there is slight wear on the conrod as well, I will be replacing the conrod, bearings and seals prior to rebuilding the engine to ensure I start tuning in a good position. Question - Is it really worth fitting the ceramic rear bearing for the extra cost over the standard bearing?
yes... go for a ceramic rear. I'm in the process of testing a ceramic one that I'm hoping will work out.
Ruune is offline
Old 07-02-2010 | 01:45 PM
  #10988
rear bearing is 14*25.4*6 but do you know the size of the front bearing as i have not removed it yet?
kevinjh is offline
Old 07-02-2010 | 01:57 PM
  #10989
Ruune's Avatar
7x19x6mm
Ruune is offline
Old 07-02-2010 | 02:32 PM
  #10990
Default newbie
hi just got my go7 port today just wondering what plug to use whats the osp3 like ?
africa is offline
Old 07-02-2010 | 02:59 PM
  #10991
grizz1's Avatar
A lot of guys run the P3. I prefer the O'Donnell 97T med plug, seems to work better on 25% or higher fuels - for me anyway.
grizz1 is offline
Old 07-02-2010 | 03:11 PM
  #10992
agreed.
go t3 plug on 25%
above 25% the od97t lasts.
fastboy is offline
Old 07-02-2010 | 11:27 PM
  #10993
Redvet79's Avatar
Answer-RC Has both the front and rear ceramic engine bearings.
$15.00 Front.
$30.50 Rear.
Check with MassiveMods about these bearings.
http://answer-rcusa.com/zencart/inde...&cPath=28_5_20
Redvet79 is offline
Old 07-03-2010 | 03:06 AM
  #10994
808gx7r's Avatar
whats some ways to set the idle gap without running the engine... other then a .8 drill bit?
808gx7r is offline
Old 07-03-2010 | 03:12 AM
  #10995
MAGPIE-121's Avatar
what grizz says in the next post
