Like Tree2Likes
Go-Tech Engines Thread
Old 05-07-2010 | 09:15 PM
  #10621
grizz1's Avatar
Originally Posted by 22Racer
I read the shimming 101 last year and it confused me.
I always break in a Go motor with stock shimming, no break in shim. After the motor loosens up a bit, a couple race weekends or a gallon on it I take out one brass shim. This leaves me with one aluminum and one brass shim. This is for 30% fuel, for 20% i think you could run one alum shim fine.
Rex
What size restrictor do you normally run with this set up Rex ?
grizz1 is offline
Old 05-07-2010 | 11:27 PM
  #10622
22Racer's Avatar
Most of the time we use a 7mm restrictor. I was talking with Ed Bridges a while back and he also recommends this.
Rex
22Racer is offline
Old 05-08-2010 | 07:59 AM
  #10623
im going to try my 7 port with the 97T plug tomorrow instead of the T3 and with the .2mm extra shim removed..probably not good to try all this at a national meeting lol but needs must
anyone know why some countries got the long needle and some got the short needle?
what i do find with the long needle is that as we travel all over the UK sometimes 200-300 miles to a track, the engine seems to change tune quite a bit,fine at one track,rich and boggy at the next with no change to tune,never really noticed this change with previous engines and yes i know humidity and barometric pressure changes the tune but it does seem over sensitive.
im wondering if the long needle is making the tune hyper sensitive and thats why the engine seems to be so far off tune sometimes..im wondering if going to the short needle will be better.
fastboy is offline
Old 05-08-2010 | 04:34 PM
  #10624
MassiveMods's Avatar
Originally Posted by grizz1
Hi Mark. With .5 shims total, is that including the head button or just the shim stack ?? It's always confusing when it says "total" - well it is for me anyway, duh
what i mean when i say " Shims Total " is the " Total amount of shims " I never include the .3 mm step when i recommend a shim measure.
Just forget the extra .3 mm , its built in to safe guard people running too few shims and butting the piston into the head button. Actually its built into about 80% of engines head buttons .. of all brands.
The information is there to help people who want to go into advanced shimming technique to find the ACTUAL head gap when calculating trapped and geometric comp ratios so they can gauge fuel mixes and plug choices. Shimming is a crutial point of tuning for any engine. If you want the very most out of it you really need to understand shimming. Yes its a bit advanced , some will get it some wont , either way its ok.
The info is there if you want to go the extra step , if you don't you can happily run the standard shimming and have a great running engine.
Hope this clarifies things
MassiveMods is offline
Old 05-08-2010 | 04:36 PM
  #10625
Originally Posted by vyt666
need some help guys,i started breaking-in my motor yesterday, pre-heated the engine with a hair blower,the engine starts but keeps on flaming out,it will idle for about 10 seconds then flames out,so i pulled the engine and sealed the carb base,backplate,pinchbolt,checked for any airleaks on my fuel tank,tubing..then put it back again on my car,but still doing the same thing,there is no problem with my needle settings,btw im using an os carb on my engine,then the last thing i check is my turbo plug(NOVAROSSI PLUG),when i put it in on my igniter it does give a bright orange color.Im still figuring out what could be the cause.
If the engine had air leaks it would most probably idle longer.
When you start the engine and pinch the fuel line how long does the engine take to die ?
Old 05-08-2010 | 05:12 PM
  #10626
bigmatt's Avatar
mark, what is acceptable pipe temps? I am having trouble with my mg-66. I know about the shim stacks, and melting bodies.but what would you rec for clutch springs? It's the initial snap. almost like rich for second then wild ass ride.I am using answer clutch system with the 1.0 spings,go-tec 2072 pipe,30% byrons gen2 nitro. I will be going to the Amain 30% nitro from our U.S. distributor after I finish off my 1.5 gallons. I tried the amain25% nitro. what I like about it is how clean it burns. Inside of engine was perfectly clean. I am really wondering knowing what I have learned from this site and yours,if 20% nitro is the way to go. I know there is all sorts of things that go to pipe temps,but if you could point me in the right direction It would be appreciated.
bigmatt is offline
Old 05-09-2010 | 12:06 AM
  #10627
The simple answer is "don't worry about the temperature".
There are so many variables in what temp an engine runs at - fuel type, plug type, pipe, ambient temp, height above sea level, track conditions etc, etc.
If it's running well and making good power with good smoke right through the rev range then it's a happy motor - the temp is irrelevant. Some engines will run best a little cooler, and some will run much warmer. Don't compare temps and tune to someone elses motor. Most times your tune will be off doing this.
Massive Mods has the best advice for temp gun use. His answer will be to hit it very hard with a hammer, then tune by sight, sound and performance. It's good advice.
WELL I TOOK EVERYONES ADVICE AND TUNED IT BY PROFORMANCE AND RAN MY .28 6 PORT AT THE OFNA RACE THIS WEEKEND AND IT DID GOOD FOR A LITTLE BUT RUNNING 300 WITH PLENTY OF SMOKE AND THE SECOND HEAT RACE THE ENGINE WENT PLOP. NO MORE ENGINE. LOST ALL COMP. ONLY HAD ABOUT 1/2 TO 3/4 OF A GALLON OF FULE IN IT AND SO I GUESS I WILL THROW THAT ONE IN THE BOOKS. KINDA MAKES ME MAD THAT I DID WHAT EVERYBODY SAID TO DO ON HERE AND FROM GO TECK AND WITH SO LITTLE FULE ON IT SHE LOST ALL COMP.
ANYBODY CARE TO TRY TO ANSWER THAE QUESTION ON WHY IT DID THAT
OR JUST MAINLY THE ONES THAT TOLD ME TO RUN IT LIKE THAT
grubby is offline
Old 05-09-2010 | 02:40 AM
  #10628
Well if you use high quality fuel and you really have smoke from the pipe ALL the time it really should not get at 300deg. Maybe your gauge was off or it was excessively rich on bottom and way to lean on top and it actually did not put out smoke on full throttle ? Also running it should not kill the compression completely in such a short period unless the engine gets dirt in. So are you 100% sure your filters were OK, neck had zip ties etc. ? It's really hard to believe you trash an engine in such a short perod of time w/o having some serious issues
Poinas2 is offline
Old 05-09-2010 | 09:37 AM
  #10629
kael's Avatar
Hey all,
Fuel question:
I've been running Byron's Gen 2 Race 30%, but two LHS closes later (), the third LHS (if an hour away is considered local!) had some bad experiences with Byron's Gen 2 and doesn't carry it. They recommended Sidewinder instead.
Any concerns switching? Running Go Tech 5 .21 in buggy, broke it in on Byron's. Got a big race in three weeks and don't feel like trashing my motor just now.
kael is offline
Old 05-09-2010 | 10:19 AM
  #10630
I know exactly how you feel. I trashed several motors over my first year of racing after only a gallon or 2. I tried blaming everyone for it. It turns out that it was my fault the whole time. I was getting dirt in the engine in a couple cases but the number one thing I was doing wrong was simple tuning things. I was running my idle gap to open which made me tune my top end way to lean. The number one symptom for this is that the motor run really strong for about the first 3 minutes and then the temps start to rise and just keep on rising the longer you run.
Now that i know how to tune. I am still running the same 2 go tech motors I ran all last season for local club races. They both got new bearings at 2 gallons but my 7 port has over 10 gallons on it and my 5 port is going on 8 gallons. both of my GX race motors have over 2 gallons and both still have very slight metal pinch. I personally still check my temps as a back up after every run but that is just to make double sure my tuning is right.
matrixmike28 is offline
Old 05-09-2010 | 10:28 AM
  #10631
22Racer's Avatar
Originally Posted by kael
Hey all,
Fuel question:
No problem switching from Byrons to Sidewinder, We run Byrons but used to run Sidewinder with no problems. Depending on oil % you may have to retune and hour or 2 but thats it.
Rex
22Racer is offline
Old 05-09-2010 | 10:46 AM
  #10632
Hey im having problems tuning my car. I have my idle set good. but sometimes i bring it to a complete stop the the car idles really high but other times i bring it to a stop and it idles normal. The carb is all the way closed, im sure of that. It also will run good for like 2 minutes than it goes weird again. Does this sound like an air leak. I got the carb, backplate, the carb bolt, And the little rubber thing on the carb sealed off. I dont know whats going on. Any help would be appreciated. Thank you.
rcdude236 is offline
Old 05-09-2010 | 01:11 PM
  #10633
Dlewis4's Avatar
R/C Tech Elite Member
Hey Go Guys.. i hve a 3 Port blue head with turbo button and normal head i am trying to get rid of. Only has 1 gallon on it including the break in. It rips in the truggy, just have no need for it anymore.
I figured i would let you all know... i want $60 for it, and have a GO pipe for it too, and would take 30 for the pipe...
if interested, PM me
Dlewis4 is offline
Old 05-09-2010 | 01:12 PM
  #10634
ran my 7 port today in the UK nationals,using 30% and od 97T plug with the stock shims..engine was a missile
getting around 9 and half minutes i reckon with what was left in the tank..shame my rear driveshaft sheared in 2..too much hp lol
fastboy is offline
Old 05-09-2010 | 01:14 PM
  #10635
Default Comparison!!??
Hi guys.
This is a serious question so please don´t start any bashing.
I´m considering trying the GO engines and I have been using a OS V-Spec and I´m satisfied with it but I would like a more mellow/controllable bottom.
It hits like hell on the bottom.
I´ve tried a couple of my friends Novarossi +4 engines with the exact same car/setup as my car including the same clutch-setup and damn it´s a nice engine... Smooooth and fast with good runtime.
Should I try the GX-3R, GX-5R or GX-7R if I would like an engine to perform like the +4?
Thanks for your time.
harleyrules is offline
