Like Tree2Likes
Go-Tech Engines Thread
Old 08-25-2009 | 10:21 PM
  #8416
MassiveMods's Avatar
We have all that in stock
Tini pin
G Clips ,
Rods
Nitrile Seals
MassiveMods is offline
Old 08-26-2009 | 05:51 AM
  #8417
tonydig11's Avatar
Tini pin
G Clips ,
Rods
Nitrile Seals
thanks. Already been to yor site. ill order 2 this week
tonydig11 is offline
Old 08-26-2009 | 02:09 PM
  #8418
zonda's Avatar
Tini pin
G Clips ,
Rods
Nitrile Seals
How much does it cost to post to united kingdom mate?
Rob
zonda is offline
Old 08-26-2009 | 06:00 PM
  #8419
22Racer's Avatar
Originally Posted by ConciliumDesign
What is the correct shimming for a GO .25 6 port using 25% nitro? Is the crank for the .25 6 port different from the .21 5/7 port engines? What is a good pipe to use for the .25 6 port? I have; 086, ttr 2035. 0801, and 2047. What would be the best one to use for a medium sized track in a truggy. Thanks
I would probably take out one thin .004 shim for 25% but never tried it. The .25 and .28 crank are the same but longer stroke than a .21. We've been running a 086 but the 0801 works very well and gets better mileage. You could try the 2047 with the 0801 header also. We've been running the .25 with the turbo button and a shim to change timing and it kicks butt.
Rex
22Racer is offline
Old 08-26-2009 | 06:20 PM
  #8420
Rob
$9 AUD so thats about $7.50 USD
Old 08-27-2009 | 04:45 AM
  #8421
Hey Guys - just to let anyone know in the UK that we will be the Go official importer for the new GX range and will be carrying all the spares as well so Zonda we will have all these bits hopefully in the next 10 days.
We are also doing to MG66`s over here and had them land today - very nice indeed!
Pete
Answer-RC is offline
Old 08-27-2009 | 05:27 AM
  #8422
Hello from France,
It's done here:
http://www.automodelisme.com/index.p...&topic=38953.0
romuald31 is offline
Old 08-27-2009 | 05:36 AM
  #8423
mattwoodcraft's Avatar
i get to run my new gx5r in tomorro in my new truggy look forward to it , then sunday race day
mattwoodcraft is offline
Old 08-27-2009 | 07:13 AM
  #8424
Flanno's Avatar
6T ! What happened to the Losi Mat ?
Flanno is offline
Old 08-27-2009 | 07:44 AM
  #8425
zonda's Avatar
Pete
Awesome do you have a web address ?
Rob
zonda is offline
Old 08-27-2009 | 11:54 AM
  #8426
fievel's Avatar
would a backwards fuel filter make my engine run inconsistently? I rebuilt my engine after having a runaway, but noticed the engine didn't tune consistently, a guy at my LHS noticed that the filter was backwards and flipped it around and now it seems to run like new. could the filter cause this problem? thank you for your time.
fievel is offline
Old 08-27-2009 | 12:09 PM
  #8427
BlueisBetter's Avatar
hi Zonda
here is the website you asked for
http://www.answer-rc.com/
the dont sell direct but here is the list of answer stockists
http://www.answer-rc.com/shoplist.php
these are in wales
http://talywainrcracers.com/1stPlaceModels.html
http://www.manseltonmodels.co.uk/
BlueisBetter is offline
Old 08-27-2009 | 12:20 PM
  #8428
RETRO RC's Avatar
definately they are design to flow in one direction
RETRO RC is offline
Old 08-27-2009 | 12:22 PM
  #8429
RETRO RC's Avatar
I beleive he said something about not wanting to lose anymore servos
RETRO RC is offline
Old 08-27-2009 | 12:28 PM
  #8430
bigmatt's Avatar
yes! harder to let fuel through. some filters it won't matter which way you put it in,others will be just like the ones for your car. they never show fuel flow direction[at least I haven't seen one] what I do is hook up some tubing at one end and blow through, then switch ends. how ever it comes out of which end the easiest is the way it should point to carb. And actually I do not run a fuel filter any more. First off there is one in my gas tank second if you start developing engine problems,like you think you have an air leak? Check fuel filter first always. Take it out of line and hook tubing direct see if problem solved.
bigmatt is offline
