Like Tree2Likes
Go-Tech Engines Thread
Old 05-14-2009 | 06:19 PM
  #6796
MassiveMods's Avatar
Howdy all , just thought id share some info on NSW titles so far !
Team Driver Robert Flanagan
Today NSW state tittles.
Truggy legal 150ml, was scuteneered at 148ml well under legal capacity.
Timed practice 1: on track for 13min 30sec, engine still running after that untill shut down, still fuel in tank.
Timed practice 2; on track 14min 18sec, you guessed it, engine still running untill pit man shut down, and again still fuel in tank. Engine at 137'C
The grin on my face when pit man showed me stop watch and temp,
priceless.
Products used:
MBX5T
Massive Mods C2 Amain bluedot fuel
MM3 GO gen5 5port .21
Sirio 2013 pipe
GO t3 plug
6.5 venturi
Thats Massive !!!!!!!!!!!!!!!!!!!!!
MassiveMods is offline
Old 05-14-2009 | 06:34 PM
  #6797
grizz1's Avatar
priceless.
He he - That's downright disgusting !!!!
grizz1 is offline
Old 05-14-2009 | 08:43 PM
  #6798
Default tuning my 7 port go
i was running 30% today and switched two 20% I cant seem to get my tune right. She runs about 240-245 then will jump up to 263-268. i put a p3 plug in and just cant seem to get it right. ANYONE. Oh buy the way Russ over at race factor THANK YOU!
leapinglizard is offline
Old 05-15-2009 | 12:36 AM
  #6799
If it's jumping around w/o any logic check your needle O-rings and if OK check the lower o-ring in the carb neck. Also I'd suggest to move to colder plug and learn how to tune the low end with that. Hotter plug helps idle and that might cause too rich LSN -> too lean HSN and screwed up idle gap hot engine doing all sorts of weird things.
Poinas2 is offline
Old 05-15-2009 | 12:47 AM
  #6800
Rampokker's Avatar
Cheers for the replies guys.
And thanks for the run in procedure grizz1. I'll definitely give that a go.
Rampokker is offline
Old 05-15-2009 | 02:19 AM
  #6801
03racefan03's Avatar
Got my ST5 Gen5.5 5-ports from Mark @ Massive Mods this week!!!
Looking foward to getting them installed and running
03racefan03 is offline
Old 05-15-2009 | 03:41 AM
  #6802
grizz1's Avatar
What a pretty pair But don't be deceived, there is evil lurking beneath their normal looking exteriors MMods Stage 5 evil
grizz1 is offline
Old 05-15-2009 | 03:54 AM
  #6803
Gizmatron's Avatar
Hehe..nice one grizz1..couldn't agree more..
I wish the weather would clear up here..I replaced the rod and pin(ti-ni coated ) in my mm5 3 port on monday and fitted the GO 2072 pipe to my mm5 7 port same day and it's rained ever since :
Gizmatron is offline
Old 05-15-2009 | 04:07 AM
  #6804
grizz1's Avatar
So it's your fault Gizz !! I am in a similar boat (that should read ARK). Two weeks of soild rain, hail, thunder here. It is the begining of our winter, but it has been very wet for this time of year. Racing cancelled last week and this week now
I just finished giving both my motors a 3 gallon TLC service. New bearings, rod and a crank polish for the Stage 5 5 Port. New bearings, rod and Gen 5.5 crank for the Stage 3 7 Port (which was a Gen 4). Since I finished them it hasn't stopped raining.
Maybe next week Sounds like the 2072 pipe is the goods. Might have to save some pennies I think.
grizz1 is offline
Old 05-15-2009 | 04:37 AM
  #6805
Rampokker's Avatar
I share your pain! I got a brand new XT8 almost 4 weeks ago, and due to work and other things requiring attention, I have still not even run it once. Hope the weather clears up soon for you guys. Over here it sounds like the roof is going to be blown off tonight.
Old 05-15-2009 | 07:35 AM
  #6806
Having trouble with tuning my 7-Port. I have about 3 qts through it idles pretty good but when I accelrate it flames out. I guess I am running pretty rich but I can not chance it out of the current tune.
I tried adjusting the needles a little at a time but nothing. I ran the buggy for about a tank with good results prior with temps never getting aboe 235-245.
I know the motor has not been fully broken in yet.
The long needle is the HSN correct.
I want to start off with the factory settings and is that flush on both needles. Sorry about the tupid questions but I dont want to ruin the motor.
Thanks to all in advance who has the time to help out.
xlt69er is offline
Old 05-15-2009 | 07:43 AM
  #6807
bigmatt's Avatar
set needles,lsn 11/2 in hsn 1/2 turn in. it should run fine at those settings. if not you may have an air leak. mine did it at the bottom of the carb. there is an o ring there that seems to be problematic. Just check it if the above setting do not work. also make sure glow plug is good. But it sounds like you are running lsn to rich.
bigmatt is offline
Old 05-15-2009 | 08:34 AM
  #6808
Wow, this must be contagous, our race this weekend was just cancelled due to construction on our new drivers stand not being ready .
BTY, would you PM me your break in method, and any hints you have to keep these beasts good and happy for the long run, I went ahead and bought Mark's MM Miracle run in formula for the break in process. And what do you guys think of GMK's Afterlife afterrun oil? Good stuff or no?
Thanks!
Old 05-15-2009 | 12:47 PM
  #6809
Gizmatron's Avatar
OK I confess! All rain,general bad weather and unfinished building work is my fault..Don't ask how I do it cause it's top secret! I could tell you but then I'd have to kill you! While I'm at it I'll take the blame for all this weeks DNF's at tracks that I failed to ruin with my weather control..
Whatever you problem just blame me and I'll pretend to care
Old 05-15-2009 | 01:19 PM
  #6810
grizz1's Avatar
Thanks!
PM sent. No knowledge of the GMK afterun, but I know Mark does a MMods ARO that I will be using in the near future.
grizz1 is offline
