Like Tree2Likes
Go-Tech Engines Thread
Old 01-06-2009 | 11:16 PM
  #5326
losi_racer's Avatar
Originally Posted by ced_so_thoed
What size would y'all run in a truggy? 21, 25, or 28?
.21 5port
losi_racer is offline
Old 01-07-2009 | 01:11 AM
  #5327
grizz1's Avatar
Originally Posted by Furadi
+1 on heavier springs, and try a JP-2. Works great on my 3 port and 7 port. Tried a JP-1 but it took to much off the top.
From what I have heard and read, none of the JP pipes particularly suit the GO motors. Save some dollars and get a GO FEMCA 0801 pipe if you are looking for bottom end and a good mid to top end rush.
grizz1 is offline
Old 01-07-2009 | 01:28 AM
  #5328
Gizmatron's Avatar
Default pipes
I've never tried the jp pipes as they are not EFRA approved for racing in europe but I use the HN 2047 ..( the GO 2047 is exactly the same )on both my .21 7port and the .21R 3 port and it makes insane power everywhere..maybe a touch more top than bottom end power but the heavier clutch springs counter that..never had a problem passing anything except the black speed tuned OS v-spec but thats a truly silly motor and costs $400+ ..
Gizmatron is offline
Old 01-07-2009 | 01:39 AM
  #5329
RETRO RC's Avatar
really I've never had a problem leaving the speeds behined with my stock 7pt turbo with the 2047 pipe.
If you want a little more bottom end get yourself a 98mm rossi header or a header of the 0801 with the 2047 pipe and you'll be more than pleased with the bottom on the 7 and 3 ports with out losing noticable top end.
Adrian
RETRO RC is offline
Old 01-07-2009 | 02:29 AM
  #5330
Gizmatron's Avatar
Default pipes
cool thanks for the info I'll try the different header..a little more bottom punch would be nice...and re the speed motors..dunno but we have just one guy in our league with one and its so fast its silly..luckily he can never keep it on the track long enough to win anything....no idea what he's had done to it or what pipe he runs or anything but it has a very distinctive scream just before he disappears over the back of a bank and into the scenery hehe
Old 01-07-2009 | 05:03 AM
  #5331
slakr's Avatar
Why does it appear that everyone is using "hot" glow plugs on the GO .21 5-Port Turbo?
I would have thought that you would use a "cold" or maybe even a "medium" plug?
However, I have never owned an engine that required a "Turbo" plug.
slakr is offline
Old 01-07-2009 | 05:51 AM
  #5332
I am getting ready to change my rod, pin, clips, and go to TKO bearings on my PTM .21 5 port, I have just alittle over 2 gallons on it. Will I see a gain in performance from the TKO's and if so where?
malik is offline
Old 01-07-2009 | 05:54 AM
  #5333
vnmsgt's Avatar
If any of you guys get a chance, try out the Caster Racing Grenade pipe on the GO's. I just put one on my 7-port and it is insane. Has more power all the way around. Just screams.
vnmsgt is offline
Old 01-07-2009 | 08:32 AM
  #5334
will g's Avatar
what is that pipe equivalant to ??
will g is offline
Old 01-07-2009 | 09:22 AM
  #5335
Rocket42's Avatar
Malik, I am abig fan of ceramic bearings and have ran them in most of my engines, you will find the engine will be crisper on the bottom with a better idle and will not really be faster on top but will pull harder on top, that is just the feeling I got from running them. Not to mention the TKO bearings are good quality and will last a long time.
Rocket42 is offline
Old 01-07-2009 | 09:38 AM
  #5336
vnmsgt's Avatar
Not quite sure as it just came out and there is no number on it. I do know it is huge and bigger than a JP-4 which is pretty big.
vnmsgt is offline
Old 01-07-2009 | 09:42 AM
  #5337
will g's Avatar
ok cool thnx i have a friend thats thinking about getting one just figured would ask thnx will g
will g is offline
Old 01-07-2009 | 11:28 AM
  #5338
Thanks Rocket now we just need that order to come in.
malik is offline
Old 01-07-2009 | 04:13 PM
  #5339
vladconnery's Avatar
Originally Posted by 69mustangbjs
has anyone heard of a price for the ebmod 5 port?
I did not see an answer to your question so if I missed it sorry. The new Go 5 port is going to be $279 The EB mods version is going to be $349. I personally talked to the importer last night. So this is not hear say. Also they are about 2 weeks away from getting them.
vladconnery is offline
Old 01-07-2009 | 04:21 PM
  #5340
RETRO RC's Avatar
do you mean the stock EB mods 5 port will be $279 and the tuned EB mods 5port will be $349.
Or are you saying that Go are increasing their prices in the states on their 5 ports to $279
RETRO RC is offline
