Like Tree2Likes
Go-Tech Engines Thread
Old 07-20-2008 | 11:43 PM
  #3871
vti-chris's Avatar
Run my 3 port R with the RB carb this weekend.
WAY better on bottom end, no bogging and could tune it very easy.
No movement of the carb like the GO was doing.
The overall power seemed the same although i did notice a slight decrease in fuel consumption but it wasn't perfectly tuned yet so i'll have to look at it again.
Did have the chance to try out the novarossi C6TF plug and was very good...great top end with good temps.
vti-chris is offline
Old 07-21-2008 | 08:07 AM
  #3872
free2day77's Avatar
I ran my GO 3prt Spec R more yesterday. I am using the stock GO carb with the short LSN and this thing flat hauls. I am very happy with this engine now.
I am getting close to 10min nows with this engine with the 8mm restrictor. I am going to try a 7 soon to soften the bottom and see if I can stretch my runtime a bit more.
If you have the long LSN I would highly suggest getting the shorter one. It makes tuning easier, much easier.
free2day77 is offline
Old 07-21-2008 | 12:33 PM
  #3873
ape_x's Avatar
Question about humidity:
Whats the general rule of thumb if the humidity increases througout
the day?
The reason i ask is i had a hell of time tuning my 7port this past
weekend. The day started great but at the end of the day it was on the
verge of raining and my engine would die after it got up running temps
when i would WOT down the stretch. should i have richened the top? It
really wasnt obvious cause i had lots of power and smoke on the
stretch.
I'm running an RB carb so it wasnt the carb
ape_x is offline
Old 07-21-2008 | 02:11 PM
  #3874
chim13's Avatar
hey i installed a nova rossi carb on my 7 port and it ran great,but i you like to stay with the go carb. Where can i get my hands on some short lsn?
chim13 is offline
Old 07-21-2008 | 03:10 PM
  #3875
I too am looking for a short LSN. I borrowed the LSN from my P5X and it solved my tuning issues. But I need to put the needle back in its home.
Mudblaster is offline
Old 07-21-2008 | 03:35 PM
  #3876
mugenb46's Avatar
[email protected] they should be able to hook you up.
mugenb46 is offline
Old 07-21-2008 | 05:32 PM
  #3877
tagalong_74's Avatar
racefactorindustries.com and email them and then you can buy them from their. They are five dollars shipped but also remember to ask them about the o rings as the new lsn do not come with them.
tagalong_74 is offline
Old 07-21-2008 | 06:41 PM
  #3878
Today I ran tank #3 thru my 5 port. I am using the break in on page 78 with no problems. Only thing I did is not run alum foil as it runs near perfect temps without it. After cooldown I took a peak at the plug and noticed some metal shavings on the bottom of it. When I first started break in I had no heat gun and quickly realized it is not possible to break this motor in without one. So after gettting a heat gun I had no problem cranking it. But before this I had to use a screwdriver to get the flywheel unstuck. Are these shavings from me forcing the piston thru the top of the sleeve? Before breakin I did a quick cleaning of the internals with nitro cleaner. Unless I missed some shavings? Should I pull apart the motor and clean it out again? I dont like the thoughts of loose metal shavings in my motor.
Chedster is offline
Old 07-21-2008 | 06:50 PM
  #3879
mugenb46's Avatar
The meteal shavings, where they fine grains? it can be from the piston, the sheer from the outside dia of the piston as it pushes through the pinch, thats why i stated to use heat before cranking the engine, if you sprayed the engine out with nitro clean, i would strongley recomend replacing the bearings, and flush the engine out while the bearings are out, this will eliminate all the trash, and spreay the wrist pin and under the piston as well as the rod bushings, and then install the new bearings and use some after run oil upon reassembly, the temps you saw during breakin are a cause of the carb being set to lean out of the box, with proper needle settings during breakin, the fat fuel mix will cool and shrink the sleeve into stalling the engine from being tight at TDC. Hope this helps
mugenb46 is offline
Old 07-21-2008 | 06:56 PM
  #3880
The shavings were not very big but then again I had no problem spotting them on the plug. Is nitro cleaner bad for bearings? Any tips on what brand bearings I should get?
Chedster is offline
Old 07-21-2008 | 07:02 PM
  #3881
mugenb46's Avatar
replacing with stock bearings is fine, no, the nitro clean isn't bad for them but it is this as water, and any shavings that where in or near the bearings are for sure in them now, and will graetly reduce the life of them, if you go with ceramics get TKO's thats all i use when it comes to ceramic bearings, if you need help with instalation or perchasing of TKO's let me know, i can do it for ya.
mugenb46 is offline
Old 07-21-2008 | 09:13 PM
  #3882
22Racer's Avatar
We ran a 5 port and .25 6 port this weekend for the first time. I have been a Go dealer for a while but only ran the 3 and 7 ports. My son ran the 5 port in his Kyosho buggy and .25 in his truggy. Yes the 5 did have alot of bottom but it was still driveable on the track we were at. Both ran flawless and responded to changes well. He did end up winning the 30 minute buggy main by 3 laps! It wasn't because of lack of talent, there was at least 6 other chassis sponsored racers there too! Everyone commented on the motors.
I did shorten the needle on both motors after break in. I shortened them by .200 inch, same length as a Nova.
Has anyone had problems with a rod on a Rb mod Go?
Rex
22Racer is offline
Old 07-21-2008 | 09:18 PM
  #3883
mugenb46's Avatar
Rex
i've never had a problem with a GO rod.
mugenb46 is offline
Old 07-21-2008 | 09:33 PM
  #3884
Internals look fine when I pulled it apart, plenty of oil in there. I did notice some scratches on lower part on conrod from the backplate also what shim was included in the box was it the thin or thicker brass washer so i can take the right one out at the gallon mark thanks guys. There are two thin brass, one thick brass and a thicker alum shim. I just cant remember what one I put in there
Chedster is offline
Old 07-22-2008 | 06:43 PM
  #3885
I noticed some guys like the 053 and 086 dynamite pipes with the go 5 and 3 port motors...My question is on the pipes. Are the manifolds exactly the same for the 083 and 053 and the difference is all in the pipe itself?
Thanks in advance
Jake
Bubonic-X is offline
