Like Tree2Likes
Go-Tech Engines Thread
Old 09-17-2007 | 10:17 AM
  #166
Keep this in mind. If the sealing surfaces are good then there is no reason for sealer to be used. Please I cannot stress that enough. Man it becomes a mess and makes a mess at the same time. We have had no luck with it. I am sure that others do, but a oring seal is one of the best ways to seal any surface that is fitted like a model engine is. Carb into case, backplate into case. You get the idea. Feel the orings look at them if they have flat spots replace them I know you will more then likely have to order them or something but it will prevent a large mess with sealer that will just fill the gap that the oring should be in. And when the fuel hits it depending on the sealer used may not stay may disove as nitro is highly corrosive.
xspower is offline
Old 09-17-2007 | 11:47 AM
  #167
Rocket42's Avatar
Ultraspeed, you can purchase just the button head and make your standard engine a turbo.
Pooldoc, first switch to hotter plugs, that will really help the idling, O.S. p3 or O'donnel 77t. Then try addidng a shim and see if that helps with the plugs, While you have it apart be sure and check your idle gap and make sure its within 1mm-1.5mm. so you can make sure your tune is correct.
Satoch, it may be a good idea to check the rear bearing and see if it is in good shape. Pulling the thin head shim should help.
Rocket42 is offline
Old 09-18-2007 | 11:57 AM
  #168
Tore down the 5 port and I found the problem-2 big chips in the piston sleeve. What a bummer cuz after 5 gallons the thing still has a great pinch!
Anyone know where I can get a piston/sleeve fast? I have a point series race coming up in a week and a half and I'd really like to run this engine.
satoch is offline
Old 09-18-2007 | 12:32 PM
  #169
Thats not so good. Man you should be ableto get the set expressed. Are they not over in Austrailia or something. You will pay for it but you will get it. If you would like my recommendation. I would be real careful with just replacing the piston/sleeve at this point. There was metal that ran through the engine so check the bearings and rod and crank. Man it may be better to replace entire engine if more then one of the listed are bad. Check the crank pin also big place for damage after metal has gone thorugh. Sorry to hear that but you did get 5 gallons not so so bad!!!!!
xspower is offline
Old 09-18-2007 | 03:21 PM
  #170
GenReaper's Avatar
http://massivemods.com with express Air Freight and you should be fine.
Thats from, Australia but hes on the ball, get on it today and you will be sweet.
GenReaper is offline
Old 09-18-2007 | 05:50 PM
  #171
slaytanic's Avatar
Could some one tell me where to buy Go Tech in the US? I don't want to go Ebay as I am pretty sure they sell the series 1. Which I don't want. Also, is the new .28 considered a "sport" engine? I was thinking of trying one out in my Matrix truggy. I am one of those guys who doesn't want to run what everyone elso runs. Around here all you see is V-specs. I currently have Radical mills that no one else runs and they are unbeleivable but I here nothing but good stuff about the Go's.
slaytanic is offline
Old 09-18-2007 | 06:15 PM
  #172
Slaytanic, I know where you race cuz I race there too, and I'll grant you there are several V-Specs but lots of RB's, Ninja's, Werks, SH, and a few Go Tech's also. No one runs the Radicals because after Mikey Czech had problems with his they died. He's had a lot of problems with his Werks also.
satoch is offline
Old 09-18-2007 | 06:38 PM
  #173
Paradoxmaker's Avatar
A main
http://www.amainhobbies.com/index.ph...filter_mfr=168
Carolina's RC
http://www.carolinasrc.com/webstore/...idcategory=318
RcCompound
http://www.rccompound.com/index.php?...id=94&x=51&y=8
Paradoxmaker is offline
Old 09-18-2007 | 08:59 PM
  #174
Rocket42's Avatar
slaytanic you can also check the dealer page out at racefactorindustries.com, there is a full list of all the authorized U.S. dealers.
Rocket42 is offline
Old 09-19-2007 | 08:11 PM
  #175
mugenb46's Avatar
Call Peter at TKO, he always has the parts i need for GO motors and his service is quick.
mugenb46 is offline
Old 09-20-2007 | 05:13 PM
  #176
TKO's website has almost no GO parts on it anymore...All it has is the conrod and wrist pin....dunno what happened to the rest....
Old 09-21-2007 | 02:32 PM
  #177
No P/S listed on the TKO site. Additionally the site says nothing will ship until Monday the 24th.
satoch is offline
Old 09-23-2007 | 05:57 PM
  #178
mugenb46's Avatar
MM, YGPM Thanks man
mugenb46 is offline
Old 09-24-2007 | 11:25 AM
  #179
rltanner's Avatar
Hey Rocket its me Robert Tanner from Havasu we were next to you at the smackdown race i've got the Vertex buggie can you tell me were or can i order a motor from you i got one of those 50% off coupons from the race give me a shout Thankz Rob
rltanner is offline
Old 09-24-2007 | 12:02 PM
  #180
Where's my %50 off coupon? I've gotten 4 guys to buy Go engines!
satoch is offline
